Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 209 - AVS Forum | Home Theater Discussions And Reviews
 404Likes
post #6241 of 6249 Old 09-17-2017, 06:47 AM
myc52002's Avatar
Originally Posted by myc52002 View Post
I'll give this a try. I have attempted several combination of settings with no success but probably not this exact set. I am connected to input 2 directly as well with the same results. There is no other display connected to the Anthem either. I'm not sure it's worth the mess to add the HDFury. Obviously the picture even in 1080P is superb but I am more annoyed by why this issue exists. It's is only on HDR encoded discs.
Well that didn't work either. It seems pretty clear whether its because of updates etc. one just can't play an HDR disc on this projector without some kind of interference device like the HDFury. No sure it's worth going there when it still looks great as is. Kind of knew this could happen when I bought the unit but still a bit frustrating trying to keep up with a moving target. Thanks all for the suggestions.
myc52002 is offline
post #6242 of 6249 Old 09-17-2017, 07:40 AM
Wendell R. Breland's Avatar
Quoted: 312 Post(s)
Liked: 172
No device needed for UHD HDR playback. Set my Oppo UDP-203 and Sony UBP-X800 for HDR to SDR and original resolution playback therefore I get SDR but 3840 x 2160 video. That is all one can expect from the VW600. Use the Oppo most of the time for HD & UHD disc playback.
Wendell R. Breland is offline
post #6243 of 6249 Old 09-24-2017, 05:44 PM
myc52002's Avatar
What in the Oppo exactly is HDR - SDR setting? I asssume it may be Strip metadata as only other choice is auto, off , forced. Setting to source direct makes no difference. Not many choices to choose. No combination works. I’ve tried them all.
I make my HDR statement based on the fact The Revenant movie is not HDR and it plays fine in 4K. I’m showing 4K output and the Anthem shows 4K and the Sony shows 4K being received.
Just bought Wonder Woman 4K HDR and does the same as other HDR discs. Oppo is outputting 1080P, not 4K. Long pressing info does show the media type at 4K but it is putting out 1080P.
The only variable here is the HDR encoding on all the discs that do not show in 4K and the one disc I have that is not HDR works as 4K through the processor and projector.
myc52002 is offline
post #6244 of 6249 Old 09-25-2017, 04:28 AM
Quoted: 312 Post(s)
Liked: 172
HDR should be set to OFF.
post #6245 of 6249 Old 09-27-2017, 05:11 PM
myc52002's Avatar
That's what I thought. Didn't work. Now I have to back track on my HDR comments because with more troubleshooting I discovered something else that is even more baffling. Nothing has changed with my previous descriptions except now when I play the non-HDR disc it is also forcing 1080P. So I then decided to direct connect the Oppo to the Sony (real pain as I have to pull the rack out of the wall) and what do ya know ALL my 4K discs play 4K directly from the Oppo to the Sony input 2. No problem whatsoever.
So clearly I was wrong on HDR being an issue so it would seem it is the Anthem. I changed the cable from the Oppo to the Anthem, tried different inputs with no success. So I called Anthem and they claim there is no way it could be the problem because all it does is pass the signal with no processing so it can't effect that issue. I'm not at all convinced of that. Frankly they weren't very concerned with my angst about this. That was frustrating and has not been my experience with them in the past. I also called Oppo just to be sure I wasn't missing something and I'm not. Their explanation mirrors my understanding of the HDCP 2.2 and HDMI 2.0 handshakes that have to occur so it would seem something about the Anthem is interfering some how with that handshake. That I have no answer to so I guess I will move over to the Anthem thread and see what I can find out. At least I know the projector is not an issue with HDR. I appreciate the time from all of you with your thoughts.
myc52002 is offline
post #6246 of 6249 Old 09-28-2017, 06:52 AM
cdnscg's Avatar
Quoted: 407 Post(s)
Liked: 82
Didn't see if you responded, but do you have another non-4k display hooked to your Anthem?
If so, this is your problem.
cdnscg is offline
post #6247 of 6249 Old 09-28-2017, 07:00 AM
Quoted: 312 Post(s)
Liked: 172
I suggested that several post back.
My Yamaha CX-A5100 has HDMI 2.0a, HDCP 2.2 switching. It did work with the Oppo and Sony VW600. But if I made certain changes on the Oppo the 5100 would fail to re-lock and required a power cycle to work again. If the Oppo was used then a Sony FMP-X10 (a 4K media player) selected the 5100 would not lock, if the X10 was selected before the Oppo it would lock. So I procured a E-SDS UHD HDMI Switch which works without issues.
On the Oppo I use the main HDMI out to the E-SDS switch and the 2nd HDMI out to the A5100 for audio, same for a Sony UBP-X800. The X10 has been sold. The A5100 still had trouble locking the audio from the Oppo so I turned off the A5100 HDMI main output when the Oppo is selected and that fixed the problem. The A5100 main HDMI out is connected to the Sony VW600 HDMI 1 input.
A great feature of the A5100 is it has 12 Scene memories with many variables that can be set, so this feature and a MX-980 remote makes it easy to select and use all these devices.
post #6248 of 6249 Old 10-19-2017, 05:39 PM
Pyxle's Avatar
Quoted: 44 Post(s)
My VPL-VW600ES projector no longer works with the Nintendo Switch after the Switch's 4.0 firmware update. The image blinks on and off in docked mode for the projector only, maybe about every 400ms. Other display devices work fine with the Switch; other sources work fine with the projector.
I have tried all manner of devices, cables, or direct connection to the projector; no luck.
Pyxle is offline
post #6249 of 6249 Old Today, 01:24 PM
Skrill's Avatar
Quoted: 256 Post(s)
Liked: 76
Happy 500ES owner here in the US. With nearly 1200 hours on the original lamp -- it's time to order a replacement IMHO.
Any good sites or options for an OEM lamp for a reasonable (discounted) price?
Skrill is online now
post #6250 of 6249 Old Today, 01:30 PM
BCWookie's Avatar
Projector lamp genie is good with coupon on site. I have bought numerous Sony original bulbs. Great service.
Marantz AV 8802
Goldenear 7.2.4
Oppo 105D
HTPC
BCWookie is online now
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
