Official Epson Pro Cinema 6030UB Owners' Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 33Likes
Old 10-15-2014, 06:45 AM
rprice54's Avatar
Quoted: 92 Post(s)
Liked: 45
What do you mean by lag? For most users here, lag is the time it takes for the signal to get from the source to the screen. Usually not an issue except for fast paced games. Once it's on the screen, we're seeing the image. Are you referring to blurry motion?
I use mine for 90% sports and love it. Try some of the frame interpolation settings. When the ball goes left to right across a 50" screen it's traveling 42" on that screen. One a 100" screen it's moving closer to 90". With the same number of frames from the source you can get some motion blur (judder?). Frame interpolation makes up those in between frames to smooth it out.
I've watched football on a plasma and this PJ and can't tell a difference in smoothness.
rprice54 is offline
Old 10-15-2014, 11:26 AM
AlexanderDelarg's Avatar
Quoted: 151 Post(s)
Liked: 170
Originally Posted by Nappyface View Post
Do you have to change any settings to prevent lag? That's the reason I was going through this thread to begin with...thought maybe I had a setting or something off. I don't seem to notice it on regular programs but it is definitely noticeable while watching sports.
I have not done anything specific for sporting events - whether I am watching a blu ray, TV show, or a sporting event, my settings remain the same except for sports I switch from THX to living room mode for a brighter picture. I will have to check my FI setting to see what it is at..... I never change it however.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
Old 10-16-2014, 08:19 AM
Liked: 0
That sounds exactly what I was trying to describe by using "lag" - like I said I'm a novice when it comes to this stuff so my knowledge base is extremely limited and lacking proper terminology. I'll try to search how to adjust the frame interpolation settings and see if that helps.
Nappyface is offline
Old 10-16-2014, 11:02 PM
ericruff's Avatar
The Detail Enhancement Firmware Update has gone live at epson.com as of yesterday.
ericruff is offline
Old 10-16-2014, 11:25 PM
Tasdom's Avatar
Quoted: 153 Post(s)
Liked: 581
link? I'm not finding it
Onkyo Pre/Pro PR-SC5508 & Emotiva XPA-5's x 2
Klipsch RF-7II's Mains RC64II Center RB75's Heights RS-7's Sides RS-52II's Rears
Klipsch RW-12D Subs x 2
Klipsch Belle's x 4
OPPO BDP-105 with Roku Streaming Stick
Epson 6030UB / Vapex 120" Electric Tensioned Screen
Tasdom is offline
Old 10-17-2014, 04:09 AM
usualsuspects's Avatar
Quoted: 18 Post(s)
Liked: 30
New firmware for us/ca 4030/5030/6030's:
epson.com/detailenhancement (U.S.) or
epson.ca/detailenhancement (Canada)
Version shown on my 5030 (US) is now V111 - was V102.
Pretty easy to do the firmware upgrade - just follow the directions.
I'm not going to bother to post any new pics of what fast mode looks like on V111 - no point - it is unchanged - not improved.
Those with start problems might want to install this firmware to see if it fixes those issues.
usualsuspects is offline
Old 10-17-2014, 06:52 AM
Tasdom's Avatar
Quoted: 153 Post(s)
Liked: 581
Thanks for the links!
Klipsch Belle's x 4
Tasdom is offline
Old 10-17-2014, 09:57 AM
ericruff's Avatar
Sorry, I had the link for the firmware upgrade, but I haven't posted here before and newbies aren't allowed to post links or photos.
I'd be interested in anyone's opinion of the improvement in picture quality after the firmware upgrade. Is it worth writing home about? Also, I had my 6030 calibrated... will the firmware upgrade "undo" all that calibration? Thanks.
ericruff is offline
Old 10-17-2014, 10:03 AM
muad'dib's Avatar
Quoted: 145 Post(s)
Liked: 49
muad'dib is offline
Old 10-17-2014, 10:06 AM
muad'dib's Avatar
Quoted: 145 Post(s)
Liked: 49
I tried the enhancements and like☺
I found setting of 3 or less the best. Seems when going to 4 it gives white lines around things.
Should not need to recalibrate, as does not seem to affect colors etc.. As far as I can tell.
Maybe sharpness control could be adjusted, but I left mine where it was prior to new update
muad'dib is offline
Old 10-20-2014, 10:18 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Originally Posted by muad'dib View Post
Just downloaded it from your link to my laptop,.. when just trying to open the download I get a message:
"This file does not have a program associated with it for performing this action. Create an association in the Set Association control panel "
Is this normal because it's not connected to Projector ???
randyc1 is offline
Old 10-20-2014, 10:28 PM
muad'dib's Avatar
Quoted: 145 Post(s)
Liked: 49
Once you download the file and extract it. Copy file over to projector (it will have a drive letter when you plug usb into it and to computer.)
After its copied, in Windows eject the projector drive, then projector will start update..
I would first download the reader PDF for a more detailed instructions and photos
muad'dib is offline
Old 10-21-2014, 06:55 AM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 358
The download is simply a .bin file to be copied to the projector, there's nothing to "open" on your laptop (it's not even a .zip file). The same web page has a link to the instructions in a PDF file.
kriktsemaj99 is online now
Old 10-21-2014, 08:54 AM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
...Ok so it's normal that i was'nt able to open file without laptop connected tp PJ ?
randyc1 is offline
Old 10-21-2014, 11:38 AM
Quoted: 636 Post(s)
Liked: 358
^ you don't "open" the file even when the PJ is connected. i.e. don't double-click it expecting something to happen. Read the PDF and it tells you what to do.
Old 10-21-2014, 06:16 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Ok great , will try it tommorow, thanks
randyc1 is offline
Old 10-21-2014, 09:57 PM
starfyre's Avatar
Will be going to someone's home tomorrow to test the 6030. Specifically bringing a PS3, ps4 and Xbox one.
Want to test some games (resogun, USF4, and Killer Instinct) and see how it feels. We wanted this proj. until we heard of the input lag.
Our new # 1 choice is the Sony HW55ES since it's decent for movies/games apparenrtly, but still gotta try the 6030
maybe, since i'm not a very good player, i won't notice any delays/lag
Sanjay
starfyre is offline
Old 10-22-2014, 05:33 AM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
Projector Reviews (link below) has published an article on updating a 5030UB with the new firmware and the resulting image improvements.
http://www.projectorreviews.com/arti...0ube-and-4030/
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
Old 10-26-2014, 09:12 PM
rslavin2002's Avatar
just installed the new firmware...Now my projector is just as clear and crisp as my 60 inch lcd tv.I AM TOTALY AMAZED
AlexanderDelarg likes this.
rslavin2002 is offline
Old 10-26-2014, 11:05 PM
Nobody Special Member
BamaDave's Avatar
Quoted: 86 Post(s)
Liked: 44
Sound like its time to purchase a USB to mini USB!
BamaDave is offline
Old 10-28-2014, 02:59 PM
madmartigan10's Avatar
how do i know if the firmware is active on my projector now. Besides the firmware number changing, does anything else change in the menu system to let me know I have the right firmware.
I don't have my projector yet, getting it ordered and installed this week so I don't know how the old version looked vs the new update.
madmartigan10 is offline
Old 10-29-2014, 06:33 AM
Quoted: 636 Post(s)
Liked: 358
^ the firmware version number is all you need to check
Old 10-29-2014, 06:53 AM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
...Will the Darbee still be benificial after the Epson firmware update???
randyc1 is offline
Old 10-30-2014, 10:40 AM
thestoneman's Avatar
Quoted: 126 Post(s)
Liked: 48
I can't find the firmware download on the American site. I can't even find it on the Canadian site for that matter. How did you find the download? I just don't want to screw this up.
My Theater Build
Equipment List: Denon X5200, Epson 6030, 120" Carada cinemascope screen, Panamorph U480, Oppo-103, Emotiva XPA-5, SVS PB12-NSD, LSA Statement LCR & surround speakers, Def Tech ProCinema 1000 rears, DefTech DI5.5R Atmos overheads, Grafik Eye 3106
thestoneman is offline
Old 10-30-2014, 10:41 AM
Quoted: 126 Post(s)
Liked: 48
I've read that the firmware has a very "Darbee-esque" effect. I was planning on a Darbee, but I am going to refrain for now. One less potential handshake issue...
My Theater Build
Old 10-30-2014, 11:34 AM
flight planner's Avatar
Look at post # 369 for the link.
flight planner is offline
Old 10-30-2014, 07:47 PM
Liked: 1
Is the file you downloaded a zip file? If so that is the reason you are asked to choose a file for opening. I had a zip file and I had to unzip it when it became a.bin file which was then copied to the projector.
Quo Vadis is offline
Old 10-30-2014, 08:00 PM
Rokker's Avatar
Quoted: 27 Post(s)
Guys - quick question regarding panel alignment.
To me, the alignment looks good OOTB, so is the any reason to perform the adjustment? Or should I not tinker with it? In that regard, even if for future reference, could anyone provide me with a step-by-step of how to do the alignment process? Thanks in advance.
Rokker is offline
Old 10-31-2014, 09:21 PM
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
What size is the Mini usb side? or is there only one size ??
randyc1 is offline
Old 11-03-2014, 11:17 AM
Quoted: 126 Post(s)
Liked: 48
That link does work, but is it wise to use the link from the Canadian site? I want to do this safely (no offense to our Northern neighbors!)
UPDATE: Link for US site is below:
http://www.epson.com/cgi-bin/Store/support/supAdvice.jsp?type=highlights¬eoid=265501&ref=van _detailenhancement
My Theater Build
Epson Powerlite Pro Cinema 6020ub 3d 1080p 3lcd Projector , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition
