could use some expert opinions - AVS Forum | Home Theater Discussions And Reviews
Old 10-28-2013, 10:25 PM - Thread Starter
Roger Wilkerson's Avatar
Hi Guys -
I have a basement theater set up that I have had for around 10 years now I guess. I have a Toshiba TDP MT-500 projector onto a 100" screen at about 13 feet. I have a Yamaha HTR-5660 receiver and I am using DISH network.
I have had the TV portion disabled for years and just got the Dish Joey down there. The projector has no HDMI capability and the Joey doesn't play as well without it apparently. The projector doesn't really support anything over 1024x576
My question is ...would there be an appreciable difference in my picture and sound if I got an HDMI receiver? or should I just leave well enough alone and dial in what I have
Thanks in advance
Roger
Roger Wilkerson is offline
Old 10-29-2013, 01:10 AM
holl_ands's Avatar
Quoted: 450 Post(s)
Liked: 185
As I understand it, Joey has HDMI (for HD) and low-rez (480 lines) Composite Video (Yellow/Red/White). Connecting Composite Video to your low-rez Projector is the obvious choice.
It is also possible to use an HDMI-To-Component-Video Interface Converter if your projector is equipped with a Component Video port....but i doubt that you will see much of a difference....esp if the projector doesn't accept 720p or 1080i and forces the interface to 480 or 576 (Europe?) line resolution.
So I think you need to think about upgrading the projector for 1080 (i or p) High Def before you think about upgrading the AVR to serve as an HDMI Source Switch.
holl_ands is offline
Old 10-29-2013, 05:26 PM - Thread Starter
The projector does accept 720p. I have two component inputs and 1 dvi-d input. From what I can see, it looks like the DVI wasn't being used but is connected to the projector and there is a dvi to hdmi adapter on it. both of the component inputs were being used, one for the DVD and not sure on the other. Since Joey does not support component I am running composite between Joey and my receiver.
I guess my thinking was to get the HDMI receiver and run the Joey to that and then connect the receiver to the projector via dvi?
Would I get 720p that way?
What recommendations might you have for an HD projector?
Old 10-30-2013, 10:23 AM
holl_ands's Avatar
Quoted: 450 Post(s)
Liked: 185
Should work...check Projector threads for user recommendations....
Yamaha Htr 5660 6 Channel Digital Home Theater Receiver
