High Brightness High Resolution Projector For Art Installation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-03-2013, 10:07 AM - Thread Starter
jojjoj23's Avatar
Hello I hope this is an interesting question for the folks in the forum used to mainly home theatre display questions.
I am designing an art installation for an artist who needs a high resolution, high brightness image. The image being projected is high contrast so I am looking for deep blacks while having high brightness. Money isn't really an object with the budget I am working with however the physically lighter and smaller the projector the better. In my research I've found the following projectors to fit the bill. Any suggestions would be great!
Projector Choices
Epson PowerLite Home Cinema 5030UB
Panasonic PT-AE8000U
VPL-VW600ES
Sony VPLFH36
VPL-HW55ES
VPL-VW95ES
VPL-VW1000ES
JVC DLA-X900R
DLA-X500R
DLA-X35
DLA-X75R
jojjoj23 is offline
post #2 of 4 Old 12-03-2013, 11:45 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4116 Post(s)
Liked: 4206
What image size, what screen material, what throw distance ?
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #3 of 4 Old 12-03-2013, 12:35 PM - Thread Starter
jojjoj23's Avatar
Screen Size: 58"x78"
Screen Material: Most likely some sort of muslin but I can convince otherwise. Any suggestions?
Throw Distance: 12ft
jojjoj23 is offline
post #4 of 4 Old 12-06-2013, 03:43 PM
d.j.'s Avatar
Quoted: 171 Post(s)
Liked: 74
its a 4:3 screen size !? what format will the image have ? ( and is it video,film or still ? and what resolution )
how is the room where you project in ? ( will there be light in it ? and if yes how much ? , color off the wall, celling and floor ? ) distance you will Watch the image ?
yes a dedicated screen will be a distinct advantage ( wich model depends on the answers above - Craig will advise you
Only two off the projectors is very high resolution / UHD ( ultra high definition = 3830x2160 ) / 4K = 4096x2160 - with around 8.8 mil pixels on screen
thats the 500/600ES and the 1000ES ( both real 4K projectors with a 4096x2160 panel )
- brightness is allmost the same between them ( probely with a Little advantage to the 1000ES )
the contrast and intrascene contrast is better on the 1000ES,
the lens and the picture is sharpere on the 1000ES,
The 500/600ES will be physically lighter and smaller ( 14 kg versus 20 kg and the 1000ES 18cm deeper/ longer )
the 1000ES will be more silent, if thats a point ?
the 500/600ES will easyer be calibreted to 100% correct colors, if thats a point.
The 1000ES has the biggest colorspace - can show DCI and Adobe RGB color Space ( could be importent if it is a still Picture/ Photo, you will show ? )
The rest is 1920x1080 resolution projectors = around 2.2 mil pixels on screen ( the JVC do some tampering with them, but are actually still 2K - 1920x1080 - projectorerer , showing a kind of pseudo "4.4" mil pixels, IMO ). But off all the projectors the X900 will have the biggest dynamic range ( native contrast - on/off contrast ).
dj
without knowing more for now - my best bet would clearly be the 1000/1100ES - but there can be importent Things in your setup, wich could change the advise on wich projector there will fit your needs best.
d.j. is offline
Panasonic Pt Ae900u Home Theater Projector , Epson 5030ub 2d 3d 1080p 3lcd Projector , Projector Gear Projector Ceiling Mount For Sony Vpl Fh36 B With 12 Extension , Sony Vpl Hw55es 3d Projector , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector , Sony Vpl Vw1000es Projector , Jvc Dla X35 3d Hd Front Projector , Jvc Dla X75r
