Official JVC DILA-X500R / RS49U / RS4910U Owners Thread - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 593Likes
Old 10-28-2015, 03:59 PM
ERuiz's Avatar
Quoted: 466 Post(s)
Liked: 154
Originally Posted by Monkey_Man View Post
Anyone using the iPhone remote app, can you confirm your app is still working after all the recent iPhone updates please.
I downloaded it yesterday and it will not work. Crashed straight back to the desktop. Never seen it run, not even once.
I have an iPhone 6+ with iOS 9.1
Efrain "AviatorBimmer" Ruiz
ERuiz is offline
Old 10-28-2015, 04:27 PM
Monkey_Man's Avatar
Quoted: 86 Post(s)
Liked: 48
Okay thanks. I have been using the iPhone app for the last year and the recent iPhone update seems to have broken it.
Monkey_Man is offline
Old 10-28-2015, 04:32 PM
ERuiz's Avatar
Quoted: 466 Post(s)
Liked: 154
Oh ok, I hope JVC fixes it soon. Really looking forward to seeing how the app looks like and works.
ERuiz is offline
Old 10-28-2015, 04:36 PM
Monkey_Man's Avatar
Quoted: 86 Post(s)
Liked: 48
I love it as you can make all the adjustments in the iPhone and it won't display any messages on the screen, even when loading new lens position.
Old 10-28-2015, 04:37 PM
ERuiz's Avatar
Quoted: 466 Post(s)
Liked: 154
Wow, now that would be awesome! Can it do macros like a Harmony?
ERuiz is offline
Old 10-28-2015, 05:40 PM
Monkey_Man's Avatar
Quoted: 86 Post(s)
Liked: 48
No it wont do that. I do run my entire system from my iPhone via Denon app, Oppo app, and the JVC app. Right now I'm using an old Droid phone to control everything until this is fixed. I submitted a support request to JVC.
ERuiz likes this.
Old 10-29-2015, 10:17 AM
Monkey_Man's Avatar
Quoted: 86 Post(s)
Liked: 48
Here is JVC's response regarding the broken iPhone app
"Hello, from what I am hearing they are working on it, but unfortunately I don't have any kind of time frame.
Thank you"
ERuiz likes this.
Old 10-29-2015, 01:58 PM
ERuiz's Avatar
Quoted: 466 Post(s)
Liked: 154
Thank you"
Thanks for the update on this.
ERuiz is offline
Old 10-29-2015, 05:16 PM
ERuiz's Avatar
Quoted: 466 Post(s)
Liked: 154
Quick question guys, reference saved lens memory on the X500R.
I saved 3 settings as follows.
16:9
2.35:1
2.40:1
When I switch between them, they do not resize to the way I originally saved them. For instance, when switching from 16:9 to 2.35, the screen will end up shifted too far right from where it was originally saved.
Any tips or ideas on what could be causing this and how to fix/avoid this?
ERuiz is offline
Old 10-30-2015, 08:05 AM
asharma's Avatar
Quoted: 907 Post(s)
Liked: 155
Originally Posted by asharma View Post
Everyone: my HDFury will be here this Friday...what the hec should I test it on...i don't have Netflix 4K, I don't believe the YouTube stuff is 2.2 protected (I could be wrong). How can I test the Hdfury's operation? Thanks
Just a repost folks...looking for advice thanks
asharma is online now
Old 10-30-2015, 09:35 AM
stanger89's Avatar
Quoted: 3004 Post(s)
Liked: 1572
stanger89 is online now
Old 10-30-2015, 10:19 AM
ERuiz's Avatar
Quoted: 466 Post(s)
Liked: 154
16:9
2.35:1
2.40:1
Any ideas guys?
ERuiz is offline
Old 10-30-2015, 10:34 AM
StevenC56's Avatar
Quoted: 197 Post(s)
Liked: 77
Any ideas guys?
Clear all your memories, then do a lens reset and redo your memories.
StevenC56 is online now
Old 10-30-2015, 10:36 AM
ERuiz's Avatar
Quoted: 466 Post(s)
Liked: 154
Gotcha, will try that today.
ERuiz is offline
Old 10-30-2015, 10:53 AM
GGA
GGA's Avatar
Quoted: 231 Post(s)
Liked: 58
Try this thread:
What devices support Netflix Super HD and 24p?
I think there are other threads there too.
GGA is offline
Old 10-31-2015, 04:40 AM
asharma's Avatar
Quoted: 907 Post(s)
Liked: 155
Hdfury
Has anyone tried their HDFury integral yet? Thanks
Old 10-31-2015, 01:26 PM
ERuiz's Avatar
Quoted: 466 Post(s)
Liked: 154
Dumb question but as I get ready to calibrate my X500R with CalMAN and an i1d3, I was wondering:
Do I calibrate it while projecting a 16:9 image or should I zoom in and fill the 2.35 screen instead?
I ask because if I calibrate at 16:9, then when I zoom in, the calibration would be affected due to the drop in lumens, or that doesn't matter?
ERuiz is offline
Old 10-31-2015, 03:39 PM
Applemike68's Avatar
Quoted: 143 Post(s)
I'm about to purchase a SI 2:35 110" screen. I'm using a JVC 4910, my question is anyone using a similar setup ? What do you think? How do I use set the projector to 2:35? Just curious as this is my first 2:35 screen
Thank you
Applemike68 is online now
Old 10-31-2015, 03:40 PM
Quoted: 143 Post(s)
Thank you
Old 10-31-2015, 05:05 PM
Seegs108's Avatar
Quoted: 4535 Post(s)
Liked: 2255
Thank you
What screen material? Is the room treated for reflections? Any ambient light?
Seegs108 is online now
Old 10-31-2015, 05:54 PM
Quoted: 143 Post(s)
Screen material will be Slate. This is a dedicated movie room so it is completely light controlled
Old 10-31-2015, 06:03 PM
Seegs108's Avatar
Liked: 2255
If it's completely light controlled you don't need a slate screen. Most of Screen Innovations screen materials are built on the presumption that there will be ambient light in the room so this screen is not appropriate for your room. It would be a much better idea to go with something like a unity gain screen such as the Stewart StudioTek 100. Most of Screen Innovation screen materials have positive gain and to get that gain they use "sparkle" elements to increase the screens reflectance. This is good for room that doesn't have proper light control but bad for picture quality as you can easily make these sparkle elements out when there's enough light hitting the screen. It gives the image an almost textured "gritty" look.
Old 10-31-2015, 08:52 PM
Jon S's Avatar
Quoted: 861 Post(s)
Liked: 277
Yes... I got mine... Unfortunately, there is nothing to test them with... It is VERY small, the size of a pack of cigarettes... It was shipped via DHL in a paper shipping bag....
ID:	1031513   Click image for larger version
ID:	1031521   Click image for larger version
ID:	1031529   Click image for larger version
giogt600 likes this.
If it's not a BIG screen, it's not a theater...
Jon S is offline
Old 11-01-2015, 01:51 AM
curlyjive's Avatar
Quoted: 527 Post(s)
Liked: 244
I got my hdfury as well. I also got a roku 4. The roku sees that it can pass 4k60 to the 4910. Problem is finding hdcp protected content that is free. Some of the rentals I looked at are $10! That's halfway to buying the Blu-ray! I have amazon prime so I'll have to see what uhd titles are free and try them. I expect it will work. They packed quite a lot into the hdfury. I especially like that it has two hdmi inputs so I can also use a uhd player with it.
curlyjive is offline
Old 11-01-2015, 03:43 AM
asharma's Avatar
Quoted: 907 Post(s)
Liked: 155
Thanks, mine arrived Friday but nothing to test it with...please keep us updated...thanks
Old 11-01-2015, 03:59 AM
Quoted: 143 Post(s)
Seegs108..
Thank you for the reply, I was in a home theater store and they had a 126" Slate with a sony projector that looked pretty darn good with the lights out. BUT, I did see sparkles/grit on the screen during the movie. So, I guess the way to go is the SI Pure White Zero Edge, that is similar to the one you mentioned. I need to go with a zero edge screen due to my width in the room. I have two columns on either side which limit the size. Using a zero edge 2:35 screen I can go max 115" diagonal. Plus, my wife really liked the LED lights which always helps with the purchase.
Thanks again,
Old 11-01-2015, 05:49 AM
Mike Garrett's Avatar
Quoted: 6261 Post(s)
Liked: 4037
Thank you
You do not say if you are going with Solar White or Pure White fabric, but regardless, there are many JVC owners shooting onto either of those screens. To use lens memory, you adjust the zoom, focus and lens shift so that the 16:9 image fits your screen height in the middle of your screen. Then store that position in memory. Then you do the same thing with the 2.35 image.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 11-01-2015, 07:05 AM
stanger89's Avatar
Liked: 1572
It doesn't matter, it won't affect grayscale/white balance or gamut.
ERuiz likes this.
Old 11-01-2015, 08:53 AM
Liked: 0
Is JVC X500 good for 2.35:1 W/O lens ?
Hi, I just get a X500 and i'm about to get a 2.35 screen.
I don't want to buy an anamorphic lens, so my question is : Are a lumagen radiance and a X500 able to deliver 2.35 pictures with the JVC's lens position memory ?
Lem3ssie is offline
Old 11-01-2015, 08:59 AM
Manni01's Avatar
Quoted: 3102 Post(s)
Liked: 2766
That's correct if he doesn't brightness match the two modes, but in that case he will get one looking much dimmer than the other.
To get the same brightness in both modes, you'll need to open the iris in one of the modes, and if you have to do so in such a way that it moves from one calibration range to the next, then greyscale will be affected.
There are about 4-5 clicks in the iris settings for each range. For example, when calibrating with the JVC Autocal, you have to calibrate with the iris fully closed at -15, then at -10, -5 and fully open at 0.
Manni01 is online now
Jvc
