Would current <$1000 projectors be an upgrade to my Planar PD7150? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-27-2013, 06:55 PM - Thread Starter
Grayson73's Avatar
Quoted: 12 Post(s)
I've had my Planar PD7150 projector since 2008 and the 3rd bulb just blew. Trying to decide whether to buy another replacement bulb or whether to buy one of the current budget projectors, such as Acer H6510BD, Viewsonic PJD7820HD, Optoma HD131XE, Benq W1070, Epson 2000/2030. I know the advantages of the current projectors are 1080p, 3D, and brightness, but how do they compare for contrast, black level, sharpness, and image noise?
What would you do?
Grayson73 is offline
post #2 of 7 Old 09-30-2013, 06:12 AM
troylavigne's Avatar
You might want to pose this question to the <$3000 forum.
troylavigne is offline
post #3 of 7 Old 09-30-2013, 10:08 AM - Thread Starter
Grayson73's Avatar
Quoted: 12 Post(s)
I thought about that, but I didn't think many of them would be familiar with the PD7150 (MSRP $8000).
post #4 of 7 Old 09-30-2013, 10:34 AM
Noah's Avatar
What's your screen size/viewing distance? I don't think the < $1000 projectors would be an upgrade in any category except resolution.
Also, how much is a replacement lamp? Can you stretch your budget to $2000?
Noah is offline
post #5 of 7 Old 10-01-2013, 10:34 AM - Thread Starter
Grayson73's Avatar
Quoted: 12 Post(s)
106" screen size, not sure about viewing distance. Replacement bulb only $103. Sounds like it would be better to buy a replacement bulb if only resolution would be better.
post #6 of 7 Old 10-01-2013, 12:17 PM
Noah's Avatar
I think I would just buy the bulb for now. Planars are very solid projectors. I don't think anything under $2k would do much for you unless you wanted to use a larger screen (and/or sit closer) or get 3D capabilities.
Sit back and enjoy!
Noah is offline
post #7 of 7 Old 10-02-2013, 06:08 AM - Thread Starter
Grayson73's Avatar
Quoted: 12 Post(s)
Thanks, new bulb it is!
Acer H6510bd Dlp 3d Projector , Viewsonic Pjd7820hd Full Hd 1080p Projector , Optoma Hd131xe Dlp Projector 3d , Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Epson Powerlite Home Cinema 2030 3lcd Projector
