Official Epson Pro Cinema 6030UB Owners' Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 33Likes
post #271 of 604 Old 05-26-2014, 08:13 AM
myriadcorp's Avatar
Quoted: 42 Post(s)
Liked: 69
Originally Posted by WestCDA View Post
Measure it. If one side of the projected image is taller than the other side, rotate the projector (side to side) until both sides of the projected image are equal in height. Then use the horizontal adjustment dial on the projector to move the image so it aligns with the screen - that 'shifts' the image without affecting the image geometry. You can't assume the screen/wall is perfectly perpendicular to the projector's plane of projection.
Yep that was the problem. The wall the screen is on slants ever so slightly away making one side hit closer than the other. I did some adjusting and was able to get the image centered without any slanting. Thanks for the recommendation.
myriadcorp is offline
post #272 of 604 Old 05-26-2014, 03:42 PM
WestCDA's Avatar
Quoted: 67 Post(s)
Liked: 79
Thanks for the update - glad to hear you were able to sort it out ... smile.gif
WestCDA is offline
post #273 of 604 Old 05-26-2014, 08:10 PM
Archbushman's Avatar
Joined the Epson 6030ub club a few weeks ago! Upgraded from a Sanyo PLV-Z4000. Used the included mount (just had to pick up an eight inch pipe from Lowe's (6 inch that comes with it was a little too short for my setup). The included rear cable cover makes for a very clean install. Had to do a few minor tweaks to get cover to fit right, but well worth it. (Notched out 2 of the plastic tabs on the inside to make a little more room and take off some of the tension on the RedMere HDMI cable...also had to file a small notch so I could get the IR wire to the projector sensor. I shopped around with all the major Epson authorized dealers mentioned in this thread . Everyone was really responsive and helpful. I ended up getting mine from (Jason Lambert) programmergeek:
(908)219-9288
Jason@IntegratedTechSolutions.com
Gave me a great package deal. Super nice guy and easy to talk to... was able to work out all the purchase details via email. Great customer service also...I had an issue with the original mount (pipe got stuck in mounting plate) and he helped me take care of it...Epson sent me a new one over night. Ended up chatting on the phone for almost an hour about various AVS topics. Definitely drop him a line if you are interested in purchasing a projector or any A/V equipment.
Archbushman is offline
post #274 of 604 Old 05-26-2014, 08:19 PM
post #275 of 604 Old 05-28-2014, 02:20 PM
myriadcorp's Avatar
Quoted: 42 Post(s)
Liked: 69
I mounted mine in the drop ceiling with this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824997387&cm_re=epson_drop_ceiling-_-24-997-387-_-Product
It cost $79 and attaches to the included mounting hardware.
post #276 of 604 Old 06-02-2014, 07:17 PM
mjz3348's Avatar
Hi Gregg,
I just received my new 6030UB and it powered up with a stuck pixel (bright blue) ... I guess it has to be returned and replaced.
I hope this is not endemic to this model.
While I am waiting for the new unit - are there preferred settings you can recommend to get started and work from there? This projector has a lot more capability than my previous Pioneer FPJ1 (although it worked flawlessly for years).
I'm not sure whether I should just leave the settings as they came out of the box or tweak them (like turning on auto Iris).
mjz3348 is offline
post #277 of 604 Old 06-03-2014, 07:46 AM
mjz3348's Avatar
Update: Epson is replacing my 6030UB overnight with a new unit. This is great service. I hope the new unit doesn't have the same problem with a "stuck" pixel.
mjz3348 is offline
post #278 of 604 Old 06-07-2014, 05:14 AM
Sebastian1029's Avatar
Hello Everyone,
I am totally new to this aspect of home theater and this projector and screen combo will be my first set-up of this type. I am coming from a 60" Pioneer Kuro and moving to an Epson 6030UB projector with a 113" fixed Black Diamond screen. Where my future projector will be placed, I will need about a 30 foot HDMI cable and the one I was looking at was the Blue Jeans BJC Series 1. I emailed the company and they said it is there most reliable HDMI cable for longer runs. Now I was looking at the above pictures of the ceiling mounted Epson 6030, and how the cables bend in for a clean and organized look and I am wondering if that Blue Jeans cable will be able to bend like that. The customer service guy did say that 23 AWG is a little stiff. I have no idea if it will work and don't want to spend money on something that won't work. I was also thinking about the Monoprice RedMere HDMI cable but then read about signal drop out issues.
Can someone please tell me what HDMI cable they are using?
Thank you for your help.
Paul
Sebastian1029 is offline
post #279 of 604 Old 06-07-2014, 07:39 PM
myriadcorp's Avatar
Quoted: 42 Post(s)
Liked: 69
Originally Posted by Sebastian1029 View Post
Hello Everyone,
Paul
I have a 30ft redmere from monoprice.com Sometimes I get no signal which is due to the cable. If I just hooked my cable from the AVR to the projector it would have no problem. My issues is the 3ft hdmi from my AVI to the wall keystone hdmi. Then it connects to the redmere that travels to my ceiling mount. From there another keystone and 1.5ft hdmi cable connects my projector. The problem monoprice said I have is the multiple connections. They said if I used a standard cable which maxes out 25ft instead of the 30ft redmere with microchip then my signal would never cut out. If you want to make it clean get the longest 1080p cable you can without a chip and use the keystones in the wall to make it look clean. I plan on replacing the redmere but I have not had an issue for a month. It's a crap shoot on it working.
post #280 of 604 Old 06-08-2014, 05:36 AM
Thank you for sharing your experience. My wife already hates me spending any money on this hobby and if I mess up and it doesn't work, she will not be impressed. She loves the Kuro TV and doesn't want me spending the money on the new projector and screen combo. If I buy an HDMI cable and it doesn't work, and then I have to by another one, she'll hold it over my head that I've just wasted even more money. I just want to buy it once and for it to work right. I'll take your advice and just get the biggest 30 foot AWG single HDMI cable (Monoprice or Blue Jeans) and run it from my projector directly to my processor and be done with it. Thanks again.
jimtigerpt likes this.
post #281 of 604 Old 06-08-2014, 08:20 AM
avconsumer2's Avatar
Standard Monoprice 50' hdmi, AVR direct to 6030 here... no signal drops yet.  (approaching 50 hours)  :)
avconsumer2 is offline
post #282 of 604 Old 06-08-2014, 08:39 AM
WestCDA's Avatar
Quoted: 67 Post(s)
Liked: 79
... I'll take your advice and just get the biggest 30 foot AWG single HDMI cable (Monoprice or Blue Jeans) and run it from my projector directly to my processor and be done with it. Thanks again.
If you will be using a heavy gauge cable, it's not going to be very flexible - I recommend you also purchase a couple of 'port savers' to use with it. They are short lengths of smaller gauge flexible HDMI extension cable (M to F) that you can put on each end for the final bends into both the projector and your source equipment. Without them, a heavy gauge cable can put a lot of stress on your HDMI ports, and quite possibly damage them. The port savers are only a couple of dollars each (look at Monoprice part 2891) - I use a lot of them and they work great.
I also use Monoprice HDMI cables of various lengths throughout the house for AV distribution, from 15 ft to 50 ft. These are their standard HDMI 'in-wall' cables (not Redmere), gauged appropriately for the distance, and I've never had a problem with them in several years of use.
WestCDA is offline
post #283 of 604 Old 06-08-2014, 11:28 AM
This is a good idea.  To elaborate, my 50' cable is also of the "in-wall" variety.  It is quite stiff and won't be making any 90 degree turns too sharp.  Will have to look into some of these myself.  Excellent suggestion.
post #284 of 604 Old 06-08-2014, 02:22 PM
drlopezmdfacp's Avatar
I just ordered mine!  First projector and upgrading from Pioneer Elite RPTV.  Is the included "ISF Calibration tools" something that someone with no experience calibrating a TV can use or do I need to make sure the installer does this for me?  If the "tools" are included it seems to imply that your average Joe can do this at home.  What has been your experience?
drlopezmdfacp is offline
post #285 of 604 Old 06-08-2014, 07:59 PM
ghiggs001's Avatar
Out of the box you might like the picture that is presented. After approximately 200 hrs of viewing you can do the basic calibration yourself with either the "Spears & Munsil", or "Digital Video Essentials" calibration discs. There are others that are just as good. I have utilized them myself plus Disney's WOW , and got very good results. You do not have to be an expert.
ghiggs001 is offline
post #286 of 604 Old 06-10-2014, 07:19 PM
Orion5150's Avatar
Quoted: 21 Post(s)
I also purchased the 6030ub from Gregg Lowen mentioned in earlier posts. Hooked me up with the Oppo 103. Gregg was great to work with and very knowledgeable. What an amazing projector! My first one. Screen is not in yet but here's a shot of it projecting on my dark blue walls with lights on. image.jpg 77k .jpg file
avconsumer2 likes this.
Orion5150 is offline
post #287 of 604 Old 06-11-2014, 03:12 AM
Very nice Orion5150, I can only imagine how great it will look on a proper screen! Thanks for posting the photo.
Mine arrives this Friday .. I can hardly wait!
iRadiate is offline
post #288 of 604 Old 06-11-2014, 10:38 PM
danielrg's Avatar
Quoted: 159 Post(s)
Liked: 55
If you get a chance - come back and tell us if your wife gets converted! I'd be curious what she thinks compared to the TV...
Hardware and System engineer. Enjoy theaters, automation, media and the outdoors.
Love the hobby, but always have to remember to keep family first!
"The Escape Pod" - First Theater Build
danielrg is offline
post #289 of 604 Old 06-12-2014, 08:12 AM
It's kind of funny because she thought I was crazy for spending that much money on the 60" Kuro, and I was going to sell it to help pay for the Epson 6030UB, but now it is my wife who doesn't want to let the Kuro go. She's seen what else is out there and likes the Pioneer Elite. All of a sudden she is a videophile! I think (hope) when she sees the projector with the black diamond screen, she is going to love it. Now I just have to wait until I save up enough money to get the projector.
post #290 of 604 Old 06-30-2014, 05:44 AM
milacqua's Avatar
Quoted: 77 Post(s)
Liked: 27
I have a problem. My wonderful 6500UB was fried in a big surge from lightning that struck the antenna mast of my next door neighbor. Lots of electronic equipment was ruined in my house and several neighbors as well. To make a long story short, I plan on replacing this with the 6030, if the insurance company lets me. My Yamaha receiver was also toasted so I will be replacing that as well.
Here is my question - since both replacements will feature 3D capability (something I really don't care for one way or another), what HDMI cables do I have to use? My 50 foot HDMI cable going from the Yamaha to the Epson is about 7 years old so I doubt it is high speed but it is thick gauge and very heavy duty. I only have one shorter HDMI cable that is considered "high speed". I have also heard you don't need any special cable to view 3D but I don't think that is correct. Since I will have 3D capability, I want to utilize it even if on a once in a blue moon basis. I do not have a 3D dvd player but will probably get one as well. What do I need in terms of cable with this projector? What tips can you provide for my conversion from 2D to 3D (such as glasses)? Does the 6030 convert any 2D signal to 3D and if so, how does that work? Thanks for any help.
Rokker likes this.
shortspark
milacqua is offline
post #291 of 604 Old 06-30-2014, 02:11 PM
To be honest, I'd try your current HDMI before investing in a new one. I recently ordered a CL2 rated (in-wall installation quality) standard speed HDMI, and though not officially spec'd for 3D... it seems to be pumping it through just fine. Officially, you're supposed to use a "high speed" HDMI I believe.
You will need a 3D Blu-Ray player (my ps3 works fine as well), as well as an aforementioned HDMI cable to go from the BD (Blu-Ray) player to your receiver. 6030 comes with two sets of 3D glasses that work fine for me.
I do believe it does, but have not experimented with this aspect as of yet.
Also... the "quote" function seems to be jacked up pretty good - sry for any confusion.
post #292 of 604 Old 06-30-2014, 02:17 PM
milacqua's Avatar
Quoted: 77 Post(s)
Liked: 27
Thanks for that avconsumer. I think you are correct that I should just try the cable I have first and if it does not work go from there. I have an Oppo dvd player but not 3D - great time to upgrade!
shortspark
milacqua is offline
post #293 of 604 Old 07-07-2014, 09:52 AM
pwentz3l's Avatar
Wow... it has been a long time since I posted on AVS forum.
I just pulled down my NEC CRT projector and put up an Epson 6030UB. Three people to pull the old one down, and one to put the new one up... with one hand free. I have an older HTPC with DVI out. I purchased an adapter and hooked the two components together via a 26' HDMI cable. No signal. I hooked up the HTPC to my Samsung HDTV with the same cable and don't have any issues. What do I need to look over, HTPC or projector to narrow down the issue? I am going to take my laptop home from work tonight and try the same connection.
pwentz3l is offline
post #294 of 604 Old 07-22-2014, 06:46 AM
Tasdom's Avatar
Quoted: 156 Post(s)
Liked: 585
Talking
Originally Posted by Tasdom View Post
Anyone having HDMI handshake delays with their PJ? I'm using this 40' Redmere cable and sometimes it takes several minutes to detect a signal.
http://www.monoprice.com/Product?c_i...seq=1&format=2
Just a quick update,
After trying 2 more cables with the same results, the issue was in my Directv STB settings. I turned off the "native" setting and now switching is fast and wonderful!
Onkyo Pre/Pro PR-SC5508 & Emotiva XPA-5's x 2
Klipsch RF-7II's Mains RC64II Center RB75's Heights RS-7's Sides RS-52II's Rears
Klipsch RW-12D Subs x 2
Klipsch Belle's
OPPO BDP-105 with Roku Streaming Stick
Epson 6030UB / Vapex 120" Electric Tensioned Screen
Tasdom is offline
post #295 of 604 Old 07-23-2014, 11:45 AM
Liked: 0
Epson 6030 or SIM2 Crystal Cube?
Maybe this is a silly question, but can someone share some perspective on which one of these projectors to go for? I have been following and reading about the Epson for over six months and ready to make a purchase, but have recently been turned onto the Sim2 Cube. Any thoughts on this for those that have seen both projectors? Thanks,
mitchjlazar is offline
post #296 of 604 Old 07-23-2014, 10:28 PM
Nobody Special Member
Quoted: 88 Post(s)
Liked: 44
Not in the same league with the 6030! Just look at this review, neck just drop downto the conclusion and check out the comments as well!
http://www.audioholics.com/projector-reviews/sim2-crystal-cube
BamaDave is offline
post #297 of 604 Old 08-12-2014, 03:20 PM
thestoneman's Avatar
Quoted: 133 Post(s)
Liked: 49
I'm seeing light at the end of the tunnel as my build is looking to wrap up in the next few weeks. I'm a bit worried about committing to a mounting distance since I am ready to hang drywall next week.
I have a UH480 lens, 115" 2.35:1 screen at approx 13'-0". Does anyone think this will be a problem? Any further and it sticks out into a common area with pedestrian traffic.
My Theater Build
Equipment List: Denon X5200, Epson 6030, 120" Carada cinemascope screen, Panamorph U480, Oppo-103, Emotiva XPA-5, SVS PB12-NSD, LSA Statement LCR & surround speakers, Def Tech ProCinema 1000 rears, DefTech DI5.5R Atmos overheads, Grafik Eye 3106
thestoneman is offline
post #298 of 604 Old 08-18-2014, 07:23 PM
bill'sWS6's Avatar
Quoted: 12 Post(s)
New 6030UB Owner
I wanted to thank everyone in this thread for all the great posts. Especially the one giving info about Jason @ Integrated Tech Solutions. I just bought my new projector from him and can't wait to get it. It will be being paired with a SI Black Diamond Zero Edge screen between 110" and 120". I am moving literally and figuratively from my current set up. I am am having a new house built only about 600' from my current one with a totally open floor concept. The open living room/kitchen room measures about 37' deep X 23' wide. We had a pipe chase added to make it easier to pull wire to the projector. The installer is going to be using CAT 6 with short 3' HDMI's on the ends to run from the receiver to the projector. We also had 14 gauge wire pulled to the back wall for the rear speakers and out to the back screened in patio. On the end of the house with the bedrooms I did double layers of 5/8" drywall (ceilings too) and green glue on the walls and ceiling as well as insulation throughout the entire houses interior walls. I added solid core doors to all the bedrooms and did R38 bat insulation on the slopes of the 15' cathedral ceiling in the living room then had R50 blown in above the bats throughout the entire house to help with energy and sound. One of the most incredible views you could ever want out of the back of the house. Should make for a great viewing room.
The projector and screen should go well with my system:
Integra 40.4 Receiver
B&W 600 Series Towers
Dual B&W 12" Powered Subs
Panamax Surge M5300-PM
Playstation 3 For DVD Player
Screened In Patio:
Definitive Technologies All Weather Outdoor Speakers (AWESOME SOUND!!!!)
I am currently running a Epson 9700UB Pro Cinema for my projector and a 92" Stewart Grayhawk screen with Vluxe Border. The projector has only had one bulb run through it and I plan on putting it up for sale along with the screen.
Like I said, a big thanks to Jason at Integrated Tech Solutions. I highly recommend calling him if you are looking at an Epson projector a Black Diamond Screen or have questions. He is a wealth of information.
(908)219-9288
Now for the wait......I have my install scheduled for about two weeks from now.
Thanks Again!!!
bill'sWS6 is offline
post #299 of 604 Old 08-22-2014, 10:26 AM
milacqua's Avatar
Quoted: 77 Post(s)
Liked: 27
I'm getting my install on this projector next week. The video store has a good reputation so I think they know what they are doing. I got the installation paid for as part of an insurance settlement so I would rather they do it than me. The 6030 will replace a 6500ub that was fried in a lightning storm.
I have a couple questions. Will the mount that comes with this unit work on a slanted ceiling? The only pictures I have seen show a flat, straight up and down mount installation but I can't imagine there would be no adjustment for a cathedral type ceiling. Also, do you have any tips for me to ask the installers, things to look for, checks before they leave, etc. I know I can expect the picture to be centered and they should calibrate it somewhat although I do not expect and ISF job in this regard. I will look for convergence issues and dead pixels. Is there anything else I should do or have them test before they leave?
shortspark
milacqua is offline
post #300 of 604 Old 08-22-2014, 02:53 PM
Charles R's Avatar
Liked: 633
You can't post this without posting an image.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Sony UBP-X800 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Roku Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Epson Powerlite Pro Cinema 6020ub 3d 1080p 3lcd Projector , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition
