Official Epson Pro Cinema 6030UB Owners' Thread - Page 7 - AVS Forum
post #181 of 296 Old 03-19-2014, 01:22 PM
thethirdnut's Avatar
Samsung SSG-5100GB
I own + recommended in several threads.
thethirdnut is offline
post #182 of 296 Old 03-21-2014, 08:12 PM
James A. McGahee's Avatar
Originally Posted by DigitalGriffin View Post
The lens is the same as the 5030, the electronics are the same as the 5030. The panels are the same as the 5030. The firmware is different. The firmware allows you to expand your image vertically so that all the pixels are used on 2.35 content without the black bars. But to truly take advantage of this you
1) need a 2.35 aspect ratio screen
2) need a 2.35 lens adpater. These are $1000+ (Often called anamorphic lenses) ISCO II is a popular choice in the USA from what I read.
If you are asking what's the point there are 2:
With the 5030, if you want to watch a 2.35 movie (Default aspect ratio of most production movies), you'll get black bars top and bottom on a 16:9 screen
If you have a 2.35 Screen, and rezoom the picture by hand (quite annoying to do on the 5030), you'll waste unused light and pixels. (Approximately 32% dimmer and 32% fewer pixels) With the 6030 and 2.35 adapter lens, you'll use all that light and all the pixels.
However the 6030 comes with the extra warranty, an extra bulb, and the mount. That alone can add up to $900. Plus you get a black projector to boot.
I just started reading this thread. I recently purchsed the 6020UB. So far I really like it but haven't had time to get familiar with it.
I see above you mentioned a $1000 anamorphic lens from ISCO. How does it attach to the Chief's Epson projector mount that came with the 6020UB or does it attach directly to the projector lens? Epson recommends the Panamorph Anamorphic Lens Kit (Fixed) ELPFALKED
which is over $6000. How does the ISCO II attach and is it a fixed or movable lens. I believe with the 6020UP a fixed lens is preferable as it maintains CIH w/o having to be moved.
Thanks for any information you can give!!
James A. McGahee is offline
post #183 of 296 Old 03-21-2014, 08:29 PM
Originally Posted by ghiggs001 View Post
I do not have a 6030ub but I have a UH480 a-lens hooked up to a 6020UB, and I would say by the way they are saying that the 6030UB is relatively good, you should be a happy viewer.
By the way, has anyone seen a comparison between the 6020ub and the 6030ub?
I'm looking for a lens for my 6020UB. Where did you get yours, how much did it cost, and how does it attach? Does it attached to the Epson's ceiling mount and is the one you got fixed for moveable? I think a moveable les is not necessary with this projector. Can you verify that?
post #184 of 296 Old 03-22-2014, 07:42 AM
ghiggs001's Avatar
James:
I bought my Anamorphic lens a about 4 years ago. Do not remember exactly what I paid for the lens and the mounting plate but am very happy with it. My suggestion is that you call Panamorph and discuss your requirement. They are very helpful and informative. By the way, it is true that you will need a mounting bracket/plate for the lens which mounts between the projector and the Chief's mounting plate. The fixed lens track is less expensive than the motorized lens track, and it works just fine. Although it is called fixed you can still move the lens manually from side to side. I just leave mine in one position and only have to move it once to clean the projector lens. If your projector is mounted very high in the ceiling you can just attach a light chain/string to the lens so you can move the lens from side to side. You will not be disappointed with the combination of the A lens and the 2.40:1 screen. I use a 12ft x 5ft Stewart StudioTek 130 screen and I get very good brightness and quality with my system. I hope this help to answer your question.
ghiggs001 is offline
post #185 of 296 Old 03-26-2014, 12:18 AM
Does the "different firmware" which "allows you to expand your image vertically so that all the pixels are used on 2.35 content without the black bars." apply to the 6020UB which I have?
I was told the 6030UB is the current more recent model of 6020UB. I was told by a salesman at StarPower in Dallas that the 6030 is the latest version or update of the 6020 and that the only difference between the two is the newer 6030 has a small increase in white brightness. I do know that my 6020 has Anamorphic Wide and Horizontal Squeeze settings which I think allows you to go back and forth between 2.35 to 16.9 by simply clicking either setting on the remote and w/o moving the lens .
Can you confirm?
Also, does a "lens adapter" include the lens or is it an "adapter" which is attached to a separate lens?
I have a lens but am hung up on how to adapt it to my Chief Projector Mount.
post #186 of 296 Old 03-26-2014, 11:18 AM
ghiggs001's Avatar
Can you confirm?
Since you already have a "A" lens, I would suggest that you call the manufacture/brand name to get the mounting information you seek. The entire process of utilizing your "A" lens is not a major problem. You will just have to get the necessary adaptor.
post #187 of 296 Old 03-26-2014, 02:44 PM
Boots Rojas's Avatar
Originally Posted by tractng View Post
Can somebody pm about the price they paid shipped?
Ditto. I would definitely like to hear what this ended up being for you. Please PM.
Boots Rojas is offline
post #188 of 296 Old 03-26-2014, 06:38 PM
HTB from what I can tell is no longer in business.
post #189 of 296 Old 03-26-2014, 06:59 PM
Tasdom,
I really like your projector mount. Does it use the Chief mount that comes with the Epson you are using? I just purchased the 6020UB recently but haven't mounted it yet.
Do you know how an anamorphic lens would attach?
Who makes it and where do you get it?
How is the arm attached to the wall?
Thanks-
post #190 of 296 Old 03-26-2014, 07:15 PM
dlbeck's Avatar
Quoted: 22 Post(s)
Liked: 137
Tasdom,
Thanks-
James - I bought a Panamorph UH480, mounting plate and a manual sled. You also need the Chief universal mount. The one that came with the projector won't work with the Panamorph. Not sure about other a-lenses.
dlbeck is online now
post #191 of 296 Old 03-26-2014, 08:18 PM
Tasdom's Avatar
Quoted: 16 Post(s)
Liked: 430
Tasdom,
Thanks-
I bought it from Monoprice. I did not use the Chief that came with the 6030 since my ceilings are too tall and I didn't want to use a long extension to ceiling mount. The spider arms that are included with the monoprice mount are too short for the mounting holes on the 6030. I had another mount here that I had gotten from Vapex that had longer legs and used those with the monoprice mount.
The monoprice mount is rock solid and attaches to a wall plate with lag bolts.
https://www.monoprice.com/Product?c_id=109&cp_id=10911&cs_id=1091103&p_id=8804&seq=1&format=2
Robbed the arms from this one...
http://www.visualapex.com/accessories/accessory_details.asp?chPartNumber=AV-813U
8804_manual_111125.pdf 2087k .pdf file
9.2 System.....
Onkyo Pre/Pro PR-SC5508 Powered by Emotiva XPA-5 X 2
Klipsch RF-7II's Mains
Klipsch RC-64II Center
Klipsch RB-75s Heights
Klipsch RS-7's Side Surrounds
Klipsch RS-52II's Rear Surrounds
Klipsch RW-12D Subs x 2
Klipsch Belle's x 4
OPPO BDP-105 with Roku Streaming Stick
Epson 6030UB / Vapex 12...
Tasdom is offline
post #192 of 296 Old 03-27-2014, 05:15 PM
AubreyParker24's Avatar
hey everyone! Just got my Epson Pro Cinema 6030 today, all i got to do is unpack and install! I bought it from Cine Acoustic in Morris Plains, NJ, He is a great guy. I got it in two days, he even gave me free Apple TV with it.
Victor Parekh
Cine Acoustic LLC
email: victorparekh@yahoo.com
phone: 973-449-4861
Can't wait to show everyone once I install it, I'll be sure to keep you guys posted!
AubreyParker24 is offline
post #193 of 296 Old 03-27-2014, 06:34 PM
dlbeck's Avatar
Quoted: 22 Post(s)
Liked: 137
Wondering if anyone has more comments about the noise of the 6030? Mine will be about 4' overt head and a little nervous after reading some posts. I don't plan to watch much 3D. Thanks.
post #194 of 296 Old 03-27-2014, 07:09 PM
WestCDA's Avatar
Liked: 34
I've got the 5030UB - same fan, same noise level. It's 3 feet overhead for me, and I was delighted to find out when the projector arrived that high lamp fan noise doesn't bother me in the slightest - YMMV. Everyone has a different threshold, and this was a major concern of mine before purchasing. I read reviews that said the fan was louder than the competition in high lamp mode, but the noise pitch made it not obtrusive. I gambled on that, and found it to be exactly the case for me - the sound is a low pitched one of air moving, that ramps up somewhat with the faster fan speed.
Whether it's an issue for you or not depends on how sensitive you are, and to what types of sound. Low lamp is virtually silent.
WestCDA is online now
post #195 of 296 Old 03-27-2014, 07:29 PM
dlbeck's Avatar
Quoted: 22 Post(s)
Liked: 137
Thanks WestCDA. That helps a lot. With a 17' throw I'm sure I'll be running in high lamp mode. Sounds like the Sony 55 is a quieter.
post #196 of 296 Old 03-27-2014, 08:41 PM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 122 Post(s)
Liked: 341
Yes Sony 55 is definitely quieter.
Mike Garrett, AV Science Sales
Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI & many more.
Klipsch, RBH, Martin Logan, Triad, Atlantic Technology, MK Sound, BG Radia, SVS & Def Tech.
AV Science Sales 5 is online now
post #197 of 296 Old 03-27-2014, 11:00 PM
lapino's Avatar
My projector is pretty close to my head, and I have to admit I sometimes find the high lamp noise sometimes bothersome especially in silent scene. Watched gravity last night and zt the beginning when the earth is displayed showing its beauty the noise really took me out of it as it is supposed to be a moment of silence.
lapino is offline
post #198 of 296 Old 03-28-2014, 08:44 AM
AlexanderDelarg's Avatar
Liked: 41
That is my throw distance onto a 118" screen and I run ECO mode and the fan noise is a non factor.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #199 of 296 Old 03-28-2014, 08:46 AM
Liked: 41
Mine is directly over my head and I do not hear the fan noise, on ECO mode which is all that I use. I have the Iris set to high and hear that during quiet scenes, but not the fan.
post #200 of 296 Old 03-28-2014, 08:48 AM
Liked: 41
Victor Parekh
Cine Acoustic LLC
phone: 973-449-4861
Congrats. Welcome to the family. After running it around 100 hours consider having it professionally calibrated by an ISF qualified tech.
post #201 of 296 Old 03-28-2014, 12:15 PM
BamaDave's Avatar
Same here, don't let anyone have you thinking it is loud as is isn't.
BamaDave is offline
post #202 of 296 Old 03-28-2014, 06:23 PM
lapino's Avatar
it is very loud for me in normal mode but it might be a defect
lapino is offline
post #203 of 296 Old 03-29-2014, 08:41 PM
jme3192's Avatar
Found, i believe, is an excellent deal on this Pro projector ($2800 USD) from an online retailer in Canada. Anyone care to share their online experience?
jme3192 is offline
post #204 of 296 Old 03-31-2014, 03:48 AM
dlbeck's Avatar
Quoted: 22 Post(s)
Liked: 137
post #205 of 296 Old 04-03-2014, 03:39 PM
WynsWrld98's Avatar
Unless you have a high gain screen and/or small screen as the lamp ages you will likely need to switch to normal lamp mode then you will hear it unless all you watch is loud action movies...
WynsWrld98 is offline
post #206 of 296 Old 04-03-2014, 04:16 PM
TexasFred's Avatar
For aftermarket 3D to use with the 6030UB I agree that the Samsung SSG-5100GB's work. They are not as good as the 2 Epson's that come with the unit, but, they are definitely better than the Quantum G5's & N11's. The Quantum's had a little more "ghosting" & were blurry at times. The Samsung SSG-5100GB's have a little ghosting also, but, not much.
The Quantum's were rechargeable and had other nice features like auto-shut off after no signal for a few moments. The vendor for Quantum gave very good service and was helpful when I returned the glasses (3Dglassesunlimited). About $40 or so a pair.
The Samsungs are battery powered without auto-shutoff, but, only about $15 to $20 a pair.
TexasFred is offline
post #207 of 296 Old 04-04-2014, 09:53 AM
thestoneman's Avatar
To control fan noise, has anyone built a 3 sided box/enclosure in a ceiling hung configuration? I am thinking of building a box to deflect the fan noise.
My Theater Build
Equipment List: Epson 6030, Panamorph U480, Oppo-103, SVS PB12-NSD, LSA Statement LCR & surround speakers, Def Tech ProCinema 1000 rears & front heights, Grafik Eye 3106....more to come
thestoneman is offline
post #208 of 296 Old 04-04-2014, 02:29 PM
Charles R's Avatar
Liked: 167
This thread might help... http://www.avsforum.com/t/1495221/black-velvet-theater-project
He did something similar a while back.
Charles R is offline
post #209 of 296 Old 04-04-2014, 05:49 PM
WestCDA's Avatar
Liked: 34
If you are thinking of a box that is open on the front, it wouldn't do much in reducing the sound of the cooling fan - the intake and exhaust are both located on the front of the projector. Remember if you enclose it you'll need to ensure the heat generated has somewhere to go, and there is a source of cool air to replace it with. Do a search on 'hush box' and you should find lots of reading material ...
post #210 of 296 Old 04-05-2014, 08:59 AM
BamaDave's Avatar
Folks are making out like this unit is loud and I don't have that opinion as all. Heck, I have mine about 7' over my head and the sound isn't enough to build an enclosure.
BamaDave is offline
Epson Powerlite Pro Cinema 6020ub 3d 1080p 3lcd Projector , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition
