Need An Ultra Short Throw Projector that is 30 inches from surfaces and can make an image 11 feet wide - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-06-2013, 09:29 AM - Thread Starter
avdts's Avatar
I am in desperate need of some help. I have a project that requires a ultra short throw rear projection (minimum 3500 lumen)
to be mounted at 30 inches back  from the wall/glass. The projector will be mounted 13 feet 6 inched from finished floor in a sofit.
The projector top image will be displayed from 9 feet from finished floor, That is 4 feet 6 inched from the projector.
If this requires 2 projectors that is fine. I need to cover 11 feet wide. The vertical is not as important. Four or five feet vertical is OK.
LEAD Technologies Inc. V1.01
Thanks for your help!
avdts is offline
