Owners thread Sony Hw55ES - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 132Likes
post #1891 of 2785 Old 04-24-2015, 04:51 AM
gnolivos's Avatar
Quoted: 361 Post(s)
Liked: 285
Originally Posted by ultra 150 pilot View Post
If the panels are that misaligned then you should have the unit swapped out!
Why not rely on digital alignment? Can you qualify your statement? Thanks!
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #1892 of 2785 Old 04-24-2015, 05:16 AM
ultra 150 pilot's Avatar
Quoted: 84 Post(s)
Liked: 43
You can only compensate a little with the software,if the unit is that badly out of alignment needs to be swapped out
I had a 55es for a while and the unit seemed to be very sharp compared to the jvc 4910 and epson 6030.
ultra 150 pilot is offline
post #1893 of 2785 Old 04-24-2015, 05:24 AM
Quoted: 84 Post(s)
Liked: 43
I'm not saying it won't help, certainly try it, all I'm saying is that it really shouldn't be soft it all out of the box.
post #1894 of 2785 Old 04-24-2015, 06:44 AM
Quoted: 1176 Post(s)
Liked: 667
With panel alignment you want to use whole pixels and get it within a 1/2 pixel. Many of the alignment systems use two pixels to make one. They vary the light between the two pixels so you have something like 10 increments of convergence for one pixel of adjustment. When using this method of varying the light between two pixels to get perfect alignment you are often giving up sharpness/ resolution and it is better to move it in whole pixels and get it as close as possible. You should be able to get it less than half of a pixel offset using whole pixels but don't expect perfection. This will help with sharpness/resolution. I use a magnifying glass when making pixel and level adjustments so I can see exactly where the pixels are located how the convergence is working. 3 pixels off is quite a bit and the unit might need replacement.
Ellebob is offline
post #1895 of 2785 Old 04-24-2015, 12:27 PM
gnolivos's Avatar
Quoted: 361 Post(s)
Liked: 285
I'm not sure Im counting pixels correctly... actually the image does not throw that much of a clear pixel structure, no matter how focused I get the projector. It's probably off by at least 1 pixel, and in some cases I see more than that.
Here are a few pictures:
These are taken with Pixel Alignment OFF, factory default.
The LAST image shows what it looks like when I adjust the panels, it seems to mess up the color balance on the left side...
gnolivos is offline
post #1896 of 2785 Old 04-24-2015, 03:36 PM
Liked: 667
That is more than a convergence problem. I would return it and get another one.
Ellebob is offline
post #1897 of 2785 Old 04-27-2015, 11:56 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3782 Post(s)
Liked: 3771
That is exactly what we are doing - there is something wrong with that projector.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #1898 of 2785 Old 04-27-2015, 12:47 PM
Quoted: 84 Post(s)
Liked: 43
Nice!,
Hopefully when he gets his new he will come back on say how much he loves it
post #1899 of 2785 Old 04-27-2015, 12:53 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3771
Nice!,
Who knows - could have been shipping damage. We do our best to make things right. That's why I went from being a customer of AV Science to working here !
post #1900 of 2785 Old 04-27-2015, 01:13 PM
gnolivos's Avatar
Quoted: 361 Post(s)
Liked: 285
Let me just take the opportunity to say, dealing with Craig @avscience has been fantastic. Very responsive, professional and accommodating. I could not be happier with the level of service provided and will undoubtedly deal with again. Now fingers crossed that the replacement works out for me.
gnolivos is offline
post #1901 of 2785 Old 04-30-2015, 02:20 PM
gnolivos's Avatar
Quoted: 361 Post(s)
Liked: 285
Question for all owners in this thread. Would you say that the HW 55 image is softer than your previous 1080 P projectors? I am finding the image extremely soft, almost out of focus, unless I enable RC. This is happening on the second unit that I have received, as well as the original one.
gnolivos is offline
post #1902 of 2785 Old 04-30-2015, 04:52 PM
Mike Garrett's Avatar
Quoted: 6606 Post(s)
Liked: 4294
The design of the 55, requires you to use RC. You can turn it down pretty low, but you need to have it on.
mjgarrett100@gmail.com
Mike Garrett is offline
post #1903 of 2785 Old 04-30-2015, 05:53 PM
brent_b_23's Avatar
Quoted: 13 Post(s)
I had the HW55ES for a month and a half. Developed bulb flicker and had to go back. Like you I always felt it was soft at times even with RC set to around 35. Any more than that the image started to get too noisy for me. I came from Mitsubishi DLP projector which was very sharp but lacking detail due to poor black levels. I had HW55ES and Epson 5030ub side by side for a couple of weeks. The Epson had way better native contrast but color was not as good and overall detail was lacking. I wish HW55ES used a better lens. Projector to projector can have a lot of variance as you read here all the time. Good luck.
brent_b_23 is offline
post #1904 of 2785 Old 05-01-2015, 02:52 PM
Liked: 0
Does anyone have recommended calibration setting for their Sony VPL-HW55ES projector on a Black Diamond 1.4 gain screen?
I have a designated windowless media room and tried almost everything but my light images are oily (maybe sparkles?) through the screen. Really shows bad on the movies Oblivion and Frozen (just giving movie examples).
Or do I need to switch screens to the BD .8 gain, Slate 1.2 gain or new Slate .8 gain?
Thanks in advance!
Mediabrandon is offline
post #1905 of 2785 Old 05-01-2015, 03:24 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3771
Thanks in advance!
If you have a windowless dark room, why not use a white screen with little or no gain ? Feel free to call us at AV Science to discuss the pros and cons of various screens. Or, send us an email.
post #1906 of 2785 Old 05-01-2015, 03:28 PM
Liked: 0
I already have the set up I mentioned above since July. Installer recommended it since we love watching movies in dark and watch football games with lights on and door open. Calibration is where I am having issues as it looks "oily" in all light areas.
post #1907 of 2785 Old 05-01-2015, 03:53 PM
Liked: 0
So for my environment, is lower gain better?
post #1908 of 2785 Old 05-02-2015, 05:32 PM
Jive Turkey's Avatar
Quoted: 265 Post(s)
Liked: 155
Without Darbee, RC would be neccessary. I've used both together at low settings and it works good, but right now I'm running Darbee without RC at HD35 with great result.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #1909 of 2785 Old 05-03-2015, 06:45 AM
Liked: 4294
I was referring to just the projector. Since Darbee and RC are similar in concept in the way they work, the Darbee can be used in place of RC.
post #1910 of 2785 Old 05-05-2015, 02:44 PM
Liked: 0
I currently have the Sony 6200 blueray player on this projector. Is this player optimal for this projector or are there better ones out there? I also have the SONY STRDA2800ES receiver. Thanks!
post #1911 of 2785 Old 05-06-2015, 10:06 AM
Home Theater Lover
Craig Peer's Avatar
Liked: 3771
I would think that Blu Ray player is fine with your HW55. It gets good reviews.
post #1912 of 2785 Old 05-07-2015, 02:33 AM
irpejoo's Avatar
Liked: 1
Hi, got hw55es installed. I used to calibration these settings https://www.avforums.com/threads/son...tings.1866843/
Picture looks good. I have totally dark room with 0.8 gain screen at 10" throwing distance. Should I make some adjustments? Is there any better settings you have found useful. There is also settings in here ( http://www.projectorreviews.com/sony...ibration-page/ ) but it doesnt have expert settings on it.
I play a lot of games and the game mode looks too bright. The NHL15 ice is like sun to my eyes. I would like to use recommended settings for playing and not game mode but still have low input lag. What settings does affect to input lag. What should I definetly disable and enable for gaming.
Thanks in advance
irpejoo is offline
post #1913 of 2785 Old 05-07-2015, 02:43 AM
broodro0ster's Avatar
Quoted: 28 Post(s)
Liked: 5
I think game mode uses high lamp mode my default. Set it to low.
broodro0ster is offline
post #1914 of 2785 Old 05-10-2015, 05:55 PM
irpejoo's Avatar
Liked: 1
It helped a bit. Contrast was also 90 at default. I put it to 50 so its more normal. Can I change game mode settings without increasing input lag. I mean if I put all settings in game mode to like avsforums best recommended settings, would it add more input lag? I know some image processing functions add input lag but does changing colorprofile, colourtemp, contrast, nrc etc have effect?
irpejoo is offline
post #1915 of 2785 Old 05-11-2015, 12:48 PM
Nowak's Avatar
Hello everyone! I have been a happy HW55ES owner for about a year now... It's my first projector and it has a grat picture quality. The only thing that bothers me is some flickering in the image, during BluRay movies in light/bright scenes (also when using windows in the PC, with almost the entire screen in white). Can it be somehow solved or disabled? The curious thing is, when I use it for gaming, this problem doesn't happen.
Nowak is offline
post #1916 of 2785 Old 05-14-2015, 04:21 AM
anidabi's Avatar
Quoted: 42 Post(s)
Have any of you had any scratches on you PJ after sending to repair center?
I got some slight scratch spots on my PJ after sony prime support.
anidabi is offline
post #1917 of 2785 Old 05-14-2015, 07:33 AM
Quoted: 138 Post(s)
Liked: 137
I would think you are safe changing those, best bet would be to change them and see if you feel a difference in input lag, my guess is you wont as those changes should be fine.
HT - JVC RS520 - Anthem AVM 60 - XPA-7 - XPA-5 - GE Triton 2 - GE Supercenter XXL - GE Invisa 650 x 8 - Xbox One - PS4 Pro - Oppo BDP-203 - Dual Rythmik FV15HP's - Lumagen Radiance Pro
My Media Room
kaotikr1 is offline
post #1918 of 2785 Old 05-16-2015, 03:22 AM
irpejoo's Avatar
Liked: 1
Thanks, seems to work fine with those adjustments I made.
irpejoo is offline
post #1919 of 2785 Old 05-16-2015, 03:26 AM
irpejoo's Avatar
Liked: 1
Anyone had success with that Tiffen filter? Which size I have to order to make it fit and do I need some extra add on pieces for making it fix with projector like collapsible hood, where to get one? I cant get contact with original filter seller if they ship to europe or not so now my only chance is Tiffen. Is there any other better options?
irpejoo is offline
post #1920 of 2785 Old 05-20-2015, 07:43 PM
gadgetfreaky's Avatar
Quoted: 21 Post(s)
I just installed a 120" black diamond zero edge 1.4 gain! But I need your help.. The bottom right of the picture curves down. The top is perfectly straight and aligned. Left side, right side.. But the bottom picture curves from the left to right towards the bottom.
So I can't perfectly fill the screen otherwise I get bleed in the bottom right of the screen. See attached.
I can't figure out how to straighten this. Is it a problem with the projector?
Name:	2015-05-20 12.18.33.jpg
ID:	728066   Click image for larger version
Name:	2015-05-20 12.18.37.jpg
ID:	728074   Click image for larger version
Name:	2015-05-20 12.18.48.jpg
ID:	728082   Click image for larger version
Name:	2015-05-20 12.18.55.jpg
ID:	728090   Click image for larger version
Name:	2015-05-20 12.19.33.jpg
gadgetfreaky is offline
Sony , Sony Vpl Hw55es 3d Projector
