Official JVC DILA-X500R / RS49U / RS4910U Owners Thread - Page 78 - AVS Forum
 95Likes
post #2311 of 2329 Old 09-16-2014, 12:33 PM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 290 Post(s)
Liked: 404
In checking into this more, from a trusted source, the firmware update, that I was told about is most likely the last update that was provided already.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me:
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Brands we sell:
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon & many more.
RBH, Martin Logan, Triad, Atlantic Technology, MK Sound, BG Radia, SVS & Def Tech.
AV Science Sales 5 is offline
post #2312 of 2329 Old 09-16-2014, 12:36 PM
curlyjive's Avatar
Quoted: 92 Post(s)
Liked: 35
Are you referring to 1211.6? That is also on current shipping units.
curlyjive is offline
post #2313 of 2329 Old 09-16-2014, 04:02 PM
twinturboaudi's Avatar
Hey guys. I seem to be getting a lot of black crush. Curious if there's a setting that might change this. I'm still learning what each setting does, since they are very different from what I'm used to. Thanks.
twinturboaudi is offline
post #2314 of 2329 Old 09-17-2014, 05:46 AM
curlyjive's Avatar
Quoted: 92 Post(s)
Liked: 35
In the gamma section, try a value of 2.3 or 2.4 and adjust the dark correction up a few clicks. Also check your brightness and contrast with test pattern.
post #2315 of 2329 Old 09-17-2014, 08:19 AM
Ok thank. I have it set to 2.2 right and am using the DVE disc. I'll try those different values.
post #2316 of 2329 Old 09-17-2014, 08:26 AM
seanbryan's Avatar
Keep in mind, it's raising the "dark level" adjustment that will bring out more shadow detail. The 2.3 and 2.4 gamma presets will actually crush blacks more than the 2.2 setting, so the dark level adjustment is the key here.
seanbryan is offline
post #2317 of 2329 Old 09-17-2014, 08:30 AM
curlyjive's Avatar
Quoted: 92 Post(s)
Liked: 35
Originally Posted by seanbryan View Post
Keep in mind, it's raiding the "dark level" adjustment that will bring out more shadow detail. The 2.3 and 2.4 gamma presets will actually crush blacks more than the 2.2 setting, so the dark level adjustment is the key here.
They can. Not knowing what his starting gamma was, I suggested 2.3 or 2.4. 2.2 tends to run closer to 2 or below and can looked washed out. 2.3 or 2.4 with dark correction would probably look better and track closer to 2.3 with a dip to 2.2 at 5-10%
post #2318 of 2329 Old 09-17-2014, 12:06 PM
I was thinking that but figured I'd try it. When you say "dark level" are you talking brightness or is there something else in the menu? I'm coming from an epson 8500ub where it was pretty easy to understand what all the controls did. The Jvc, while far superior in picture quality, has a bit of a learning curve to the adjustments.
post #2319 of 2329 Old 09-17-2014, 01:50 PM
seanbryan's Avatar
In the gamma menu there is the option to select your preset gamma curve (2.2, 2.3, 2.4, etc...) and below that you should see other adjustment options that can be applied to the gamma you select. I think they are called "picture tone", "?bright level?", and "dark level". It is the dark level adjustment you need to raise. This will bring out shadow detail in the darker APL images.
post #2320 of 2329 Old 09-17-2014, 03:13 PM
Yukichon's Avatar
Quoted: 74 Post(s)
Liked: 25
Hi everyone
Just ordered my 4910 from Mike at AVS and got an amazing deal !
Super excited to receive it and get it set up once my HT is built. Can anyone recommend a good ceiling mount?
I will be mounting it at 15' 6" as per Mikes recommendation, but would also like to know how low I should hang it?
Yukichon is offline
post #2321 of 2329 Old 09-17-2014, 04:01 PM
DavidHir's Avatar
Quoted: 159 Post(s)
Liked: 424
Originally Posted by Yukichon View Post
Hi everyone
Mike is awesome to work with and I am sure he can give you recommendations. In my case with my RS4810, I went with the Chief RPMA and 18" extension from ceiling (based on his recommendation). The mount has worked perfectly.
DavidHir is offline
post #2322 of 2329 Old 09-17-2014, 04:50 PM
jjcook's Avatar
Quoted: 25 Post(s)
Hi everyone
Chief RPMA281 is the mount with JVC-specific adapter plate. RPMAU includes universal adapter arms instead. I have the RPMA281 on my JVC and the RSMAU (smaller version of the RPMAU) on my Mits. Both work great, I think the universal arms add a little more visual bulk to the mount (which may or may not be important to you, if its even visible depending on your mounting location).
- Jeff
WTB: PSA XS15 or XS15se, PM me.
Small HT: JVC RS4910, Mits HC7900DW, Falcon 2.35:1 100-wide, Marantz SR7008, Triad Gold Omni SE & Silver Surrounds, PSA XS15-base, Oppo 103D, Tivo Mini, HTPC
jjcook is offline
post #2323 of 2329 Old 09-17-2014, 06:31 PM
Yukichon's Avatar
Quoted: 74 Post(s)
Liked: 25
Thanks for the advice, is this the correct one? http://www.amazon.com/Chief-RPMA281-Custom-Elite-Mount/dp/B004SU2LD2
Yukichon is offline
post #2324 of 2329 Old 09-17-2014, 06:44 PM
AVS Club Gold
Quoted: 290 Post(s)
Liked: 404
Hi everyone
The RPAU does not fit the JVC projectors. I would go with:
RPMA281
CMA101
CMS???
The CMS??? is the drop tube. Would need to know screen height, screen placement, ceiling height and distance from ceiling to top of image. Call tomorrow and we can go over this info and work out what length drop tube you need.
Email Me:
Brands we sell:
post #2325 of 2329 Old 09-18-2014, 08:59 AM
Kris Deering's Avatar
Quoted: 211 Post(s)
Liked: 351
Have a friend that just installed a X500 and is looking for discrete codes for lens memories. Anyone here know if there are discrete codes for this that can point me in the right direction? THX.
Senior Video Editor
Secrets of Home Theater and High Fidelity
Kris Deering is offline
post #2326 of 2329 Old 09-18-2014, 11:18 AM
Axel's Avatar
Quoted: 18 Post(s)
RS232? If so, here ya go.
____
Axel
Axel is offline
post #2327 of 2329 Old 09-18-2014, 11:56 AM
Quoted: 48 Post(s)
Liked: 8
Will the 4910 be bright enough for a 125in diagonal 2.35 screen' it is a 1.1 gain white screen. I also like 3d' will the 4910 also be bright enough to light it up. I do like a some what bright pic. My room is pretty much a bat cave. Basement no lights 'black drape walls; Flat black ceiling and black carpet. My current epson 8350 is mounted 13ft 6in back. Just above top of screen. I have low ceiling down their like 7ft 8. I am stuck between the Epson 5030 and Sony hw40' I know they are bright with decent pic. But I know the 4910 will maybe be better. Just worried about a Dim image and the handshake issues. I use a Darbee also. Thanks for any help.
hotpepper007 is offline
post #2328 of 2329 Old Yesterday, 12:03 PM
surrey lad's Avatar
iRule
Originally Posted by Jnelson Young View Post
Do you guys find the network connection to be unstable? I use iRule and the only component I have problems with is the 4910. It's on-line maybe 50% of the time, the rest--mac mini, Onkyo 3009, Roku3, AppleTV are up 99% of the time.
Same here, very frustrating indeed. Things did improve with the latest firmware so now at 85% on-line. But since the update I have discovered a bug, with the x500 on the network and iRule connected to it I can't use any of the lens control features ie zoom, image shift etc using iRule or the JVC remote. I'm convinced its the PJREQ command causing the problem reason being within the first few days of upgrading the firmware my lens memory 'names' were strangely renamed PJREQ...weird.
When I close the iRule app on my nexus I can use the lens control features using the JVC remote.
surrey lad is online now
post #2329 of 2329 Old Today, 12:08 AM
dmoneyman2323's Avatar
Anyone know if the Calman 5 auto calibration software has come out for this projector yet? I was looking to buy a i1Display Pro and would like to do a basic calibration, just waiting on the software to come out.
dmoneyman2323 is offline
Jvc
User Tag List
