Drop Ceiling Mount for Panasonic 8000u Recommendation - AVS Forum | Home Theater Discussions And Reviews
Old 12-14-2013, 04:30 PM - Thread Starter
ch1sox's Avatar
Quoted: 317 Post(s)
Liked: 113
Anyone have any mounts they can recommend? I'm guessing I'm going to have to put a piece of plywood in the joists, cut a hole in the tile and then drop a mount through the tile hole. Anyone done something like this?
ch1sox is offline
Old 12-15-2013, 09:25 AM
Vlubbers's Avatar
I did something similar and I am sure it is common. I used an Arakno Geared Projector Mount to position a Vango. It has not moved in two years. The crucial consideration is the stability of the attachment point. Mine spans trusses on 12 inch centers, but the more stable the better. If it is a floor that gets traffic, you may be surprised at the induced deflections.
Sony G90-->D-ILA--> LCD-->Vango LED DLP
Vlubbers is offline
Old 12-16-2013, 07:34 PM
DIY Granddad (w/help)
MississippiMan's Avatar
Quoted: 1774 Post(s)
Liked: 808
This comes from another recent request made on another Thread.....
I've done this several times in the past so you should easily be able to do something like this:
Chief RPA 181 Mount
Peerless ACC570 Ceiling Plate
1-1/2" PVC Male Threaded Couplings
1-1/2" Schedule 40 PVC Pipe
The Ceiling Grid is more than sufficient to support a total PJ/Mount / Deck assembly of 30 lbs
MississippiMan is offline
Old 12-16-2013, 08:52 PM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
Chief RPA 181 Mount
Any time you use just the ceiling grid to support something like this, you should do two things.
1. Place a tie wire from the structure above to each corner of the grid around the mount.
2. place a tie wire from the structure above to the mount it's self.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 12-16-2013, 09:02 PM - Thread Starter
ch1sox's Avatar
Quoted: 317 Post(s)
Liked: 113
Chief RPA 181 Mount
Thanks for the visual. I went ahead and got the acc570 and pole.
I think I'll do something similar to the picture, but not exactly. I've got a wood joist exactly 18.5 ft which turns out to be my exact throw range. So I'm to go through the tile and hold it by the beam. However, now that you bring this up I'll add some support wires for reassurance.
ch1sox is offline
Panasonic Ptae8000u Hd Projector
