Lamps.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-23-2013, 12:24 PM - Thread Starter
eiguy's Avatar
Have a Panasonic DZ6700 projector... its a bit older but they've stopped making bulbs for the thing. What do I do now? I just spent a couple grand on "OEM" lamps that have all the same markings of the original bulbs, minus the sticker on the bulb that says made in china under the housing... Am I stuck only getting fake bulbs? I haven't tried them out yet... should I stick with them?
eiguy is offline
post #2 of 4 Old 10-23-2013, 04:20 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
This was never a HT projector and I doubt anyone here has any experience with it. But it was only a dual lamp projector and replacement lamps for it, a pair, regardless of country of origin, are just not that expensive. Google a bit for best price and cal the vendors advertising them for guarantees etc. You might consider a new projector but you can't get a HT theater projector with 6000 lumens for less than really big bucks
mark haflich is offline
post #3 of 4 Old 10-24-2013, 04:41 PM - Thread Starter
eiguy's Avatar
You're right its not HT. Its used in a conference room. The original bulbs are pretty much impossible to find. Phillips no longer makes them, even though the projectors are only a few years old. One of the fake bulbs blew out in an hour...
eiguy is offline
post #4 of 4 Old 10-24-2013, 07:18 PM
Liked: 1012
The bulb warranty would cover that. You might find some new old stock if you hunt around. How have the other fake bulbs held up?
Panasonic Pt Dz6700uldlp
