Owners thread Sony Hw55ES - Page 47 - AVS Forum
 8Likes
post #1381 of 1399 Old 09-24-2014, 07:44 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 362 Post(s)
Liked: 418
Originally Posted by AdamAttewell View Post
Just shocks me that my Benq W1070 projected a perfect square image but the Sony at over twice its price can't.
The shorter throw range of the 1070 helps in this regard.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Brands we sell:
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon & many more.
RBH, Martin Logan, Triad, Atlantic Technology, MK Sound, BG Radia, SVS & Def Tech.
AV Science Sales 5 is online now
post #1382 of 1399 Old 09-24-2014, 08:20 AM
Craig Peer's Avatar
Location: In my home theater ( when I'm not rock climbing, cycling or kayaking ) - Sacramento CA area
Quoted: 208 Post(s)
Liked: 271
It might not be 100% perfectly level and square to the screen. I can get that same effect with my Sim Lumis - and that projector has a great lens. It doesn't take being off by much to cause that.
Craig Peer, AV Science Sales. Direct Line - 585-671-2972
I'm available 8:30am - 4:30pm PST, Monday - Friday Email me at
Yes, we sell Home Theater gear right here at AVS !!
JVC, Sony, Epson, DPI, SV Sound, Martin Logan, RBH, Klipsch, and many more!
Craig Peer is offline
post #1383 of 1399 Old 09-24-2014, 08:24 AM
Liked: 0
So will having the zoom near its limits affect how much bow is present is the image?
I took the projector back to the dealer and he set it up and the bow was present, he then setup an epson 5030ub and the image was square.
That projector has an even bigger throw range than the sony.
AdamAttewell is offline
post #1384 of 1399 Old 09-24-2014, 09:48 AM
AVS Club Gold
Quoted: 362 Post(s)
Liked: 418
Near the limits of the lens shift can make a difference. As I said earlier, it is the lens. You just have to decide if everything else is good enough to make you want to live with this bowing or exchange. My brother has an older Sony and it is bowed slightly at the bottom. The image sharpness and uniformity was so good on the projector, compared to others he had seen, that he decided to keep it. He just enlarged the image slightly, so that the bow, is lost in the black velvet border.
Email Me:
Brands we sell:
post #1385 of 1399 Old 09-24-2014, 07:42 PM
Skrill's Avatar
Quoted: 87 Post(s)
Liked: 35
I did a search of this thread and found nothing useful on it.
Can someone tell me what "Contrast Enhancer" does in the advanced menu settings?
Also -- while asking questions -- I would love to know that the difference gamma adjustment settings mean. I can tell what looks good -- but I would love to know that "off", 2.2, 2.4, Gamma 8, etc., refer to.
CT
_____________________________________________
Skrill is offline
post #1386 of 1399 Old 09-25-2014, 02:14 AM
Fishhooks's Avatar
Like some of the posted photographs, (Post 1237) I need to have my "55" fairly close to the rear wall at the projector position. This would be whether it was table or ceiling mounted.
The Instruction Manual states a minimum space of 30cm at the projector rear as the air intake is obviously here.
In the case of table mounting, with "clear space" of more than 2 metres at each side and more than 1 metre above, would a space of around 20cm be too close to the wall?
Fishhooks is offline
post #1387 of 1399 Old 09-25-2014, 06:47 AM
Liked: 0
Can you measure the amount of bow you have seen from the screen edge to the top the image.
Its just when I watch a film in 2.40:1 I can see the bottom of the image is bowed also when a ticker is on the bottom of the screen this also has a bow to it.
So its not just the edge of the image that is not straight but it is also distorting the bottom portion of the image aswell.
Is this normal? I have 1cm of bow from the top of the screen to the top of the image.
post #1388 of 1399 Old 09-25-2014, 06:49 AM
AVS Club Gold
Quoted: 362 Post(s)
Liked: 418
What size screen do you have? Are you saying the top of the ticker (at bottom of screen) is bowed or just the bottom of the ticker is bowed?
Email Me:
Brands we sell:
post #1389 of 1399 Old 09-25-2014, 07:07 AM
Liked: 0
My screen size in 110" diagonal
Well the bow changes from top to bottom depending on the orentation of the projector.
So if ceiling mounted it is at the bottom, if on a table its at the top.
The ticker just bows upward.
Here is some pictures:
http://postimg.org/gallery/hq38oiwo/11240701/
post #1390 of 1399 Old 09-25-2014, 11:31 AM
AVS Club Gold
Quoted: 362 Post(s)
Liked: 418
Okay, so it is not bowing the entire image, just the bottom of the image or top, depending on orientation of the projector. The problem is the lens, not the screen. You just have to decide if you want to overshoot 3/8" or exchange. If everything else about the projector is real good, I would consider keeping, because while you could get one that does not have the bowing, it could have lower sharpness or lower focus uniformity. If it has other problems, I would see about an exchange.
Email Me:
Brands we sell:
post #1391 of 1399 Old 09-25-2014, 01:33 PM
Liked: 0
This being my first high end projector I have no idea what to look for with sharpness, convergence and focus uniformity.
The bow is something I can see but I have been I discussion with Sony prime support and they can't tell me from pictures if the bow is "within limits" to not.
So I will need to send it away to them, so they can test it.
post #1392 of 1399 Old 09-25-2014, 01:47 PM
AVS Club Gold
Quoted: 362 Post(s)
Liked: 418
Put a static image or test pattern up and if the sharpness is the same all across the screen, then you are good there. Put up a convergence test pattern and see how well the colors match up, from viewing distance. If both of those items look good, then I would probably not mess with sending it in.
Email Me:
Brands we sell:
post #1393 of 1399 Old 09-25-2014, 07:07 PM
Fishhooks's Avatar
This 3D package is what comes as standard with a VPL-HW55 Projector purchased from an authorized Sony Dealer in Australia.
My initial delivery was missing the small adapter cable, probably by mistake and the dealer certainly made it instantly available when I contacted them. Can't imagine it's cost should be anywhere near $75!
I think I read somewhere that VPL-HW55's in some parts of the world also are packaged with a voucher for a new lamp. Here in Australia you only get a voucher for a $100 discount on your next lamp if purchased from a Sony Dealer.
Would also appreciate some feedback on the clear space some of you have behind the projector, to a wall, where of course the main air-intake is.
The manual states 30cm, I think I can only manage about 20cm, but the space at the top and sides is more than 1 metre, certainly at the sides several metres!
post #1394 of 1399 Old 09-26-2014, 11:33 AM
Liked: 0
Thanks for all your help and time I will have a good look at the PQ over this weekend, will see if I can put up with the distortion.
Does annoy me the bottom of movies are bowed.
post #1395 of 1399 Old 09-26-2014, 12:26 PM
AVS Club Gold
Quoted: 362 Post(s)
Liked: 418
Make the image slightly larger, so that it overshoots the bottom of the velvet covered screen frame by 3/8" and you will soon forget about it. Do this by making it 3/16" bigger top and bottom and lens shifting it down 3/16". Then it is hidden.
Email Me:
Brands we sell:
post #1396 of 1399 Old 09-28-2014, 02:21 PM
Liked: 0
may I ask how good the hw55es' 3d performance is (crosstalk/ghosting etc.). "I'm between" the hw55es and the Epson 9200/5030 but it's a pretty hard decision to me. Unfortunately at my place I have no dealer to compare them or check them out. Epson has a 120hz technology for 3d, but according to Sony the hw55es supports 120hz, too. I'm pretty confused and I don't know which one I should buy. Sony's advantage is the sxrd technology and the epson is better in 3d like people say because of the 120hz. How is it possible to reach these 120hz for 3d for the sony hw55es? (remember I said sony said the hw55es supports it)
Shaq is offline
post #1397 of 1399 Old 09-28-2014, 06:06 PM
Liked: 0
What do people recommend for settings with reality creation and noise reduction with movies.
Been told 20 on resolution but no one has recommended a setting for noise reduction.
post #1398 of 1399 Old Yesterday, 05:55 PM
sethk's Avatar
CT
Contrast enhancer, as the name implies, looks at the luminance content of the image and tries to push out the darker and lighter elements of the frame to 'increase contrast'. In some content it may be fine, but it can also crush out darks / highlights in some other content.
Gamma is the luminance curve, or how quickly successive luminance levels are mapped to various brightness levels. It is most noticeable in night / dark scenes where you can see various shades of very dark colors which still maintaining deep blacks. The higher the number ('2.4', etc.) the darker the picture looks, and the lower the number the less dark grays, and deep browns look. Depending on how light controlled your theater is, the lower your gamma curve can be, which still keeping the content viewable. Typically, you see values between 2.2 - 2.4 for modern displays in most environments, but this is ideally figured out during calibration. Here's a link for your perusal.
sethk is offline
post #1399 of 1399 Old Yesterday, 07:49 PM
Skrill's Avatar
Quoted: 87 Post(s)
Liked: 35
Thank you for the assistance. Very helpful.
Couple of follow up questions if I may:
1. I understand what gamma does now -- what does it mean if gamma is in the "off" setting in our 55ES projectors?
2. Our projectors seem to have two types of gamma values. One set is the 2.2, 2.4, etc. That I now understand. The other set is Gamma 8, Gamma 9, etc. How do the two relate?
Thank you again!
CT
Skrill is offline
Sony , Sony Vpl Hw55es 3d Projector
User Tag List
