Ceiling mount for Sony HW55ES? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-11-2013, 09:25 PM - Thread Starter
JeffK's Avatar
I've pretty much settled on the Sony HW55ES for a projector, it will be ceiling mounted about 14' from the 120" diagonal 16:9 screen. Can anyone suggest a nice ceiling mount for it? Also, the ceiling is still open, and I've run HDMI, Cat6 and conduit to the area in the ceiling. I'd like to figure out which mount to get this week so that I can make sure to add blocking (before the ceiling gets drywalled next monday) and such so that it can be mounted very securely. I'd like to hide the wires as best as possible too. The electrician is installing an outlet in the ceiling, so I'll try and have that put as close to the mount as possible and then use a short power cable to "hide" that as best as possible.
JeffK is offline
post #2 of 3 Old 11-12-2013, 04:07 AM
Aaronh's Avatar
Liked: 31
I'm planning on using the Peerless PRG-UNV. The Chief mount is also widely recommended (RPA 020 - I think).
Aaronh is offline
post #3 of 3 Old 01-23-2014, 10:00 AM
MadDod's Avatar
Is anyone using the Emmy HA717 mount? I'm having a hard time getting all 3 mount holes to line up with the plate, and the arms don't seem to help. Would appreciate any ideas or pictures of other people's mounts.
Mike
MadDod is offline
Sony Vpl Hw55es 3d Projector , Peerless Prg Mount
