Things for noobs to look for when testing a new Projector. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-18-2013, 10:21 AM - Thread Starter
Reefdvr27's Avatar
Quoted: 1562 Post(s)
Liked: 1036
I am a projector noob as I have my first PJ on order and I am waiting for delivery.
As we know there are hour limits on returns for projectors and I wanted to get some info for what to look for to see if my projector is doing what it is suppose do, in a relative timely matter.
I was hoping maybe some of the guys with some good knowledge can jump in and give a short list of what a projector should be doing correctly and what to look for problem wise.
As I said at the top I am new to the world of projectors and have not had time to really read up on how to even set a PJ up as well as getting it dialed in and running correctly.
So with that said if anyone would like to jump in and give some of the newer guys getting their feet wet in the Projector world some soundly advise, it would be greatly appreciated.
Thank you
Reef
Reefdvr27 is offline
post #2 of 8 Old 12-18-2013, 12:34 PM
airscapes's Avatar
Quoted: 346 Post(s)
Liked: 283
So, you didn't read up on all the things involved in setting up a projector, or a screen or the room it goes in, but you bought a projector?
What did you buy?
How do you know it will be bright enough or won't be to bright for the screen size you purchased?
Did you buy a screen? If so what aspect ratio and how big?
Where will the projector be mounted and how far from the screen wall?
Can the projector you bought project the appropriate sized image from that distance?
What color are the walls and ceiling?
Do you plan on watching with any light on?
The list goes on and on, it is not like buying a TV.
Seems like you jumped the gun big time as there are many factors that go into making a projected image look good. You can have a $5000 projector and it will look like a million buck or it can look like crap depending on many factors in the rest of the setup.
Not really sure what you are looking for to actually answer your question.. What I look for in a projector : Uniform focus, uniform white image with a full field pattern displayed, sharpness of image, accuracy of color out of the box, black level, noise level and motion issues (depends on image technology).
A lot more info of what you bought, what you have and what you expect, would be needed for anyone to give you meaningful advice.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 8 Old 12-18-2013, 12:50 PM
stef2's Avatar
Quoted: 318 Post(s)
Liked: 212
Maybe the OP wants to know how to quickly evaluate if the projector he got is a lemon or not...dead pixels, color uniformity, panels algnment...?
stef2 is offline
post #4 of 8 Old 12-18-2013, 01:11 PM
airscapes's Avatar
Quoted: 346 Post(s)
Liked: 283
Yep I get that, but if the basics were not taken into consideration, he may want to cancel the order before it is delivered.
Doug
post #5 of 8 Old 12-18-2013, 02:41 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1036
What did you buy?
What did you buy?
I don't recall asking for any of the questions you asked me. What I am asking is what a projector should do out of the box to know that it is working properly so I or others can return it with out voiding any warranties. I am looking for quick and simple check list to know that the projector is working fine. My projector will also be sitting in the box for awhile till my theater is complete, so another reason I would like to it is firing on all cylinders. Unfortunately where I live there are no audio/video resources, NONE. So I kind of have to rely on AVS for all my help.
post #6 of 8 Old 12-18-2013, 02:49 PM
Seegs108's Avatar
Quoted: 4164 Post(s)
Liked: 2046
Basically, do what was previously mentioned. Check for really bad convergence, dead pixels, brightness uniformity, and anything obvious that sticks out. There isn't a whole lot that needs to be checked. Unfortunately you probably won't find out if it's truly a lemon until you get a few hundred hours on the projector as the things previously mentioned are typically checked at the factory before getting shipped out.
Reefdvr27 likes this.
Seegs108 is online now
post #7 of 8 Old 12-18-2013, 03:12 PM
airscapes's Avatar
Quoted: 346 Post(s)
Liked: 283
Sorry, you gave no info other than you were a noob and didn't do any research but bought a projector. All those questions and more should have been addressed before purchase. If you did all of that than forgive me for trying to help.
If you have not read the owners thread for this mystery projector projector you purchased, you should do that, known issues come up in those threads like bad convergence, bad optics, noisy fan etc.
Simple list.
Turns on, image focuses, focus uniformity, if it has lens shift make sure it works, image sharpness, color uniformity, brightness uniformity, all pixels working, if not a single chip DLP make sure convergence is good and uniform, all inputs work. Any other image evaluations would require the room be somewhat finished and a screen be in place with the projector and seating at or near the finished locations.
Image evaluations would be set user controls with a pattern disk including brightness, contrast and sharpness. If calibration gear is on hand choose closest color temp and gamma settings, calibrate gray scale and CMS if it has one. Then view known content to evaluate contrast image quality, color accuracy, image noise etc etc.
Good luck with your project.
Doug
post #8 of 8 Old 12-18-2013, 05:54 PM - Thread Starter
Reefdvr27's Avatar
Liked: 1036
Simple list.
Thanks guys.
