Owners thread Sony Hw55ES - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 127Likes
post #2521 of 2750 Old 02-01-2016, 03:20 PM
cdy2179's Avatar
Quoted: 743 Post(s)
Liked: 433
Originally Posted by PaulG View Post
I really don't like the mount I've got right now and have been considering a Chief. Current mount wobbles and I want something more solid + with the current mount, I'll have to take the PJ down for filter maintenance. If I got the RPA020, can I just mount it to a drop pipe already affixed to the ceiling or am I missing something? Thanks.
I upgraded to Chief. BAss at reference is no issue. Insanely built mounts... I could hang from it!
cdy2179 is offline
post #2522 of 2750 Old 02-01-2016, 05:00 PM
hdtvluvr's Avatar
Quoted: 33 Post(s)
Liked: 31
As long as the pipe you have is 1-1/2" NPT and at least 4 rows of threads. Be sure the pipe is firmly mounted so it doesn't add to any play/motion.
Here is from the manual:
Installing to 1-1/2" Threaded Extension Column
1. Install 1-1/2" NPT or NPSM following ANSI/ASME B1.20.1
(Schedule 40, 0.154" minimum thickness aluminum - ASTM
B221) threaded extension column (not included) into
threaded collar until tight, with a minimum of four threads
engaged.
PaulG likes this.
hdtvluvr is offline
post #2523 of 2750 Old 02-01-2016, 06:40 PM
Quoted: 37 Post(s)
Liked: 9
So yesterday I finally put in the email for my lamp coupon, and today they confirmed my order, albeit warning of the backorder with no expected availability.
Then 2 minutes ago I got an email that my lamp had shipped (with tracking number).
I guess I'm just extra lucky??
PaulG likes this.
doubledgedboard is offline
post #2524 of 2750 Old 02-02-2016, 02:32 PM
PaulG's Avatar
Quoted: 102 Post(s)
Nicely done! Go play the lotto!!
Placed my order in November. Just got the same shipping confirmation email. FINALLY!
PaulG is offline
post #2525 of 2750 Old 02-02-2016, 03:21 PM
ninjahifi's Avatar
Quoted: 13 Post(s)
Sent voucher info mid-December, just got shipping info today.
ninjahifi is offline
post #2526 of 2750 Old 02-02-2016, 07:09 PM
yash's Avatar
No such luck for me yet. I submitted mine in early December and still waiting for my shipping confirmation.
yash is offline
post #2527 of 2750 Old 02-08-2016, 10:31 AM
smuggymba's Avatar
Quoted: 113 Post(s)
I submitted mine today so hopefully I'll get it in 2-3 months.
smuggymba is offline
post #2528 of 2750 Old 02-08-2016, 12:05 PM
gadgetfreaky's Avatar
Quoted: 21 Post(s)
I have about 1900 hrs on my lamp, and definitely the last few months.
Ugh.. so did we figure out if I just need a new lamp? less than 2K hours.. I run it 70% high lamp 30% of the time in eco mode.
Also, where's the best place to buy a high quality replacement for a reasonable price?
I replaced this about 11 months ago. So is this projector a 2K hour lamp projector?
gadgetfreaky is offline
post #2529 of 2750 Old 02-08-2016, 12:09 PM
plissken99's Avatar
Quoted: 129 Post(s)
Liked: 35
Are there any child size 3D glasses for this projector? Have a friend with a 6yr old kid who can't wear the normal size glasses.
The more things change, the more they stay the same.
Snake Plissken
plissken99 is offline
post #2530 of 2750 Old 02-10-2016, 08:40 AM
jrlnc's Avatar
Lamp failure after 1800 hrs - Sony: 'you're SOL'
Well, I just had to use my replacement lamp because it was beginning to flicker all the time, whether it was Low or High lamp mode.
By the way, I almost always used mine in LOW lamp mode for the first 1600 hrs. After the flickering started I could 'cure' it with a few minutes of running it on High. But that eventually didn't work anymore.
I thought these lamps were quoted at 5000 hrs?
I called Sony's warranty service who said that's normal, the lamps DON'T last 5000 hrs and it's considered an accessory not covered by warranty.
But if I wished, I could send an email to complain.
Couple this with the diminishing contrast issue = the last Sony product for me EVER.
jrlnc is offline
post #2531 of 2750 Old 02-10-2016, 09:43 AM
cdy2179's Avatar
Quoted: 743 Post(s)
Liked: 433
Dude, it's a light bulb... Some last longer than others. They all use mostly Philips or osram. The next lamp say an osram could last 5000 hrs and never fail just get dim as hell. My last two osram both went over 6k...never blew or flickered, the one before than went out with 2k on it.
So you hate Sony because the lamp went out early... The lamp hour rating is based on dimness and usability based on that... It's not a guarantee of lamp life... This is something long time projector owners quickly come to understand. Kinda like those lights in your house some burn out much earlier than others..of course these are much higher quality so usually they get too dim to be useful before they quit.
Bottom line... Welcome to projectors... Unless you go laser it's the way it is.
Scarriere likes this.
cdy2179 is offline
post #2532 of 2750 Old 02-10-2016, 09:46 AM
robnix's Avatar
Quoted: 665 Post(s)
Liked: 500
Speaking of lamps, where's a good place to buy replacements?
Looky here!
robnix is offline
post #2533 of 2750 Old 02-10-2016, 10:01 AM
plissken99's Avatar
Quoted: 129 Post(s)
Liked: 35
What do you mean by "diminishing contrast"?
Snake Plissken
post #2534 of 2750 Old 02-10-2016, 10:26 AM
jrlnc's Avatar
Sorry, I guess I am mistaken. I'm fairly inexperienced with projectors. I've only owned 1 prior to this model and only got it up to 1100 hrs on the original bulb before I upgraded. I thought I heard somewhere that this one would last 5000. Sony says no such thing...
Also, I contacted Mike G from AVS whom I bought the projector from. He replied that there is a just general 3 month guarantee on the bulb. I guess there are too many variables like power spikes/outages, dust, smoke, HI/LO mode to really gauge these by hours.
I am disappointed, but Mike said all projector companies would tell me the same thing. JVC would not replace it after 1800 hrs either.
C'est la vie. I just didn't figure on replacing the bulb this often (after 20 months/1800 hrs). But now the projector is my main display and I use it for everything.
cdy2179 likes this.
jrlnc is offline
post #2535 of 2750 Old 02-10-2016, 10:33 AM
jrlnc's Avatar
I thought it was this thread.
jrlnc is offline
post #2536 of 2750 Old 02-10-2016, 12:20 PM
Quoted: 21 Post(s)
So where is everyone buying their bulb for the sony projector? if it's once a year.. I'd like to keep it at below $200.. then it's only $17/month, price of 2 movie tickets which I'll gladly pay
post #2537 of 2750 Old 02-10-2016, 12:41 PM
cdy2179's Avatar
Quoted: 743 Post(s)
Liked: 433
It's rare for one to go out that early. Usually they'll get so dim you get tired of the dim picture and swap it out.. or you change it when the projector tells you too. The ratings the manufacture gives is their opinion of when it's dimmed enough to need swapping out. Unless you use it for your main TV you'll go a few years between lamps.
cdy2179 is offline
post #2538 of 2750 Old 02-10-2016, 12:46 PM
cdy2179's Avatar
Quoted: 743 Post(s)
Liked: 433
Here's where I've bought my last 3 lamps over the last 8 years. Philips and Osram.http://www.projectorlamps.com/sony-p...pl-hw55es.html
robnix, Scarriere, jrlnc and 1 others like this.
cdy2179 is offline
post #2539 of 2750 Old 02-10-2016, 01:06 PM
robnix's Avatar
Quoted: 665 Post(s)
Liked: 500
Bookmarked.
Looky here!
robnix is offline
post #2540 of 2750 Old 02-10-2016, 01:16 PM
trmoore2's Avatar
Quoted: 108 Post(s)
Liked: 48
HW-55ES Clean filter message
I recently cleaned my filter for the Sony HW-55ES (for the second time) and the red message prompt is coming on when I turn on the projector. Is there a "reset" for the filter? Does the notice come on based on hours or dirty-ness?
Main Speakers: Revel F208's. Center: C208
SUB#1: Rhythmik F15HP. SUB#2: Stereo Integrity HST18 w/ Crown XLS2502
Marantz SR7009, Emotiva XPA-5
Projector: Sony HW55-ES, Carada 134" screen
trmoore2 is offline
post #2541 of 2750 Old 02-10-2016, 01:33 PM
cdy2179's Avatar
Quoted: 743 Post(s)
Liked: 433
Originally Posted by robnix View Post
Bookmarked.
There's also some places to buy the bare lamps and install yourself in the OEM housing. Also some companies sell new lamps in used OEM housings. Just don't go cheap because the reflector of the housing is important. Just go with a reputable company and you'll be good to go.
cdy2179 is offline
post #2542 of 2750 Old 02-10-2016, 02:48 PM
robnix's Avatar
Quoted: 665 Post(s)
Liked: 500
I made the mistake with a Mitsu DLP of going cheap once. Never again.
Looky here!
robnix is offline
post #2543 of 2750 Old 02-10-2016, 03:28 PM
jrlnc's Avatar
Thanks cdy2179.
Then there's this one too that also has a 6-month warranty and uses an original Philips bulb. I don't have any experience with this company, but it looks like gadgetfreaky's wish of <$200 lamps are easily available out there.
cdy2179 likes this.
jrlnc is offline
post #2544 of 2750 Old 02-12-2016, 06:35 PM
Quoted: 37 Post(s)
Liked: 9
I think your comment about 1600~ hours on LOW nailed it.
As you'll see in numerous posts earlier in the thread, it's pretty clear that running the bulb in 'Low' for an extended period, especially from the start, drastically increases the likelihood that your bulb will develop arcing issues (where the arc wanders down from the tip of the electrode) and start to flicker.
It's a common recommendation to burn in your bulb at full power for at least 100 hrs before switching to 'Low'.
It's also recommended to immediately switch to a new bulb once you get it, and both burn it in and make sure it won't die within the very limited warranty period. Once you get past the first part of the bathtub curve you should be okay.
post #2545 of 2750 Old 02-12-2016, 10:27 PM
Quoted: 21 Post(s)
awesome.. ordering now
post #2546 of 2750 Old 02-22-2016, 06:14 PM
Quoted: 37 Post(s)
Liked: 9
tl;dr silver screen + 55es + active 3d = will samsung 3d glasses still work?
So I ended up dumping some cash into trying out 3D on my 55es in a few ways, and for posterity, my adventure goes like this:
- Tried out included IR glasses, not much desync issue, but very heavy and had headaches after a few hours (I already wear glasses + use headphones), some crosstalk
- Decided I would try the RF route, bought the overpriced sony cable
- Bought EStar Emitter Kit (BC100) and some samsung ssg-5150gb glasses
- Emitter Kit worked fine with sony cable, but included pair of glasses was uncomfortable, and the samsung's i bought wouldn't pair
- Discovered there are two standards of 'RF' in 3D, the BT 'Full HD 3D' format and the ZF 'We're Special Snowflakes' format
- Estar kit was ZF, glasses were BT
- Estar kit has awesome tweaking options (duty cycle, timings), but the samsung glasses are super light, cheap, and comfortable (even over glasses and with headphones).
- Gave up on Estar kit, bought 'Xpand' kit on the cheap (Mitsubishi combo pack on amazon), and it paired with my Samsungs
- Xpand kit works, but I still get crosstalk, and it doesn't let you tweak the duty cycle, etc
Now the current predicament...
I have a Silver Ticket Grey screen that I'll be replacing with their Silver Ticket 'Silver ALR' Screen.
The new screen retains polarization.
As evidenced over in this thread, Active 3D + Silver Screens + JVC projectors is an issue, since the polarization (horiz\vert) of the light coming from the LCD\LCOS doesn't match the polarization of most active 3d shutter lenses (horiz\vert), and this results in massive dimming of the picture.
So as you can see from that thread, one company makes specially polarized 3D glasses to be used with JVC projectors.
What I'm concerned about is when I get my ALR Screen, since it retains polarization, will it end up borking me on light output when I use it with my Samsung SSG-5150GB glasses?
Does anyone have any experience using Active 3D + a polarization retaining screen?
I can't seem to find any information if the 55es is horizontal or vertical, and if the samsung glasses are horizontal or vertical (although I'm inclined to believe that the glasses are vertical since the 'JVC style' xpand ones in the linked thread are specifically listed as horizontal).
Thanks~!
post #2547 of 2750 Old 02-22-2016, 06:48 PM
wouldtoo's Avatar
Quoted: 24 Post(s)
Thanks~!
I have used the included Active glasses with my Screen Inovations Slate and have enjoyed it. They are a little heavy, but it's been decent. I have watched Avatar, Kenny Chesney's 3D concert, and the Avengers that my daughter bought. It has been fun
wouldtoo is offline
post #2548 of 2750 Old 02-22-2016, 06:53 PM
wouldtoo's Avatar
Quoted: 24 Post(s)
Originally Posted by tmavs View Post
Originally Posted by wouldtoo View Post
Question. I am trying to play a 3D movie. The HW55ES is capable of playing 3D and I have a 3D capable Sony Blu Ray player. When I try to play a 3D movie, it is telling me I don't have a 3D device.
I am running everything through my Integra DTR-50.3 receiver. The only thing I can figure is that the receiver is not picking up the 3D. I don't know if there is a setting in the receiver I need to set or what. Any suggestions?
I have posted this on the Integra site as well, but have not heard anything yet. Any information would be greatly appreciated.
Your AVR does not support 3D.
Got my AVR to play 3D. Bought a new HDMI cord. The other one was fairly new, so not sure. I knew my Manual said it played 3D, so now it works
wouldtoo is offline
post #2549 of 2750 Old 02-24-2016, 09:58 PM
Quoted: 37 Post(s)
Liked: 9
Thanks for the response! I researched your screen and it appears that while it's an ALR screen that particular screen doesn't retain polarization.
post #2550 of 2750 Old 02-24-2016, 11:22 PM
Crizo's Avatar
My bulb is flickering at 720 hours. Is that a record? It has been on low since day one. I never heard of that "set to high for first 100 hours" rule. Oh well..like others have said, it's just a bulb.
Crizo is offline
Sony , Sony Vpl Hw55es 3d Projector
