Official JVC DLA-X700R / RS57U Owners Thread - Page 75 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #2221 of 2227 Old 08-19-2017, 12:38 AM
fleaman's Avatar
Quoted: 78 Post(s)
Liked: 121
Originally Posted by makaveddie81 View Post
Not sure how to do that, but there must be a way to manually correct this yes?
I don't see a multi point gamma adjustment, only preset options and they all droop like that.
There are gamma adjustments, but only 3 of them. The adjustments for ea gamma preset are 'picture tone', 'bright level', 'dark level'. Bright adjusts the brights, Dark adjusts the darks, and Picture tone is the mids. So I guess it's a 3 point adjustment.
I bought my RS57 used with about 600 hrs on it and had black crush, which I assume was the result of the 'gamma droop'. I don't have Calman or meters (so no autocal yet for me), but using a 2.1 or 2.2 gamma preset and bumping up the dark level +1 or +2 across all colors, and I think +1 on the picture tone, helped out greatly with my shadow detail.
I dunno how close this 'coarse' adjustment gets me to doing it the right way with JVC autocal, but maybe you can try it and see how it measures out since you have calman. Post the results if so!
fleaman is offline
post #2222 of 2227 Old 08-19-2017, 12:42 AM
fleaman's Avatar
Quoted: 78 Post(s)
Liked: 121
I just noticed you have a RS4810 listed in your signature as your PJ? Maybe you haven't updated your sig? If you do have the RS4810, this thread is probably not the best thread to post about it....and my previous advice probably won't apply...
fleaman is offline
post #2223 of 2227 Old 08-19-2017, 12:52 PM
DavidHir's Avatar
Quoted: 2052 Post(s)
Liked: 1677
You're going to want to use Calman for the RS4810.
DavidHir is online now
post #2224 of 2227 Old 09-12-2017, 01:43 PM
Quoted: 44 Post(s)
Liked: 1
Hi Guys,
I'm going to buy an used RS57.
My main intent is to whatch Ultra HD Blu Ray titles with my Panasonic UB900 player.
I want that my panny send a 2160p/24hz SDR signal to the pj. No need for Rec2020.
Rec709 conversion is not a problem for me.
Some one of you use those two products togheter?
My fear is that may accour some EDID problem ...
I own an HD Fury integral if it's necessary...
let me know, thank you
FidelioX is offline
post #2225 of 2227 Old 09-13-2017, 07:58 AM
mskreis's Avatar
Quoted: 74 Post(s)
Liked: 26
I have a similar setup and have had no problems. I have a linker, though, instead of an integral.
JVC RS57; Marantz AV7702mkII; Lumagen Pro 4240; Oppo BDP-203;Triad Silver LCR, Onwall Bronze Surround, Inwall Bronze Omni, KEF Inceiling Ci 160QR x 4; Dual RSS460HO-4 18" SWs
mskreis is offline
post #2226 of 2227 Old 09-28-2017, 06:31 AM
markhyams's Avatar
Quoted: 33 Post(s)
Originally Posted by Kamikaze13 View Post
My RS57 (X700) would black out with 1080P/24 out on my Oppo so I had to leave it on 1080P/60 out.
No problems since, except for a loose HDMI cable causing drop outs.
I know this is an old quote, but I started having this problem last night. Kamikaze13, did you ever find a resolution to your problem, besides switching to 1080p/60? That worked for me too, but I would like to be able use 1080p/24 sources too. Thanks for the help!
Mark
JVC X500R, Silver Ticket 120-inch screen, Denon 4520, Sony BDP-S5100, Google Chromecast, Logitech Squeezebox
SVS Prime Bookshelf (LCR), SVS Prime Satellite (x2 Surround), SVS-SB2000 (Dual)
markhyams is offline
post #2227 of 2227 Old 09-28-2017, 02:23 PM
Kamikaze13's Avatar
Quoted: 107 Post(s)
Liked: 51
Mark
Lol that was so long ago I barely remember it. I'm pretty sure I switched to an active HDMI cable but honestly I don't remember if I ever switched back to 1080p/24.
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
Jvc Dla X700r
