Official Sony VPL-VW500ES / VW600ES 4K Projector Thread - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 394Likes
Old 02-09-2014, 12:00 PM
whitetrash66's Avatar
Quoted: 66 Post(s)
Liked: 42
Does anyone know if a uk lamp will work in a USA or Canadian machine? I can't find anyone in North America with a lamp in stock or on order. Will a euro lamp work if the part number is the same?
whitetrash66 is offline
Old 02-09-2014, 12:05 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 231
Any reason you think why they would not work? They are just named differently but they should use the same parts. I can understand if it was the Sony 95 or 1000es, but the 500es and 600es are the same projector. Never hurts to be 100% sure
blee0120 is offline
Old 02-09-2014, 12:23 PM
Quoted: 66 Post(s)
Liked: 42
I'm just not sure a euro lamp will work. I know power standards are different there (120 vs 240). If anyone can find me one in stock, I'd be thankful. I already have 500 on mine and I'd like to have a spare
Old 02-09-2014, 12:37 PM
Brad/Viper-Fan's Avatar
Quoted: 33 Post(s)
Liked: 27
I'm thinking of buying the 600ES to use on a smaller screen, 40"x94" scope screen, would this be to bright in low lamp? Screen is a ST130 micro-perf about 1.17gain, light controlled room.
If to bright, is there a manual iris to close down to reduce brightness?
Brad
Brad/Viper-Fan is offline
Old 02-09-2014, 01:00 PM
Mike Garrett's Avatar
Quoted: 5590 Post(s)
Liked: 3578
It would be very bright for a fully light controlled room, but some would like it.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 02-09-2014, 01:22 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Yes. there is a manual iris and you could also use a ND filter.i
mark haflich is offline
Old 02-09-2014, 01:44 PM
Quoted: 33 Post(s)
Liked: 27
Thanks Mark!
In your opinion will that be to bright for that screen size?
Brad
Old 02-09-2014, 02:04 PM
Quoted: 33 Post(s)
Liked: 27
Just to clarify, that's a manual iris in addition to the dynamic iris?
Brad
Old 02-09-2014, 02:58 PM
Liked: 1010
There is only one iris. It can be set to manual or dynamic (full or partial). In dynamic the iris bright opening level can be set via the dynamic iris brightness control which sets how large the iris will open to. this affects how bright the picture will be.
Old 02-09-2014, 04:09 PM
Thaal's Avatar
Originally Posted by BakeApples View Post
Have anyone here imported a 500es from Japan and how did it work? I`m mostly interested in how and if the warranty will apply on a imported 500es from Japan to Europe.
Sony Prime support?
It's important to know that there is NO prime support in Japan with 500es. They mention only 1 year standard warranty. Now will Sony make repairs in Europe for a Japanese 500es... Maybe (or it might be out of warranty repairs) ? All I heard is that Sony Europe's prime support are actually exchanging european units with Japanese ones when swapping units... In the US it might be a different story since it's a 600es and not 500es... Worse case scenario you'll have to pay to ship it back to Japan...
Thaal is offline
Old 02-09-2014, 04:16 PM
espny's Avatar
is there a way to make the projector Simulview ready?!
espny is offline
Old 02-09-2014, 05:17 PM
Quoted: 33 Post(s)
Liked: 27
Thanks for the feedback Mike, in your view, would you buy the 600ES or the RS57/4910 for my size screen?
Brad
Old 02-09-2014, 09:59 PM
Liked: 3578
Old 02-09-2014, 10:19 PM
billqs's Avatar
Quoted: 291 Post(s)
Liked: 171
Sony Prime support?
That's a pretty steep price difference if the yen to dollars calculator I used was correct. I didn't notice any different models from JVC than the ones over here. If Sony eventually decides to market the 500/600 similarly here, they would see tremendous sales. Right now the new e-shift3 projectors and the Sony 4ks are at two very different price points. Both are outside my price point, but last year's model JVC 4810 in B Stock from AVS just might do it for me. It would be a different story if the Sony were competitively priced.
JVC RS500, Denon 7200WA, 7.2.4 Atmos/DTSX dedicated Theater. 133" Dalite 1.3 screen. M&K S150 + K7 ear level, 4 Tannoy DC overheads.
billqs is offline
Old 02-10-2014, 12:23 PM
Liked: 3578
If you did not purchase one already, the 4810 B-stocks are gone.
Old 02-10-2014, 12:49 PM
jaychatbonneau's Avatar
Quoted: 137 Post(s)
Liked: 37
1. Will I need a separate video processor to use a 500es with a 2.40 lens? Can the internal video processor be adjusted to do the appropriate stretch? I know it can for 2.35 lenses.
2. If the 500es can't do stretch for 2.40 on its own, how much stretch do I need to program the external video processor for? Remember the native aspect ration on the 500es is 1.89.
3. How precisely can aspect ratios be entered into video processors? Limited to two digits after the decimal?
Thank you for your help! I know these are noob questions.
jaychatbonneau is offline
Old 02-10-2014, 01:41 PM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 144
Update on lag.
I was playing Red Dead Redemption for the XBOX 360, and was messing around. There is definately a noticeable delay between button pushing and action on the screen. I have an Onkyo 3009, and so i set it to output 4k2k to the projector instead of 1080P. Now I must say, the 4K upscaling is TERRIBLE from this receiver, and the game looked visibly softer. BUT the latency was gone! Much much better! i'd say its improved from about 100ms to maybe 30 ms. It feels like there is no delay compared to sending a 1080P signal. So gaming is much better. I guess when receiving a native source, there is much less processing in the receiver going on.
Because the upscaling sucks so bad from my Onkyo, i set it to output the direct resolution from all my sources (Xbox 360, Xbox One, PS4, Cable box) to my Oppo 103D and let the 103D upscale these sources to 4K so the projector doesn't have to. Now my lag is gone! I'd recommend this to all gamers on this projector, and i'd be interested to see some hard measured numbers on this!
Yesterday i played Demon Souls and also Last of us on PS3 and had no issue with lagging. Demon Souls is critical on timing and I didn't have much issue with it. I said "much" because I haven't played it in a while and not being able to perform an action could very much be my own skills. But for the most part, I was able to perform time critical actions.
I only tested shooting in Last of us and it was spontaneous.
Checking in RC menu, there was no database option available. Checking info, it said 720P/60 FPS.
SherazNJ is offline
Old 02-10-2014, 02:57 PM
Liked: 1010
The answer is no and yes. If your souces are below 1080p, the projector will do the necessary stretch. If your source is UHD or 4K, the answer is you will need to use an external processor.
Old 02-10-2014, 03:08 PM
Quoted: 137 Post(s)
Liked: 37
I know the input has to be 1080P. I have no 4K material to input. :-(
The thing is I will be using a 2.40 lens that stretches by 35% horizontally, while a 2.35 lens stretches by 33%. Can the 500ES do the different vertical stretch necessary for the 2.40 lens?
Old 02-10-2014, 04:45 PM
Liked: 3578
What lens are you using. Most horizontal expansion lenses are 1.33 and that will work fine with your 2.40 screen.
Old 02-10-2014, 05:08 PM
Quoted: 137 Post(s)
Liked: 37
I will be using a Prismasonic that does a 35%stretch instead of 33%.
Old 02-10-2014, 05:57 PM
Liked: 1010
No. The vertical stretch only has two options 1.33 and 1.24 9or something close t that, I don't remember.
Just use the 1.33 stretch on the Sony. You can over scan slightly and you will probably be overscanning more anyway to hide the pincushioning caused by the anamorphic lens.
jaychatbonneau likes this.
Old 02-10-2014, 06:48 PM
billqs's Avatar
Quoted: 291 Post(s)
Liked: 171
Shoot! Any chance more will pop up?
billqs is offline
Old 02-10-2014, 08:21 PM
Liked: 1010
How about the odds on Masters tickets popping up. Whoops this is a Sony 500/600 thread. Excuse me, I look in the right thread. smile.gif
Old 02-10-2014, 08:30 PM
Quoted: 137 Post(s)
Liked: 37
1.33 stretch with a 2.40 lens would look really distorted. Since the 500ES only has two setting for vertical stretch I will just get a Lumagen. If I light the center 3840 by 2160 pixels a 35% vertical stretch will result in exactly a 2.40 aspect ratio with the Prismasonic lens. If I light all the pixels, a 26.66% will get me almost exactly 2.40.
So, how precisely will the Lumagen set the stretch?
Old 02-10-2014, 08:45 PM
Liked: 3578
The vertical stretch of the 600ES works fine on a 2.40 aspect screen. It is not distorted (not talking about pincushion, which all A-lenses give). Not sure where you are getting this.
If your screen is 50" high and 120" wide, then the width of your 16:9 image is 88.89" wide. That means with a 50" high image you would get a 118.5" wide image once stretched 33%. So to completely fill the 120" width, you would need to increase the image height to 50.75", over-scanning the height of the screen 3/8" of an inch, top and bottom.
Added
Now the Lumagen works very well for vertical stretch and since vertical stretch is a scaling function and the Lumagen does a great job scaling, you will probably find that it does a better job than the projector.
Old 02-10-2014, 08:58 PM
Quoted: 137 Post(s)
Liked: 37
Not true. This is because the Prismasonic lens I am going to use does a 35% stretch. Unless the Sony's video processor can be set to a 35% vertical stretch in 1.78 mode there will be geometric distortion.
Old 02-10-2014, 09:02 PM
Quoted: 137 Post(s)
Liked: 37
How precisely can the Lumagen Radiance Mini set the vertical stretch? Do you sell them?
Old 02-10-2014, 09:40 PM
Liked: 3578
Can't do that with the Sony, but I believe you can with the Lumagen, though I think you are not going to be able to tell the difference. Yes we are a Lumagen dealer.
Old 02-10-2014, 09:43 PM
Quoted: 137 Post(s)
Liked: 37
I will call you. Can you ship to Hong Kong?
Sony Vpl Vw500es , Sony Vpl Vw1000es Projector , Sony Fmp X1 4k Ultra Hd Media Player
