Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 164 - AVS | Home Theater Discussions And Reviews
post #4891 of 4917 Old 04-16-2015, 07:16 AM
MX48's Avatar
Quoted: 55 Post(s)
Liked: 33
Thanks Seegs.
MX48 is offline
post #4892 of 4917 Old 04-16-2015, 07:37 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1440 Post(s)
Liked: 784
Originally Posted by MX48 View Post
Sorry, thought I put that in there. 170" wide.
Originally Posted by Seegs108 View Post
The Schneider Optics CD 1.33x is a horizontal expansion lens. From basically the same distance as what the projector on its own could do, this anamorphic lens will shorten that length by 1.33x (you just need to factor in the extra length of the anamorphic lens, that's why I said 'basically the same distance'). So as an example, if you were using a 100" wide screen, the Sony on it's own (with it's 1.31 - 2.68 lens) could fill that screen if the lens is placed anywhere from 131 inches to 268 inches. But add in the anamorphic lens and it shortens the throw by 1.33x so you'd be close to 98 inches to 202 inches with the lens in place.
I think the Cine Digitar is better in terms of pincushion over the UH480. I've had both here. The UH480 can accommodate shorter throws however before vignetting occurs. Both are excellent in terms or retaining image sharpness.
170" wide 2.35 screen and 17' of throw, he is going to have a lot of pincushion on a flat screen and a curved screen would be the recommended screen to use. The minimum recommended throw for that size image using a flat screen is 21'-6" when using an A-lens. If you go with the 17' of throw, expect to see about 1.25" of pincushion top and bottom.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Sony, JVC, Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, SVS & Def Tech, Denon, Pioneer, Marantz & Yamaha .
AV Science Sales 5 is offline
post #4893 of 4917 Old 04-16-2015, 07:40 AM
MX48's Avatar
Quoted: 55 Post(s)
Liked: 33
Thanks Mike. My screen is DIY convertible curved using track linear actuators.
MX48 is offline
post #4894 of 4917 Old 04-16-2015, 07:54 AM
AVS Club Gold
Liked: 784
To calculate the range of the throw for an A-lens, you use the height of the image. 170" wide 2.35 screen gives you a 72.34" high image. That is the size image in 16:9 that you have to look at. Using a VW600, you can shoot that size image from 14'-9" to 30'-4". So if you had a flat screen, you would use the range of 21'-6" to 30'-4" and with a curved screen, from 14'-9" to 21-'-6", depending on the curvature. If you have the standard 45' radius curve, then 17' to 18' should be pretty good.
post #4895 of 4917 Old 04-16-2015, 09:27 PM
lovingdvd's Avatar
Quoted: 677 Post(s)
Liked: 131
Originally Posted by Javs View Post
This is when its totally warmed up, and when I say warm I mean its the same after running a couple of full length films.
Blue is 20 notches up and 10 left which is 2+1 pixels according to you guys.
Anyway hoping the new one is good, clearly my unit is a lemon.
I don't think it's considered a lemon. Definitely not optimal performance. But most don't get perfect convergence and I believe 2 pixels off is still within Sony's quality control limits.
At first when I read this I thought oh wow, how can he not think 2 pixels off was not a HUGE misalignment error. Then it dawned on me - we are talking about pixels on a 4K projector. So at 1/4 the size of 1080p pixels, that means being off by 2 pixels is 0.5 1080p pixels. That's still less than what I'd consider good, but understandably no longer in the "huge" department.
lovingdvd is offline
post #4896 of 4917 Old 04-16-2015, 09:31 PM
lovingdvd's Avatar
Quoted: 677 Post(s)
Liked: 131
What is Sony's current Advanced Replacement Policy for projectors in the US? I assume the VW600 and VW1100 fall under this. As of 3 years ago when I got my VW95 the policy was within the first 90 days Sony would send you out a new unit over night and then you'd put your bad unit in that box and ship it back. Then I think I heard they changed it to two months instead of three. Anyway, I haven't followed along in recent years - can someone say if this is still how their policy works?
post #4897 of 4917 Old 04-16-2015, 09:32 PM
Javs's Avatar
Quoted: 66 Post(s)
Yep 4K Panel... I don't mind that amount once its warm but it takes at least an hour of horrible convergence before it settles on 2+1 pixels out, I can get it looking perfect with Alignment tool and to me there is no loss of sharpness whatsoever when I use it so thats not really an issue I guess.
I am swapping my unit for a stuck pixel issue though, although a separate issue that's the reason I am actually swapping it for. Hopefully my replacement has even better alignment and no stuck pixels...
Current:
Sony 300ES | OZTS Majestic Screen White 120" 16:9 | Denon AVR-791 | Krix KDX L/C/R + Surround | Seismix 3 MK3 Subwoofer | Sony PS4 | Xbox-360
Wish List:
Marantz AV8802 | Elektra Thatron HD | Anti-Mode 8033 II
Javs is online now
post #4898 of 4917 Old 04-17-2015, 05:09 AM
ultra 150 pilot's Avatar
Quoted: 44 Post(s)
Liked: 24
I wonder at what point does Sony repair these projectors or just puts units like the one your sending back into resirculation and sells them as b stocks
ultra 150 pilot is offline
post #4899 of 4917 Old 04-17-2015, 05:42 AM
George Kouzev's Avatar
Quoted: 153 Post(s)
Liked: 44
In a way you should feel lucky about the stuck pixel as your next unit is likely to be better with convergence too.
George Kouzev is offline
post #4900 of 4917 Old 04-17-2015, 05:59 AM
mark haflich's Avatar
Quoted: 1059 Post(s)
Liked: 760
I wouldn't be concerned with globally correcting panel non alignment in full pixel increments at all. I wouldn't consider a 3 pixel error to be any worse than 2 pixels or one pixels. FULL pixel correction has for all practicality no adverse impacts on picture quality except for the loss of a line per pixel corrected at the edge of the image and those lines are normally overscanned on the screen border. I would MUCH MUCH more have a full three pixel error than a 1/2 pixel error whose correction would introduce artifacts to the really anal viewer. If you can't see the misconvergence from your viewing on your thrown seat, leave the convergence controls alone except for full pixel global corrections.
Mark Haflich
markhaflich@yahoo.com
call me at: 240 876 2536
mark haflich is online now
post #4901 of 4917 Old 04-17-2015, 06:07 AM
Liked: 760
It has nothing to do with what you see or don't see, there are no loses in sharpness with global full pixel correction. Loses occur with subpixel corrections which are absolutely there no matter how non acute you are as an observer. A set that as a full pixel error is better than a set with a half pixel error if you insist on correcting subpixel errors.
Mark Haflich
post #4902 of 4917 Old 04-17-2015, 06:45 AM
AVS Club Gold
Liked: 784
It is now 30 days.
post #4903 of 4917 Old 04-17-2015, 06:47 AM
AVS Club Gold
Liked: 784
I don't think they sell them as B-stocks. I have sold a lot of B-stocks and have never had a B-stock with a stuck pixel.
post #4904 of 4917 Old 04-17-2015, 09:12 AM
Wendell R. Breland's Avatar
Quoted: 144 Post(s)
Liked: 80
Would this be an upgrade from my UH480?
This is not an answer to your question but you may want to read this article by Ron Jones here. Be sure to read the reply by ozvids. He implies the crystalmorphic by Tony Drummetts is the only one available that will pass 4K. Please note the article is a year old and things may have changed in the world of anamorphic lens.
Wendell R. Breland is offline
post #4905 of 4917 Old 04-17-2015, 10:01 AM
Craig Peer's Avatar
Location: In my home theater ( when I'm not rock climbing, cycling or kayaking ) - Sacramento CA area
Quoted: 740 Post(s)
Liked: 558
I've been perfectly happy zooming on my 2.35:1 screen with my VW600.
Craig Peer, AV Science Sales. Call me on my direct line - 585-671-2972, 8:30am - 4:30pm PST, Monday - Friday
Email me at craig@avscience.com http://shop.avscience.com/
Yes, we sell Home Theater gear right here at AVS !!
JVC, Sony, Epson, DPI, SIM2, SV Sound, Martin Logan, RBH, and many more!
Craig Peer is offline
post #4906 of 4917 Old 04-17-2015, 10:23 AM
Quoted: 144 Post(s)
Liked: 80
Same here except for reading menus, when zoomed, from BD player and FMP-X10 media player.
I can not find any info on "crystalmorphic by Tony Drummetts". Thought sure I had a reference but can not find it anymore
post #4907 of 4917 Old 04-17-2015, 10:30 AM
Craig Peer's Avatar
Quoted: 740 Post(s)
Liked: 558
Try this - http://xeitoptics.com/xeit-v-isco-shootout/
post #4908 of 4917 Old 04-17-2015, 01:13 PM
sriram227's Avatar
how to fix this issue on sony 600es
sriram227 is offline
post #4909 of 4917 Old 04-17-2015, 01:15 PM
sriram227's Avatar
How to fix this issue on sony 600 es
ID:	671169   Click image for larger version
ID:	671177   Click image for larger version
post #4910 of 4917 Old 04-17-2015, 05:05 PM
Javs's Avatar
Quoted: 66 Post(s)
Mate, that needs to be returned for repair
Current:
Wish List:
Javs is online now
post #4911 of 4917 Old 04-17-2015, 06:50 PM
Liked: 760
Wow. Even firmware 1.20a won't fix that. Obviously the unit was dropped, probably in shipment, severely damaging the optical block. Surely, the problem didn't arise after time on the unit.
d.j. likes this.
Mark Haflich
post #4912 of 4917 Old 04-17-2015, 10:08 PM
Skrill's Avatar
Quoted: 178 Post(s)
Liked: 54
I think you underestimate the power of 1.20A.
d.j. likes this.
Skrill is offline
post #4913 of 4917 Old Yesterday, 07:11 AM
desray2k's Avatar
Quoted: 35 Post(s)
Liked: 27
??? What power?
Sent from my Nexus 6
desray2k is online now
post #4914 of 4917 Old Yesterday, 07:47 AM
Skrill's Avatar
Quoted: 178 Post(s)
Liked: 54
Originally Posted by desray2k View Post
??? What power?
Why ... the power of humor and sarcasm of course ...
Skrill is offline
post #4915 of 4917 Unread Today, 12:09 AM
desray2k's Avatar
Quoted: 35 Post(s)
Liked: 27
??? What power?
Haha... Maybe I m Asian that's why dun understand it.
post #4916 of 4917 Unread Today, 01:06 AM
BakeApples's Avatar
Quoted: 18 Post(s)
Do you know the price for this lens? Couldn't find it in the link you provided.
BakeApples is online now
post #4917 of 4917 Unread Today, 01:18 AM
Liked: 760
??? What power?
Conversely, sometimes I find some Asians difficult to understand. I was talking with a pretty Asian woman the other day who walked up to me at a party and I really didn't understand much of what she was saying. To be polite, I simply kept nodding my head yes. She then said something that obviously I completely misunderstood because she slapped my face very hard. Still dun understand exactly why.
Mark Haflich
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
