Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 397Likes
post #4861 of 6198 Old 04-12-2015, 11:12 PM
Javs's Avatar
Quoted: 2388 Post(s)
Liked: 1987
My 300ES has an issue with warm up blue convergence. It takes about 20-30 minutes to go away. Is this considered bad?
I know its not a 500ES but looks like the issue is there on the 300/350
JVC X9500 (RS620) | OZTS Majestic 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | Rotel RMB-1555B | DIY Javelin Audio TPL-150 L/C/R | DIY Faital MTM TPL-150 Surrounds | DIY Dolby Atmos MKII Modules | DIY Quad 18" Subs 30cf Net
Shootout - JVC RS500 (X7000) & Sony 320ES | My Panasonic UB900 HDR and SDR Settings | My MadVR Settings
Javs is online now
post #4862 of 6198 Old 04-13-2015, 07:31 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
Originally Posted by Eventidal View Post
Just to let you know, I actually own one... And it has Firmware 1.200a onboard and it is has been delivered as European version, even if the label says Japan...
Interesting -- seems to me that the "Sx" may be more indicative of the intended market for sale - versus a revision number.
BTW - when you say "1.200a" ... do you mean "1.20A"?? That is the firmware that was loaded on my "S1".
Skrill is offline
post #4863 of 6198 Old 04-13-2015, 07:38 AM
desray2k's Avatar
Quoted: 276 Post(s)
Liked: 114
That's pretty bad IMO...maybe you want to do some panel alignment in the settings.
desray2k is online now
post #4864 of 6198 Old 04-13-2015, 07:39 AM
Javs's Avatar
Liked: 1987
Oh I can get it perfect using the alignment but we all know its better if I don't have to do that.
Javs is online now
post #4865 of 6198 Old 04-13-2015, 08:01 AM
Mike Garrett's Avatar
Quoted: 5937 Post(s)
Liked: 3832
Don't touch panel alignment, until the projector has warmed up for an hour. Then adjust if needed/wanted. All projectors have to warm up and any 3-panel projector is going to need longer warming up, than a single chip. What you want to see is if the projector, once warmed up looks good from your viewing distance, not from 3' or 4' away. You also want to see if, once warmed up, it goes to the same place for convergence each time.
mjgarrett100@gmail.com
Mike Garrett is offline
post #4866 of 6198 Old 04-13-2015, 08:02 AM
Liked: 3832
Please note, he said his projector was not warmed up. All 3-panel projectors will not look their best, for convergence, when warming up.
post #4867 of 6198 Old 04-13-2015, 09:10 AM
Javs's Avatar
Liked: 1987
Correct, after 30-40 minutes the blue settles but still roughly 2 pixels out. I used panel alignment on the blue by a full 2 pixels up and one full pixel to the right, then it looks perfect. I used the tool because I could see green fringing even when it warmed up. I sit pretty close.
I am still in the process of DOA swapping my unit for the stuck pixel issue so hoping my replacement also has better convergence and I wont have to use the alignment tool.
Javs is online now
post #4868 of 6198 Old 04-13-2015, 02:08 PM
lovingdvd's Avatar
Quoted: 2712 Post(s)
Liked: 575
Glad you are getting it swapped out. Just to clarify - when you say you need two full pixels up and one pixel over to fix the convergence - is that once it is warmed, or do you mean you need to do that if you want to make it look converged when cold? Two pixels up and one over is a huge amount of misconvergence IMO.
lovingdvd is offline
post #4869 of 6198 Old 04-13-2015, 03:41 PM
Javs's Avatar
Liked: 1987
This is when its totally warmed up, and when I say warm I mean its the same after running a couple of full length films.
Blue is 20 notches up and 10 left which is 2+1 pixels according to you guys.
Anyway hoping the new one is good, clearly my unit is a lemon.
Javs is online now
post #4870 of 6198 Old 04-13-2015, 04:23 PM
desray2k's Avatar
Quoted: 276 Post(s)
Liked: 114
Yeap...that sounds pretty bad. Hope you "new" unit will be better.
And yes, you should only adjust the panel AFTER its been warmed up. My unit is very good...even when I start up the projector. blue pixel shift is at its minimal.
post #4871 of 6198 Old 04-13-2015, 04:23 PM
Seegs108's Avatar
Quoted: 4390 Post(s)
Liked: 2193
I don't think it's considered a lemon. Definitely not optimal performance. But most don't get perfect convergence and I believe 2 pixels off is still within Sony's quality control limits.
Seegs108 is offline
post #4872 of 6198 Old 04-13-2015, 04:25 PM
Javs's Avatar
Liked: 1987
I think you are probably right, if these were 1080p pixels we are talking about it would barely be one pixel out in reality.
A couple 4k pixels out is not so bad.
Javs is online now
post #4873 of 6198 Old 04-13-2015, 04:30 PM
Seegs108's Avatar
Liked: 2193
Normally I only care about misconvergence if it's actually visible from my seating distance. It goes the same for using the convergence software. I dont enabled it if I can't see the misconvergence. Because the software alters the video, not the panels themselves. Aka don't use it if it doesn't visibly bother you. If you can see it with video content I'd say definitely look into getting a new unit.
Seegs108 is offline
post #4874 of 6198 Old 04-14-2015, 12:53 AM
Quoted: 49 Post(s)
Liked: 4
[QUOTE=Skrill;33445370]Interesting -- seems to me that the "Sx" may be more indicative of the intended market for sale - versus a revision number.
Nope, it has to do with serial numbers!
Eventidal is offline
post #4875 of 6198 Old 04-14-2015, 05:55 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
[quote=Eventidal;33467530]
Hmm - you seem so confident in your statement - but my unit was labeled "VW500ES1", has a "120XXXX" serial, and was factory loaded with firmware 1.20A.
Skrill is offline
post #4876 of 6198 Old 04-15-2015, 04:07 AM
Mangiri's Avatar
Originally Posted by Mangiri View Post
Thanks Michael, I'll let you know how it goes.
Just received the unit back from Sony. They replaced the Optical Block.
The projector is now working fine again and has also improved the blue shift, focus and the ability to adjust the red properly. It came back with firmware 1.10 still loaded.
Cheers
Mangiri is offline
post #4877 of 6198 Old 04-15-2015, 04:40 AM
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
Cheers
How long did the repair take? Remind me, was this a 600 or 500?
Tnedator is offline
post #4878 of 6198 Old 04-15-2015, 09:21 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3323 Post(s)
Liked: 3277
Cheers
That's good news. And that is the current firmware.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #4879 of 6198 Old 04-15-2015, 10:06 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
Except for 1.20A right? I know it seems like Sony hasn't stated much about it or made it available for download -- but wouldn't 1.20A be the most current firmware?
Skrill is offline
post #4880 of 6198 Old 04-15-2015, 10:13 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 3277
I haven't seen that version available to download from Sony. And someone gets their projector back from Sony with version 1.10. That tells me that 1.10 is current. 1.20A ? Vaporware. Or not for the US market perhaps.
post #4881 of 6198 Old 04-15-2015, 10:15 AM
Liked: 3832
Bingo.
post #4882 of 6198 Old 04-15-2015, 10:22 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
The later may be true (i.e, not for US market) -- but it certainly isn't vaporware. I can attest to that. I still would love to see the release notes on 1.20A (and know what it does different than 1.10 - if anything).
Skrill is offline
post #4883 of 6198 Old 04-15-2015, 01:40 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3277
My feeling about firmware is if your ( fill in the blank - projector, Blu Ray player etc. ) is working just fine, don't fix it.
post #4884 of 6198 Old 04-15-2015, 03:31 PM
Mangiri's Avatar
Mine was a very early build 500. The repair with Sony took exactly a week (including shipping both ways to Sydney) and I have to say was completely painless. They couldn't have been more helpful.
Thanks for the help here too guys. Appreciated.
Cheers
Mangiri is offline
post #4885 of 6198 Old 04-15-2015, 03:38 PM
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
Cheers
That's good to hear, both that it's sorted out and that they made it painless.
Tnedator is offline
post #4886 of 6198 Old 04-15-2015, 06:28 PM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
You know - I just checked my unit, and you are right. The firmware is "1.200 A" as noted in the menu information screen.
Skrill is offline
post #4887 of 6198 Old 04-16-2015, 05:29 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Does anyone know what throw distance I would need for the Schneider Cine Digitar 1.33x? I have found info on the Sony VW50 but not the 600 (I am at about 17 feet with my UH480).
Would this be an upgrade from my UH480?
MX48 is offline
post #4888 of 6198 Old 04-16-2015, 07:02 AM
Liked: 3832
Screen size?
post #4889 of 6198 Old 04-16-2015, 07:07 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Sorry, thought I put that in there. 170" wide.
MX48 is offline
post #4890 of 6198 Old 04-16-2015, 07:13 AM
Seegs108's Avatar
Liked: 2193
The Schneider Optics CD 1.33x is a horizontal expansion lens. From basically the same distance as what the projector on its own could do, this anamorphic lens will shorten that length by 1.33x (you just need to factor in the extra length of the anamorphic lens, that's why I said 'basically the same distance'). So as an example, if you were using a 100" wide screen, the Sony on it's own (with it's 1.31 - 2.68 lens) could fill that screen if the lens is placed anywhere from 131 inches to 268 inches. But add in the anamorphic lens and it shortens the throw by 1.33x so you'd be close to 98 inches to 202 inches with the lens in place.
I think the Cine Digitar is better in terms of pincushion over the UH480. I've had both here. The UH480 can accommodate shorter throws however before vignetting occurs. Both are excellent in terms or retaining image sharpness.
Seegs108 is offline
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
