cleaning lens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 12-08-2013, 05:56 PM - Thread Starter
taxman48's Avatar
Quoted: 319 Post(s)
Liked: 310
Just got mhy JVC 35 and was wondering how to and how often to clean the lens?.. I keep my cover on when not in use, but wanted to clean the lens and with what material.. thanks in advance
taxman48 is online now
post #2 of 16 Old 12-08-2013, 06:06 PM
Mike Garrett's Avatar
Quoted: 7063 Post(s)
Liked: 4772
Best to not touch the lens. Definitely do not do a regular cleaning regime. Each cleaning will put micro scratches on the lens, so never touch, unless you have to.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 16 Old 12-14-2013, 08:50 AM
isamu's Avatar
Quoted: 37 Post(s)
what about if you use one those soft lens/glasses cleaning fabric cloths?
isamu is offline
post #4 of 16 Old 12-14-2013, 10:04 PM
Liked: 4772
Unless you have a smudge, don't touch the lens. I would not use the cleaning cloth.
post #5 of 16 Old 12-14-2013, 10:30 PM
Elix's Avatar
Quoted: 238 Post(s)
Liked: 104
I use an air duster for photo lenses
Elix is offline
post #6 of 16 Old 12-15-2013, 12:17 AM
davestan's Avatar
I could be wrong here but I thought many projector lens sit behind an outer clear cover so the actual lens surface is not what you would be cleaning. I have been told that this is the case with the Epsons. These covers may be plastic so I would be cautious about rubbing them with any cloth or device (eg lenspen) unless absolutely necessary.
davestan is offline
post #7 of 16 Old 12-15-2013, 12:36 AM
Reddig's Avatar
Quoted: 252 Post(s)
Liked: 521
The lens on my BenQ W7000 collects dust particles from time to time and air doesn't clean it enough. Nothing major but I still see particles on the lens. What other cleaning options are there besides a photo lens air cleaner such as above? Is it safe to use compressed air?
JBL Pro Cinema-JTR subwoofers-Sony projection-Elite AT screen-Denon AVR-Oppo BD player-Acoustimac panels-SeatCraft HT seating
MANCHESTER UNITED!!
Reddig is offline
post #8 of 16 Old 12-15-2013, 05:38 AM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
Dust does not effect performance. Do not clean the lens if all you're seeing is dust on the lens.
Seegs108 is offline
post #9 of 16 Old 12-15-2013, 12:58 PM
Reddig's Avatar
Quoted: 252 Post(s)
Liked: 521
Nice good to know thanx.
MANCHESTER UNITED!!
Reddig is offline
post #10 of 16 Old 12-16-2013, 09:08 PM
Googer's Avatar
Quoted: 306 Post(s)
Liked: 264
Works great on my RS20. biggrin.gif They're cheap, on the order of $5-6 on Amazon for example and does a great job of cleaning without any chemicals or leaving any scratches (they're meant for cleaning SLR lenses and the like, so they're meant for exactly this sort of thing). You'll still probably note a couple specks of dust that you won't be able to get rid of no matter how much you try but as others have noted, dust alone doesn't really affect performance.
Googer is offline
post #11 of 16 Old 12-17-2013, 12:43 AM
isamu's Avatar
Quoted: 37 Post(s)
ink?
isamu is offline
post #12 of 16 Old 12-17-2013, 05:13 AM
Googer's Avatar
Quoted: 306 Post(s)
Liked: 264
No, a LensPen doesn't use ink. It's got a piece of microfiber on the end with a carbon treatment on it that absorbs grease, etc. The pen's cap 'recharges' the tip when you twist it on when you're done using it, which is why the pen has several hundred uses in it.
Googer is offline
post #13 of 16 Old 12-17-2013, 11:33 PM
isamu's Avatar
Quoted: 37 Post(s)
Sorry dude, I mean to say "LINK", not "ink", as in can you post a link to where I can buy one?
isamu is offline
post #14 of 16 Old 12-18-2013, 04:38 AM
stanger89's Avatar
Quoted: 3676 Post(s)
Liked: 2046
stanger89 is online now
post #15 of 16 Old 12-18-2013, 04:54 AM
Googer's Avatar
Quoted: 306 Post(s)
Liked: 264
I put a link to Amazon's product page in my original reply; I guess you missed it.. Too subtle I guess so here you go again. tongue.gif
Googer is offline
post #16 of 16 Old 12-18-2013, 10:14 AM
isamu's Avatar
Quoted: 37 Post(s)
isamu is offline
Jvc Dla X35 3d Hd Front Projector
