VPL-VW1000ES and HTPC at 4k (native rez) - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #1 of 261 Old 11-11-2013, 10:50 AM - Thread Starter
Supraman321's Avatar
I just got a new VPL-VW1000ES from AVS and I have to say fantastic projector and couldn't be happier with the purchase through AVS (top notch all the way smile.gif). One of the first things I did since I know it is one of the only ways for me to have an opportunity to get some native rez 4k content is to hook up my HTPC to it via HDMI, here are the specs:
OS Windows 8.1 (Driver is latest from AMD, beta 9.2)
- i7 2600k at 4.0ghz
- 8GB DDR3
-250GB Samsung EVO SSD
-AMD R9 290X 4GB
Direct connect to HDMI port on projector with High Speed HDMI v1.4a compatible cable. The OS "sees" the display as the VPL-VW1000ES and reports max rez as the native 4096 at 70hz but in the AMD Catalyst software settings it only lets me set "HDTV" settings for resolution up to a max of 1080p.
Has anyone gotten a connection from a PC to the VPL-VW1000ES to run at 4096x2160 at 24hz over the default non-upraded HDMI connections?
Thanks for any comments/assistance!
Supraman321 is offline
post #2 of 261 Old 11-11-2013, 12:55 PM
hifiaudio2's Avatar
Quoted: 425 Post(s)
Liked: 113
Yes I had it working at native 4k with a Radeon HD7950. It has been quite a while though since I had this hooked up. I don't recall any major hiccups, difficulties, or issues.
It should only be able to work at up to 24 (or maybe 30) hz though. Make sure you set it at that.
hifiaudio2 is offline
post #3 of 261 Old 11-11-2013, 01:01 PM - Thread Starter
Thanks. I might try my other machine that is running Win7 and a couple of GTX 780's then cause the options for resolution with the R9 290X don't even list anything above 1080p frown.gif so maybe it is something with that card I guess but it is brand new and advertised for its 4k prowess so I thought it was a safe bet.
post #4 of 261 Old 11-11-2013, 01:25 PM
hifiaudio2's Avatar
Quoted: 425 Post(s)
Liked: 113
Yeah I would think if the drivers for the 7950 worked then the 290x would have no issue. If those drivers are separate then maybe its just because they are new.
post #5 of 261 Old 11-11-2013, 01:55 PM - Thread Starter
Thought so too, I'll keep playing around with it though, thanks for the comments smile.gif.
post #6 of 261 Old 11-11-2013, 02:09 PM
zombie10k's Avatar
Quoted: 3870 Post(s)
Liked: 3951
I'm about to pick up a GTX 780 TI and try the same thing. Let us know if you get it work, I'd also like to see a few native 4K clips on the VW1000.
zombie10k is online now
post #7 of 261 Old 11-11-2013, 02:14 PM
Andreas21's Avatar
Quoted: 1133 Post(s)
Liked: 728
I have seen alot of native 4K material on the VW1000 and use a Radeon 7970 card with a Core i7 prosessor and 12 GB DDR3 Ram and it is no problem with native 4K, just make sure you play it from a fast harddrive and I prefer a fast SSD.smile.gif
Andreas21 is offline
post #8 of 261 Old 11-11-2013, 04:38 PM - Thread Starter
Yeah, little bothered why the 290X won't do it without any issue but we'll see, I've got a little "tweakin" to do though before I give up and go to the GTX 780 SLI rig. That one is a little heavy for me to want carry to the projector and I'll need to get to epic frustration levels to go move that monster wink.gif.
BTW, was there any special selections you had to make with the 7970 or was it plug and go to the rez selection and just choose the native?
post #9 of 261 Old 11-11-2013, 05:13 PM
Andreas21's Avatar
Liked: 728
post #10 of 261 Old 11-12-2013, 03:54 AM
yuettoi's Avatar
I tried once with ny PC, DELL XPS8500, i7-3770, 16GB ram, Radeon 7870.
So far so good.
yuettoi is offline
post #11 of 261 Old 11-12-2013, 06:33 AM
R-o-c's Avatar
You Must deactivate gpu scaling in catalyst . Change the refresh rate And so @right click windows desktop.
refresh Rate @23 Hz this is for blu Ray
Deactivate all color And Video Extras im catalyst
Greetz from germany
R-o-c is offline
post #12 of 261 Old 11-12-2013, 08:18 AM - Thread Starter
Yeah, I think I'm sensing a pattern here. I tried my other PC with the GTX 780s and Windows 7 just to isolate the OS/settings on the HTPC with the 290x and no joy there either. My long HDMI run to the projector is a bit of an older cable from Monoprice that is pretty generic so I may have overestimated its spec I'm thinking. I have a new one incoming that I'm going to give a shot and see if my hunch is right but so far neither PC gives me an option to chose anything above 1080p.
post #13 of 261 Old 11-12-2013, 01:58 PM - Thread Starter
Anyone that has it working care to share the brand of HDMI cable they are using, just want to be sure I eliminate every anomaly. I have generic mostly HDMI cables all labeled as high-speed and tried one of those with a direct connect to the projector with no luck. I know it shouldn't matter as long as it is high speed but I'd like to just go with something known good smile.gif.
post #14 of 261 Old 11-12-2013, 02:03 PM
hifiaudio2's Avatar
Quoted: 425 Post(s)
Liked: 113
post #15 of 261 Old 11-12-2013, 02:07 PM - Thread Starter
post #16 of 261 Old 11-13-2013, 12:36 AM
Elix's Avatar
Quoted: 238 Post(s)
Liked: 104
When will we see 40-bit color depth option in Windows, I wonder (30-bit color + 10-bit alpha channel)? We have 32-bit since Windows 95.
Elix is offline
post #17 of 261 Old 11-13-2013, 05:36 AM
yuettoi's Avatar
My cable is Wireworld Series 5.2 HDMI Silver Starlight, "HDMI Ver.1.3b Cat.2 " in 2008.
yuettoi is offline
post #18 of 261 Old 11-13-2013, 06:16 AM
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
Nice to see this got a separate thread.
I m also using my HTPC with my VW1000. Just because it is so cool to go to the information in the Sony menu and see there that it is getting a 4K signal! smile.gif
Serious, my HTPC letting doing the upscaling is far superior to internal 2K=>4K upscaling of the Sony. Remember to put the Reality Creation in the VW1000 completely OFF when feeding it with a native 4K signal!!
I m using a HD7970 and I use madVR as upscaler. My CPU+GPU can handle JINC3+AR which is the best upscaling possibility that madVR has but also the most heavy one. What I did notice is that some options are not available anymore on the VW1000 when feeding it with a native 4K signal. FI is not available anymore which is quite disappointing. But I prefer my HTPC upscaling for now and I m willing to give up motion flow on the VW1000 for this.
Any idea where to find some good native 4K material?
sanderdvd is offline
post #19 of 261 Old 11-13-2013, 07:04 AM
hifiaudio2's Avatar
Quoted: 425 Post(s)
Liked: 113
You guys are making me want to break out the HTPC again and give this a go. Sanderdvd, is there an updated madVR guide that covers new methods like JINC3+AR? I have been out of HTPC long enough to have not heard of JINC3+AR yet until I just started researching it after your mention.
post #20 of 261 Old 11-13-2013, 08:12 AM
tr402m's Avatar
Just compared upscaling in JRiver (Red October HQ) and internal VW1000ES and have to agree, JRiver doing it much better!
The only problem is with fast moving scenes, SONYs "Motion Enhancer" which does not work in 4K plays much smoother.
Does anyone know if that is fixed in HDMI 2.0 upgrade of this projector?
The good thing would be If that feature will work in 4K or probably upscaling and output in 4Kp60 will help.
Also, would it accept 1080p120 for 3D gaming?
Thinking about ordering Nvidia 780Ti's but there is still no info if it is ready for HDMI 2.0 andthat is  just a matter of drivers...
tr402m is offline
post #21 of 261 Old 11-13-2013, 08:54 AM
zombie10k's Avatar
Liked: 3951
I just picked up a GTX-780 Ti today for my Shuttle SFF (I7, 32 GB ram, 512 OCZ SSD). Can you post some info about this configuration? I'd like to try the HTPC vs the built in scaling. I'm finding that the RC is too overcooked even at minimum setting. We're trying to find out if this will change with the upcoming motherboard upgrade. thanks!!
post #22 of 261 Old 11-13-2013, 09:16 AM
tr402m's Avatar
It is very easy, just download JRiver (www.jriver.com), set native resoluton of the screen to  4K @ 23hz, go to JRiver Video settings, set Red October HQ in there and hardware acceleration marks. Then just start your bluray movie. You can pause it then, change resolution to 1080P and compare!
tr402m is offline
post #23 of 261 Old 11-14-2013, 10:11 AM - Thread Starter
Got it working but needed a new cable and couldn't go through my receiver. Also, had to turn off GPU scaling (apparently was on). Thanks for all the suggestions smile.gif. I also tried Jriver and it is a pretty cool app but for some reason it would recognize my blu-rays when they were in the PC drive which is a Blu-ray drive but wouldn't actually play a movie for some reason, just a black screen, ah well.
post #24 of 261 Old 11-14-2013, 10:48 AM
zombie10k's Avatar
Liked: 3951
you will likely need ANYDVDHD to strip the protection before it will play.
I tried a number of un-protected ISO's last night (right click ISO, mount with windows 8 built in command) and was able to play them through jriver.
I have some good info to post later with the setup I ran last night.
post #25 of 261 Old 11-15-2013, 02:09 AM
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
I ve compared it to madVRs JINC3+AR alogorithm and madVR outperforms Jrivers upscaling by miles. But you need a BIG cpu+gpu combo for madVRs JINC3+AR
post #26 of 261 Old 11-15-2013, 06:03 AM
hifiaudio2's Avatar
Quoted: 425 Post(s)
Liked: 113
Is the HD7950 sufficient? Are you using XBMC or MPC-HC as the player? Would you mind sharing your settings? MadVR has so many its incredibly confusing.
post #27 of 261 Old 11-15-2013, 06:22 AM
rcohen's Avatar
Quoted: 1401 Post(s)
Liked: 630
I read somewhere that you needed an HD7970 for 4k.
rcohen is offline
post #28 of 261 Old 11-15-2013, 06:43 AM
zombie10k's Avatar
Liked: 3951
Can you please post details of your software configuration? I have an i7 with 32 GB and the new 780 GTX Ti, can't get much bigger than that... smile.gif
post #29 of 261 Old 11-15-2013, 09:01 AM
hifiaudio2's Avatar
Quoted: 425 Post(s)
Liked: 113
If you install Jriver and tell it to use Red October HQ, it uses madVR. BUT... does it let you configure madVR to use JINC3+AR, etc? I tried to setup MPC-HC to use madVR and even though I installed madVR and registered the filters, MPC-HC still says the madVR renderer is "unavailable". Edit - nevermind.. I did not realize I could not use the 64bit version of MPC as it is incompatible with MadVR. Switched to 32 bit MPC and MadVR loads.
FYI I found a nice program that lets you download 4k videos from Youtube so you don't have to worry about streaming them. http://www.4kdownload.com/howto/howto-download-4k-video
post #30 of 261 Old 11-15-2013, 10:01 AM
Kevin 3000's Avatar
Quoted: 126 Post(s)
Liked: 32
Kevin 3000 is offline
Sony Vpl Vw1000es Projector
