Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 404Likes
post #6211 of 6218 Old 07-15-2017, 05:55 PM
aka: HarperVision
Dave Harper's Avatar
Quoted: 1370 Post(s)
Liked: 609
Originally Posted by bweissman View Post
That's interesting, thanks. I was unaware of the Sony UBP-X800. I see it also has a display setting for "TV or Projector", which I haven't noticed in a player before.
About that 8-bit data, isn't that all the 600ES can handle? Does the 600ES's "x.v.Color" setting help at all with wide-color-gamut content?
I guess I will head over to the X800 thread, but one more quick question. It's vague in the manual how the "4K upscale" setting works. Does the "Auto1" setting do the right thing with our projectors, namely send 1080p when playing a regular Blu-ray and 2160p when playing a UHD disc? I prefer to upscale 1080p in the projector.
Thanks again.
The UB900 also has a setting to choose TV or Projector.
Yes you can send 10 bit to the Sony, but I think the driver board is limited to 8 bits (per Seegs108). The SXRD panels themselves are 12 bit.
Yes the x.v.Color (x.v.YCC) setting is a little bit wider gamut, but the source has to also have that capability, and not many do. I think the PS3 does. But since it is capable of wider than rec709 color gamut, you can send the BT2020 (which is for now just P3 inside the 2020 container) and it will go out as far as it can color wise, which if I recall gets to about 87% of DCI-P3 color gamut for the Sonys. So you do get some benefit by sending BT2020 from your UHD players, etc. I saw this first hand while testing a 350ES, 365ES & 675ES.
Originally Posted by toomanytvstosee View Post
Paul what converter are you referring to
Originally Posted by PBonn View Post
The HD Fury, and I think there is another one.
Paul
HDFury has two out now, the Integral and the Linker, and a new one coming in Nov called the Vertex that does what each of those do combined, and then some!
bweissman likes this.
Dave Harper is offline
post #6212 of 6218 Old 07-16-2017, 02:31 PM
cdnscg's Avatar
Quoted: 381 Post(s)
Liked: 77
What colour space setting would you suggest to get the most from a 350ES to max the potential of a HDR player like the Sony X800?
cdnscg is offline
post #6213 of 6218 Old 07-16-2017, 11:26 PM
aka: HarperVision
Liked: 609
The 350 also supports the xvYCC if I recall so that's also wider than rec709, so you can send BT2020 and let it go as wide as it can, which is probably the same 87 or so % of P3.
You'll probably need an HDF Integral or Linker to get it to output SDR BT2020 though. Or try to get it to send HDR with a Linker and then use custom settings like my HarperVision ones.
post #6214 of 6218 Old 07-17-2017, 07:56 AM
cdnscg's Avatar
Quoted: 381 Post(s)
Liked: 77
Thanks for the reply Dave. I was hoping that I could work with one of the 5 Color Space options mentioned in the manual.
Dave Harper likes this.
cdnscg is offline
post #6215 of 6218 Old 07-18-2017, 06:00 PM
aka: HarperVision
Liked: 609
I'm pretty sure if you have a meter like an i1 and grab a free calibration software like HCFR (if you don't have these already?) then you should be able to use the Custom Color Space and send BT2020 to it with an HDF device and then check and adjust the CMS to as wide as you can get it to support. I think it'll be similar to the other Sonys, about 87% of P3.
post #6216 of 6218 Old 07-18-2017, 06:48 PM
cdnscg's Avatar
Quoted: 381 Post(s)
Liked: 77
Thanks again. After all these years I still haven't found the time or the courage to approach such types of calibration. Possibly something for my retirement
On a somewhat non-related subject, is there a moderately priced pj (in the $ range of a Sony 350ES) that truly shows a noticeable benefit of the latest HDR players and discs? My 300ES is a great 4K pj, but I see no difference when playing a UBR discs.
cdnscg is offline
post #6217 of 6218 Old 07-18-2017, 07:02 PM
aka: HarperVision
Liked: 609
Yes, I would look for a leftover or B-Stock JVC RS600 or maybe a new JVC RS520. You may even be able to get an RS620 in the range that the 350ES retailed for.
I personally think the laser phosphor Epson LS10000 and LS10500 do it justice as well, if calibrated right for HDR.
I would contact @Craig Peer or @Mike Garrett from AVS.
Craig Peer and Mike Garrett like this.
post #6218 of 6218 Old 07-18-2017, 08:01 PM
Mike Garrett's Avatar
Quoted: 6583 Post(s)
Liked: 4276
Would be happy to help you.
mjgarrett100@gmail.com
Mike Garrett is online now
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
