Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 160 - AVS Forum | Home Theater Discussions And Reviews
 397Likes
post #4771 of 6198 Old 03-28-2015, 06:18 PM
WIKED's Avatar
Quoted: 78 Post(s)
Liked: 47
After reading post's on here I am thinking of buying the AEMC CA813 light meter. Has anybody got one?
WIKED is offline
post #4772 of 6198 Old 03-28-2015, 10:04 PM
lovingdvd's Avatar
Quoted: 2716 Post(s)
Liked: 578
Using the CA813 light meter to measure your front projector
lovingdvd is offline
post #4773 of 6198 Old 03-28-2015, 11:53 PM
magicj1's Avatar
Quoted: 67 Post(s)
Originally Posted by Michael9009 View Post
Disable for brightness, enable for contrast.
Really. Why is this please?
I have always been told to leave the DI off when calibrating.
magicj1 is offline
post #4774 of 6198 Old 03-29-2015, 01:06 AM
WIKED's Avatar
Quoted: 78 Post(s)
Liked: 47
Originally Posted by lovingdvd View Post
Thanks for the link. I did read that thread before I posted in here but that last post was 2yrs ago.
WIKED is offline
post #4775 of 6198 Old 03-29-2015, 03:15 AM
Mangiri's Avatar
Hi All, I'm really loving the 500, but had this fault just appear. Vertical red lines in a couple of bands run across the width of the screen. The lines appear with no source equipment connected, so it is a fault with the projector itself. Has anyone seen this before?
Mangiri is offline
post #4776 of 6198 Old 03-29-2015, 03:19 AM
Mangiri's Avatar
Another pic with no equipment connected.
Mangiri is offline
post #4777 of 6198 Old 03-29-2015, 04:49 AM
mariob33's Avatar
Quoted: 90 Post(s)
Liked: 73
Send a message via Skype™ to mariob33
i had a unit that developed these lines and it needed to be replaced. In particular if you see the lines with no source?
In search of video bliss...
mariob33 is online now
post #4778 of 6198 Old 03-29-2015, 10:25 PM
Michael9009's Avatar
Quoted: 286 Post(s)
Liked: 77
On my VW1100ES, with the DI disabled (DI Off and Gamma Off), I have to lower the contrast to 89 to avoid clipping the whites. With the DI enabled on Full Auto (Gamma Off), even with the contrast at Max, the whites would not be clipped. So, this suggests that the DI has other effects (on contrast, gamma) than just lowering the output level in dark scenes. Therefore, you should calibrate the contrast with the DI on, if you plan to leave it on when watching video programmes.
magicj1 likes this.
Michael9009 is offline
post #4779 of 6198 Old 03-29-2015, 10:31 PM
Quoted: 286 Post(s)
Liked: 77
It appears that the unit is faulty. Contact your dealer or Sony to have the PJ replaced or repaired.
post #4780 of 6198 Old 03-30-2015, 01:05 AM
Mangiri's Avatar
Thanks Michael, I'll let you know how it goes.
Also, on another subject, was it reported what Firmware 1.20a does? Google comes up with the following on the latest batch:
"Now shipping latest batch VW500ES! Comes with firmware 1.20A!
Latest batch has significantly reduced thermal blue convergence (less color fringing as the panels warm up)"
I'd be interested to know what has been changed to achieve this!
Thanks again all and cheers
Mangiri is offline
post #4781 of 6198 Old 03-30-2015, 09:19 AM
lovingdvd's Avatar
Liked: 578
From what I recall with my Sony VW95, its firmware cannot be updated by the user - it must go to Sony for service. Is that still the case with Sony's latest models like the 500/600 and 1100?
Also are you saying that it is firmware 1.20a that addresses the blue convergence during warm up and that the latest batch is shipping with firmware 1.20a, or are you saying that the latest batch has some other tweak (along with 1.20a firmware) that helps with this issue?
How can one purchase a unit and know whether its coming from the latest batch?
post #4782 of 6198 Old 03-30-2015, 09:33 AM
mariob33's Avatar
Quoted: 90 Post(s)
Liked: 73
FW on the 500/600 is able to be upgraded by the user using USB port. I don't think unless you buy from the likes of avs (they do open verify upgrade at least for JVC) who will go the extra mile there is a tried and true method to verify. IMO it's truly luck of the draw. Assuming some form of supply chain excellence chances are you will get something recently produced ~1 year probably less.
post #4783 of 6198 Old 03-30-2015, 09:41 AM
lovingdvd's Avatar
Liked: 578
Glad to hear the 500/600 firmware can be upgraded directly by the user. Is the same true for the 1100?
post #4784 of 6198 Old 03-30-2015, 09:44 AM
George Kouzev's Avatar
Quoted: 240 Post(s)
Liked: 66
I had to lower the Contrast on my VW300ES to 89 avoid clipping the whites, only to realize I should not be doing that. Different pj I know, so number is likely a coincidence but in case. If you are talking Spears & Munsil Bluray, you are supposed to make levels above 235 clip on purpose.
George Kouzev is offline
post #4785 of 6198 Old 03-30-2015, 10:28 AM
d.j.'s Avatar
Quoted: 168 Post(s)
Liked: 74
No
dj
d.j. is offline
post #4786 of 6198 Old 03-30-2015, 10:44 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3352 Post(s)
Liked: 3326
Updating the firmware on myVW600 was very easy. A tip - unplug your HDMI cable first.
One way to make sure you are purchasing a projector from " the latest batch " is to buy from AV Science. We only sell " fresh " projectors !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #4787 of 6198 Old 03-30-2015, 10:54 AM
d.j.'s Avatar
Quoted: 168 Post(s)
Liked: 74
Originally Posted by George Kouzev View Post
I had to lower the Contrast on my VW300ES to 89 avoid clipping the whites, only to realize I should not be doing that. Different pj I know, so number is likely a coincidence but in case. If you are talking Spears & Munsil Bluray,you are supposed to make levels above 235 clip on purpose.
Actully I dont think so, allmost every Sony I ever had adjusted ( 10,30,50,90,95,1000,1100) did begin to clip after about 88 with iris off.
IMO it depends on, if you want to see / have the WTW detail (if and when there is some in the materiel ), or you want to maximaze light output - personally I like to have some headroom and if any WTW detail at all, I want to see / have it - therefore I have it at 88 even that I use the auto full mode ( because I do think that even in auto full, it can clip, it just depends on the materiel and how it adjust the contrast/gamma - but not on the static test pattern from S&M )
your opion may differ
dj
d.j. is offline
post #4788 of 6198 Old 03-30-2015, 11:09 AM
Quoted: 240 Post(s)
Liked: 66
It is good to have some headroom in case these WTW show up from time to time, though 11-12 clicks is an overkill for sure.
post #4789 of 6198 Old 03-30-2015, 11:13 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1011
Are they organic as well?
Craig Peer likes this.
mark haflich is offline
post #4790 of 6198 Old 03-30-2015, 11:18 AM
d.j.'s Avatar
Quoted: 168 Post(s)
Liked: 74
Not if here sudently "pops" some detail up at 250 ! ( my clips at 251 with contrast at 89 )
d.j. is offline
post #4791 of 6198 Old 03-30-2015, 11:23 AM
Quoted: 240 Post(s)
Liked: 66
Do you know of reference material where these big pops exist? If these are frequent, a larger buffer can make sense.
post #4792 of 6198 Old 03-30-2015, 12:26 PM
Liked: 1011
Old wine, aged cigars, young women. and fresh projectors. Could have been George Burns' mantra.
joerod and Craig Peer like this.
post #4793 of 6198 Old 03-30-2015, 01:15 PM
zombie10k's Avatar
Quoted: 3026 Post(s)
Liked: 3115
it's possible they are tweaking the digital convergence more so than they currently are. This is one area I didn't like about the VW600 vs. the VW1100. Sony is adjusting these settings at the factory and it can't be turned off. only further adjustments from their 'baseline'.
I would rather have control over this from the start. it let's you see how far off the projector is from the factory.
zombie10k is online now
post #4794 of 6198 Old 03-30-2015, 01:30 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3326
What else do you need in life Mark? I'm there buddy !
post #4795 of 6198 Old 03-30-2015, 03:13 PM
anmg's Avatar
Quoted: 65 Post(s)
I have a 600es and I don't even see the 1.20a on the Sony support website. The latest they have is 1.1.
anmg is offline
post #4796 of 6198 Old 03-30-2015, 04:44 PM
bweissman's Avatar
Quoted: 225 Post(s)
Liked: 89
We're all seeing that. I have no idea why they haven't put the update on that page.
bweissman is offline
post #4797 of 6198 Old 03-31-2015, 01:41 AM
magicj1's Avatar
Quoted: 67 Post(s)
Hi.
May I ask how you are detecting clipping? I've recently calibrated my vw500 at 100% contrast, I used Agryll/1000 patches, the calibration time was pretty reasonable and the results look spot on to me. Please do not think I am contesting your findings, just wanting to learn more accurate methods.
magicj1 is offline
post #4798 of 6198 Old 03-31-2015, 05:37 AM
Quoted: 240 Post(s)
Liked: 66
Hi.
My finding is the same as yours BTW - my PJ is good at 100% contrast. I calibrated using the approach suggested in the S&M disk tutorial (you can Google it). They have a pattern with the top 40-50 levels of white in one bit increment - all the way to 255. With normal signals (as opposed to high dynamic range, I am not sure if they exist for video), the brightest white should not exceed 235. They suggest you map the max contrast of the display to 235 thus clipping all level above in order to max your dynamic range. NOTE: this improves the on/of contrast (another way of saying dynamic range) by 10-20% compared to the 89 contrast setting where you avoid clipping up to 255!
magicj1 likes this.
post #4799 of 6198 Old 03-31-2015, 06:25 AM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
I believe the CA813 became popular a decade ago, or more, when there were very few choices for reasonably priced lux meters. Today there are some much less expensive alternatives. I have both a Minolta meter (higher end than the CA813) but I also have a very inexpensive LX1330B (sold under several brand names - Amazon link below). While there very well may be more unit-to-unit variations in the accuracy for the LX1330B (I checked one a friend had purchased and it measured about 10% higher than mine) than for the CA813, but my unit measures within about 1% of what the Minolta reads for light at or near 6500K. One of the problems with any of these meters is the maximum accuracy is for lower color temperatures and in fact AEMC rates the CA813 accuracy at +/- 5% for a 2856K light source (incandescent light) but only +/- 11% for other light sources (see the 2nd link below for the spec. sheet).
http://www.amazon.com/Dr-Meter-Digit...ords=lux+meter
http://www.aemc.com/products/pdf/2121.21.pdf
WIKED likes this.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #4800 of 6198 Old 03-31-2015, 06:48 AM
anmg's Avatar
Quoted: 65 Post(s)
Can you get the 1.20a update somewhere else?
anmg is offline
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
