Ceiling mount downward angle? - AVS Forum | Home Theater Discussions And Reviews
Old 11-13-2013, 07:06 PM - Thread Starter
ckmic's Avatar
Is it just me or does the Panasonic 8000 have a serious downward angle when mounted on the ceiling ... the lens in inline with the top of the screen - 17 foot throw - 110" screen
ckmic is offline
Old 11-14-2013, 06:59 AM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
You need to adjust the projector's optical lens shift. This is a manual adjustment on this projector (i.e., not a power adjustment with the remote).
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
Old 11-14-2013, 08:45 AM
Vlubbers's Avatar
In my case I find that I must first zero out any lens shift as a starting point. Which is what Ron is saying. One way to do that is to turn the projector on and then center the light exiting through the lens in the exact center of the lens. Then the projector can be leveled in the mount and then lens shift dialed in if necessary. The best part, the sweet spot if you will, of almost any lens is the exact center. But necessity trumps perfection at times.
Sony G90-->D-ILA--> LCD-->Vango LED DLP
Vlubbers is offline
Panasonic Ptae8000u Hd Projector
