Owners thread Sony Hw55ES - Page 65 - AVS | Home Theater Discussions And Reviews
 39Likes
post #1921 of 1940 Old 05-21-2015, 08:42 AM
Soul_Reaper_SKN's Avatar
Liked: 0
Hi guys
Is there any good ceiling mount I can get for vpl 55es from amazon?
Soul_Reaper_SKN is offline
post #1922 of 1940 Old 05-21-2015, 10:29 AM
Craig Peer's Avatar
Location: In my home theater ( when I'm not rock climbing, cycling or kayaking ) - Sacramento CA area
Quoted: 854 Post(s)
Liked: 629
The Chief RPA020 or RPMA020 mount is my choice.
Soul_Reaper_SKN likes this.
Craig Peer, AV Science Sales. Call me on my direct line - 585-671-2972, 8:30am - 4:30pm PST, Monday - Friday
Email me at craig@avscience.com http://shop.avscience.com/
Yes, we sell Home Theater gear right here at AVS !!
JVC, Sony, Epson, DPI, SIM2, SV Sound, Martin Logan, RBH, and many more!
Craig Peer is offline
post #1923 of 1940 Old 05-21-2015, 10:46 AM
Liked: 0
Does Amazon stock these?
post #1924 of 1940 Old 05-21-2015, 11:09 AM
Craig Peer's Avatar
Quoted: 854 Post(s)
Liked: 629
Go check on Amazon - they should. We do at AV Science.
post #1925 of 1940 Old 05-21-2015, 11:30 AM
Liked: 0
They only seem to have this one.
http://www.amazon.com/Chief-RPAU-Uni...s=chief+mounts
will it work?
post #1926 of 1940 Old 05-21-2015, 11:43 AM
Craig Peer's Avatar
Quoted: 854 Post(s)
Liked: 629
will it work?
Yes, that will work !
post #1927 of 1940 Old 05-21-2015, 11:48 AM
Liked: 0
thanks .
post #1928 of 1940 Old 05-21-2015, 03:49 PM
gadgetfreaky's Avatar
Quoted: 17 Post(s)
Originally Posted by gadgetfreaky View Post
I just installed a 120" black diamond zero edge 1.4 gain! But I need your help.. The bottom right of the picture curves down. The top is perfectly straight and aligned. Left side, right side.. But the bottom picture curves from the left to right towards the bottom.
So I can't perfectly fill the screen otherwise I get bleed in the bottom right of the screen. See attached.
I can't figure out how to straighten this. Is it a problem with the projector?
Would love some help on this?.. pretty please?
gadgetfreaky is online now
post #1929 of 1940 Old 05-21-2015, 04:13 PM
Craig Peer's Avatar
Quoted: 854 Post(s)
Liked: 629
Your projector is not perfectly aligned with the screen. It needs to be level and square with the screen. And your screen should be level ( and hopefully the wall is plumb ). Play with the mount.
post #1930 of 1940 Old 05-23-2015, 04:03 AM
WildWolf's Avatar
Quoted: 42 Post(s)
I have a stupid question.....I maxed out the zoom on the 55es at the lens but the picture is not big enough. Is there anything else I can do or do I need to move my projector back?
WildWolf is offline
post #1931 of 1940 Old 05-23-2015, 04:41 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1627 Post(s)
Liked: 849
There are other things that you can do, but the simplest and cheapest is to move the projector. The other options are to buy a conversion lens or set up a first surface mirror to increase your throw distance.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Sony, JVC, Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, SVS & Def Tech, Denon, Pioneer, Marantz & Yamaha .
AV Science Sales 5 is offline
post #1932 of 1940 Old 05-23-2015, 04:44 AM
WildWolf's Avatar
Quoted: 42 Post(s)
thank you for the quick reply.
WildWolf is offline
post #1933 of 1940 Old 05-24-2015, 11:00 AM
Loquitur's Avatar
I'm interested in this projector but don't know if it will work in my set up. I want to sit it on a shelf 16.5 feet from a 106" screen. Is that within the throw distance of the projector?
Loquitur is offline
post #1934 of 1940 Old 05-24-2015, 06:49 PM
replayreb's Avatar
I ordered my Chief RPA020 ceiling mount from B&H Photo...
http://www.bhphotovideo.com/c/produc...Projector.html
Click on the compatability tab on this page to make sure it fits your projector:
http://www.chiefmfg.com/Products/RPA020
You can't order directly from Chief so that's why you have to go through B&H Photo. It may take them a week or more to get it from Chief before they ship it on to you but one time I ordered one for an older projector and they drop-shipped it directly from Chief.
It includes the standard Chief ceiling mount and a custom plate that fits the Sony 55ES. It's not that much more expensive than a universal mount and is a custom fit. I've never understood why someone would buy a two, three or four thousand dollar projector and then mount it using a piece of plywood. lol
replayreb is offline
post #1935 of 1940 Old 05-24-2015, 11:17 PM
Ronald Epstein's Avatar
Quoted: 85 Post(s)
Liked: 90
Should be. I have a 118" screen with a throw distance of 16 feet. Perfect.
Ronald Epstein is offline
post #1936 of 1940 Old 05-25-2015, 08:54 AM
AVS Club Gold
Liked: 849
Or you could call someone that keeps this as a stock item.
post #1937 of 1940 Old Yesterday, 03:09 PM
Loquitur's Avatar
I'm not sure if I am reading the projectorcentral.com throw distance charts correctly but if I am, the maximum throw distance for this projector on a 106" diagonal screen is 16' 2". Unfortunately, due to room limitations, I can't go with a larger screen. So I'm thinking I have to go with the JVC. I hate to spend the extra money but there will be no throw distance issues and it also has a huge vertical lens shift which should make set up very easy. I want to put this projector on a shelf at the rear of the room which is within easy reach. My former projectors have all been ceiling mounted and they have been a PITA when it comes to changing bulbs and normal maintenance. If I'm reading that chart wrong, I hope somebody will let me know since I would definitely go with the 55ES if it would work for me. Susan
Loquitur is offline
post #1938 of 1940 Old Yesterday, 04:32 PM
AVS Club Gold
Liked: 849
You are correct, 16'-2" for the Sony. The JVC throw would be around a max of 21'-6" we have both of these projectors in stock. If you have any questions, give us a call.
post #1939 of 1940 Old Yesterday, 11:25 PM
Quoted: 85 Post(s)
Liked: 90
Loquitur,
You will definitely love the 55ES.
Now owning it 2-3 months, it is performing flawlessly (though the first one I got was defective out of the box).
Picture quality is exceptional.
post #1940 of 1940 Old Today, 02:07 AM
marlon1925's Avatar
Quoted: 30 Post(s)
Loquitur,
I can't wait to have mine in a week. woohoo!
anyone here tried playing FIFA 15 on ps4 using this PJ?
marlon1925 is online now
Sony , Sony Vpl Hw55es 3d Projector
