RS35 Bulb Replacement: Increased Magenta Stripe Risk? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-29-2013, 05:10 PM - Thread Starter
Larry Newcomb's Avatar
Hi,
My RS35 has 2900+ hours and I'm now receiving the "bulb replacement" warning. So far I've had no issues (with either the bulb or the projector). It still seems bright enough for me (but I have no way to measure spectral or gamma changes).
  1. Do I need to replace the lamp (why is JVC "bothering" me with this message)? Is there some risk to the projector if I don't replace the lamp?
  2. Am I correct in assuming that a new (brighter) bulb implies more heat generation? If so, the increased heat can't be good for the projector. This model series has had some issues (see http://www.avsforum.com/t/1451654/attention-magenta-or-any-colored-stripe-defect-on-their-jvc-projector).
I supposed I should look on the magenta stripe risk as an excuse to purchase a new projector. smile.gif
Thanks, Larry
Larry Newcomb is offline
post #2 of 5 Old 09-29-2013, 05:48 PM
Mike Garrett's Avatar
Quoted: 7082 Post(s)
Liked: 4785
A few owners have reported seeing the stripe after installing a new lamp. Problem is the new lamp did not cause this. The new lamp was just so much brighter that it made the stripe that the owner did not know was there, show up more.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 5 Old 09-29-2013, 06:22 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2582
The lamp should run just as hot no matter the age as it draws the same amount of power regardless of age. What causes the magenta (or sometimes another color) stripe to occur is the glue used to seal the optical block wearing down over time, most likely from all the heat, which can cause the block to shift slightly which projects the color band people see on screen. Unless you're forcefully jamming the new lamp in you shouldn't worry about causing the issue.
Seegs108 is offline
post #4 of 5 Old 10-02-2013, 06:14 PM - Thread Starter
I guess I should give Mike a call and order one then.
Thanks, Larry
post #5 of 5 Old 10-02-2013, 06:18 PM
Liked: 4785
Thanks, Larry
