Focus question ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-30-2013, 02:25 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Once you have established the throw distance , ...and then ajusted focus ,...after when .zooming between 16:9 & 2.35 do we have to re - focus or should it stay as is. ??
randyc1 is offline
post #2 of 6 Old 12-30-2013, 02:38 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Refocus.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 6 Old 12-30-2013, 03:20 PM
d.j.'s Avatar
Quoted: 167 Post(s)
Liked: 73
what projector do you use ?
dj
d.j. is offline
post #4 of 6 Old 12-30-2013, 06:12 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Originally Posted by airscapes View Post
Refocus.
...Ya OK refocus, thanks
randyc1 is offline
post #5 of 6 Old 12-30-2013, 06:13 PM - Thread Starter
randyc1's Avatar
Quoted: 238 Post(s)
Liked: 40
Epson 6030UB ,
randyc1 is offline
post #6 of 6 Old 12-30-2013, 06:57 PM
Seegs108's Avatar
Quoted: 4224 Post(s)
Liked: 2095
The only time you wouldn't have to refocus would be on projectors that have lens memories. These are typically newer projectors released within the past 2-3 years. But then again, it's been shown that lens memories aren't always 100% accurate when going to and from each memory, so it's still good to double check the focus to make sure it's where it should be.
Seegs108 is online now
