Owners thread Sony Hw55ES - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 132Likes
post #1441 of 2782 Old 10-11-2014, 06:15 AM
Jruc03's Avatar
Quoted: 13 Post(s)
Originally Posted by AV Science Sales 5 View Post
If you bought it from an authorized dealer, you need to contact them.
I contacted them and they are getting back with me as they said it should have been in the box. They may have to contact Sony they said.
Jruc03 is offline
post #1442 of 2782 Old 10-13-2014, 07:26 PM
yash's Avatar
I am interested in knowing if anyone on the forum is using the IR IN of this projector to control it and if so what IR receiver they are using. I have this projector ceiling mounted and am looking for a way to control it with IR signals coming from the back of the projector. I tried the Monoprice 5-Feet IR Extender Cable Receiver (108060) without any luck but this same IR receiver works fine with my Verizon Fios STB and is able to control it. Any ideas?
yash is offline
post #1443 of 2782 Old 10-16-2014, 10:18 AM
jidelite's Avatar
Quoted: 41 Post(s)
I had problems with my IR IN to the point that I knew there was something wrong with the projector but decided it wasn't worth taking it down (ceiling mounted) and sending it to Sony since I was going to use RS232 anyway. Hope you have better luck than me finding a solution...
jidelite
jidelite is offline
post #1444 of 2782 Old 10-16-2014, 03:27 PM
yash's Avatar
jidelite
Thanks for the response. I called the Sony support line and the tech said that any IR receiver should work but didn't know why the Monoprice one does not work with the projector. He was also unable to recommend any receivers that are known to work with it.
yash is offline
post #1445 of 2782 Old 10-17-2014, 12:05 PM
jamesvicky's Avatar
Quoted: 29 Post(s)
For what it's worth I got a monoprice one and it doesn't work in mine either, and nor does it work in my anthem receiver either
jamesvicky is offline
post #1446 of 2782 Old 10-17-2014, 01:03 PM
dw886's Avatar
Quoted: 13 Post(s)
I've played around with a number of Monoprice IR units. The 108060 is the same unit that comes with their HDMI over CAT6 wallplate, and it's only single band IR (meaning it won't work with all remotes / devices).
The IR receiver that comes with their IR Repeater (9895) seems to work with everything that I've plugged it into. I don't have the Sony projector (yet - theater is still under construction, so it'll be a few more weeks), but I'd be willing to bet if you pulled the IR Receiver out of the box that comes with the 9895 unit, it would work, and the 108060 won't because the band of IR for the projector isn't covered in the 108060.
Whenever I use one of their HDMI over Cat5/Cat6 wall plates, I throw away the IR receiver (same as the 108060 unit), and use one from the 9895 instead...YMMV of course with the projector, but if I were to bet...I'd say it would work there as well.
dw886 is offline
post #1447 of 2782 Old 10-17-2014, 10:22 PM
yash's Avatar
Thanks for the info. Do you know the type of connector on the IR receiver? HW55ES expects mini jack for the IR in. It was not clear from the manual for the unit though it looked like a mini jack. Anyway at that price I am thinking of ordering one since even if the IR in does not work I can still use the unit itself to relay the signals to the IR sensor in the front of the projector.
yash is offline
post #1448 of 2782 Old 10-19-2014, 04:53 AM
Mike Garrett's Avatar
Quoted: 6367 Post(s)
Liked: 4116
Sony sale on models HW40ES and HW55ES. Sale starts today, Sunday the 19th and goes to the end of the month. Call us for details. If anybody was considering one of these projectors, now is the time.
mjgarrett100@gmail.com
Mike Garrett is offline
post #1449 of 2782 Old 10-20-2014, 07:00 PM
qwerty_88's Avatar
Quoted: 72 Post(s)
Will the Sony HW55ES be better than an old JVC (RS55 / X70)? I'm torn between the two right now they're being offered to me for the same price.
qwerty_88 is offline
post #1450 of 2782 Old 10-21-2014, 11:29 AM
Jruc03's Avatar
Quoted: 13 Post(s)
I have calibrated mine to the best of my ability but after messing with some of the extra settings I do like the picture better with the cinema black pro lamp brightness on the low setting but whenever I use it and a scene in a movie comes on with a bright image I see a lot of flickering in the brightness. Is this normal and or has anyone been able to calibrate it out?
Jruc03 is offline
post #1451 of 2782 Old 10-21-2014, 04:55 PM
Buurke's Avatar
Check if "Film Projection" in the Motionflow menu is set to "Off".
Buurke is offline
post #1452 of 2782 Old 10-21-2014, 06:06 PM
Jruc03's Avatar
Quoted: 13 Post(s)
I did check this to be sure it was off, it does create a similar effect but its not quite as noticeable as the flicker i'm seeing and its only in lighter scenes.
Jruc03 is offline
post #1453 of 2782 Old 10-22-2014, 06:28 AM
cemo62's Avatar
Quoted: 49 Post(s)
Use it in high lamp mode for 5-6 hours and then back to low lamp
cemo62 is offline
post #1454 of 2782 Old 10-22-2014, 10:57 AM
Jruc03's Avatar
Quoted: 13 Post(s)
I have used it in high for about 40hrs already and it still reverts right back to flickering. I'll play around with the calibration again to see if I can get rid of it.
Jruc03 is offline
post #1455 of 2782 Old 10-22-2014, 06:27 PM
Quoted: 27 Post(s)
Liked: 0
Mike: Can you send me a PM on the sale price of the 55ES? Thanks.
jasenkent is offline
post #1456 of 2782 Old 10-22-2014, 07:27 PM
Liked: 4116
Sent you a PM.
post #1457 of 2782 Old 10-22-2014, 10:04 PM
khactuyen's Avatar
Quoted: 27 Post(s)
Send a message via Yahoo to khactuyen
Sent you a PM.
and me, thanks.
khactuyen is offline
post #1458 of 2782 Old 10-23-2014, 05:41 PM
Quoted: 225 Post(s)
Liked: 53
Just been watching IMAX Hubble in 3D and randomly the video signal keeps dropping and comes back the glasses lose sync when the video comes back on they sync back up.
I can always hear audio just the video goes and comes back, only goes for a second or two.
I am using a PS3 for my bluray player and going through a Yamaha RXV-675.
Some times the picture flickers and I get two white lines at the top of the image it's like it losing sync or something.
Any ideas?
AdamAttewell is offline
post #1459 of 2782 Old 10-23-2014, 09:32 PM
Liked: 4116
Any ideas?
What HDMI cable are you using?
What is your throw distance?
What is your viewing distance?
What screen are you using?
post #1460 of 2782 Old 10-23-2014, 10:27 PM
tmavs's Avatar
Does the signal drop while watching a 2D movie?
tmavs is offline
post #1461 of 2782 Old 10-24-2014, 02:47 AM
Quoted: 225 Post(s)
Liked: 53
I am using the chord company HDMI cables.
2D is fine never drops out, going to try and watch Pacific rim tonight see if I get the same result.
post #1462 of 2782 Old 10-24-2014, 06:16 AM
Liked: 4116
If 2D never drops out and 3D does, then it is the HDMI cable. When I say drop out, I mean, no picture on the screen. If the glasses are losing sync, then you may have too much total distance, as in projector to screen, to viewer. You can correct this by getting the external emitter and placing near the front of the theater or go to RF. That is why I asked you all those questions. Also need to know specific HDMI cable, not just manufacturer.
post #1463 of 2782 Old 10-26-2014, 05:46 AM
Liked: 4116
Just a reminder, this week is the last week for the Sony sale. Sale ends at the end of this month. Call for details.
post #1464 of 2782 Old 10-26-2014, 04:01 PM
Jive Turkey's Avatar
Quoted: 257 Post(s)
Liked: 150
Crap. Wished I had held out a bit longer before buying mine from you guys. I'm a very "thrifty" oriented fellow.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #1465 of 2782 Old 10-26-2014, 06:13 PM
Mr Ian B's Avatar
Quoted: 53 Post(s)
Liked: 46
Just reached 1,000 hours last night. Totally satisfied, no issues, image as bright as day one. Only had it for 10 months now. I use it as my primary TV at home w 3-4 hours daily on.
Ian B
Mr Ian B is offline
post #1466 of 2782 Old 10-26-2014, 06:42 PM
Liked: 4116
As soon as we heard a sale was coming, we told all customers that called in for pricing. Would not feel right selling at regular price, knowing a sale was coming.
nathan_h likes this.
post #1467 of 2782 Old 10-27-2014, 02:34 AM
khactuyen's Avatar
Quoted: 27 Post(s)
Ian B
Hello, The PJ in high or low lamp mode? can you post your calibrated setting? thanks.
post #1468 of 2782 Old 10-27-2014, 07:21 AM
Quoted: 257 Post(s)
Liked: 150
I shouldn't whine, and I apologize for doing so. I got a good price and the free lamp deal when I bought My 55ES from AVS. I also got a good deal on a Denon 5200 last week.
Honestly, the 55ES is worth full retail if one had to pay it.
See ya. Dave
post #1469 of 2782 Old 10-27-2014, 08:43 AM
Liked: 4116
No problem. Like everyone else, this has happened to me also.
post #1470 of 2782 Old 10-27-2014, 01:20 PM
freddy202022's Avatar
Quoted: 31 Post(s)
Sony Hw55ES special pricing ? I go the Epson 5030 but its too loud and I just returned it, but realized my mount wont work with the new Sony, what kind of ceiling mounts are you guys using ?
freddy202022 is offline
Sony , Sony Vpl Hw55es 3d Projector
