Sanus VP1-B1 Ceiling Mount for JVC RS45? - AVS Forum | Home Theater Discussions And Reviews
Old 10-03-2013, 10:31 PM - Thread Starter
ahkim's Avatar
Anyone have experience with the Sanus VP1-B1 mount? The guy at best buy said it would work with my JVC. The weight limit is 35 lbs which is about the projector weight.
Is this a good mount? Will it fit?
I've got Best Buy gifcards so I'm trying to get my mount from there. It comes with a 2" pipe so it can be pretty low profile.
http://www.sanus.com/us/en/products/visionmount/projector-mount/VP1#
ahkim is offline
Old 10-10-2013, 11:40 PM - Thread Starter
ahkim's Avatar
I'll answer my own question, it turns out that BB has Chief mounts so I went with that. Same price but much higher weight rating. It's the Chief RPAU.
ahkim is offline
Old 10-11-2013, 06:26 AM
Mike Garrett's Avatar
Quoted: 5564 Post(s)
Liked: 3542
The RPAU is not compatible with the RS45. You need the Chief RPA281 or RPMA281. You can also get the "B" and "C" versions of the RPM(A)281.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 10-11-2013, 08:54 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
To clarify, its the U part of the mount, the small plate that secures the legs that themselves attach to the projector. The plate can be made to work if you mount it horizontally across the projector width and are willing to drill a small hole. A better solution is to abandon the U (the universal legs and leg securing plate) and instead use a dedicated mounting plate Now no legs are used. the mounting plate is the 281 part of the mount number..RPA281. The plate can be ordered separately or as a package with the RPA etc.
mark haflich is offline
Old 10-16-2013, 03:56 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3037 Post(s)
Liked: 2969
I've come to not like the Universal mount nearly as much as the projector specific mounts, even if they do fit / work with a projector. Why? The plates on the projector specific mounts are much more solid and don't flex like the arms on the universal mounts can. Why is that important? It might not make any difference. But it could. Install two SVS PC13 Ultra subs and watch something with loads of LFE in your theater...............better hope those universal arms don't flex ! eek.gif
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
Old 10-16-2013, 04:30 PM
Liked: 1010
Plus one.
Sanus Classic Vp1 B1 Projector Mount
