JVC DLA-X500, DLA-X700, DLA-X900, RS49,RS57,RS67 HDMI Problems - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #151 of 903 Old 01-14-2014, 10:54 AM
krichter1's Avatar
Quoted: 1969 Post(s)
Liked: 2235
You should call the JVC support # in the document right away.
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is offline
post #152 of 903 Old 01-14-2014, 11:11 AM
DDMac's Avatar
This morning I successfully flashed the new firmware into my 6710 using a 32 bit windows7 laptop utilizing an on-board serial port and .NET framework 4.5.1. The flash went off without a hitch. I downloaded the zip, extracted to a desktop folder, printed the instructions, followed them exactly, and everything is golden.
I tested the various resolutions without any lockups utilizing my Lumagen 2041. I was able to get one blank screen by watching directv (1080p60) on lumagen hdmi input 1 and then switching directly to Lumagen input 2 which was my Oppo bluray player which was already playing a movie(1080p24). I turned the Oppo off and on and hdcp negotiation was established and the movie played as expected. This would have “locked” the projector up before the firmware update causing the need for a projector unplug. I have not been able to lock the projector up under any scenario I tried this morning.
Also, when focusing with e-shift off and with the built in pattern, e-shift still turns itself on. This doesn’t affect me, as I focus with the built in Lumagen patterns.
Good luck to everyone flashing-
DDMac is offline
post #153 of 903 Old 01-14-2014, 11:24 AM
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
As another data point for those choosing equipment to flash the firmware, I successfully flashed an RS-4910 using 32-bit Windows 8.1, a Sabrent SBT-FTDI USB-to-serial adapter, and a null modem patch cable from Monoprice. I haven't tested whether the update resolves the HDMI lockup issues, but the updating went smoothly.
jstach500 is offline
post #154 of 903 Old 01-14-2014, 01:03 PM
odedia's Avatar
Liked: 25
Originally Posted by rboster View Post
Here's a link to the USB-to-RS232C adapter that JVC stated they have tested the procedure with: http://www.amazon.com/gp/product/B0000VYJRY/ref=oh_details_o00_s00_i01?ie=UTF8&psc=1 .
I can say, I've used this adapter to update my Anthem Receiver's calibration setttings (all measurements are downloaded to your computer, then transferred to the receiver, which requires in the case of my laptop an adapter to the RS232C input on the back of the receiver). This adapter has worked perfectly each time I've used it. For a computer illiterate like myself, I need things to work right the first time (don't have the knowledge to create a work around wink.gif ).
Mike: excellent advice on waiting till others (who are more experienced than me) have successfully run the download through it's paces.
Ron
PS: Now I have two pieces of electronics that use the adapter...$24 well spent.
Can you also link to the null modem cable thing that you use? I'd hate to get the wrong thing.
odedia is offline
post #155 of 903 Old 01-14-2014, 01:06 PM
Moderator
rboster's Avatar
Quoted: 1049 Post(s)
Liked: 1018
Sorry, the cable I used came with the anthem receiver. Here's one that would do the trick:
http://www.amazon.com/StarTech-com-10-Feet-RS232-Serial-SCNM9FF/dp/B00006B8BJ/ref=pd_sim_e_1
edit: linked the correct F/F cable
FS: HDBaseT HDMI Cable extender Kit (up to 100 ft) for $75 : http://www.avsforum.com/forum/210-vi...l#post52653465//
rboster is online now
post #156 of 903 Old 01-14-2014, 01:12 PM
jjcook's Avatar
Quoted: 349 Post(s)
Liked: 146
Sorry, the cable I used came with the anthem receiver. Here's one that would do the trick: http://www.amazon.com/StarTech-com-10-Feet-RS232-Serial-SCNM9FM/dp/B00009ADGW/ref=sr_1_5?s=electronics&ie=UTF8&qid=1389733568&sr=1-5&keywords=RS232+Serial+Null+Modem+Cable
Don't you need a female-female cable if you're using the Tripp Lite Keyspan? The linked cable is male-female. The JVC is a male connection as is the Keyspan.
Σ Info: Δ 8.5' viewing distance AT screen fabrics comparison
Σ Builds: Δ HT 2.0 renovation with acoustic coffered ceiling (in progress, 10% completed)
Δ Variable-aspect screen with motorized masking (on hold, have parts)
jjcook is online now
post #157 of 903 Old 01-14-2014, 01:16 PM
jstach500's Avatar
Quoted: 44 Post(s)
Liked: 43
Here's the Monoprice null modem cable (female-female) that I used to successfully flash the 4910: http://www.monoprice.com/Product?c_id=102&cp_id=10212&cs_id=1021205&p_id=478&seq=1&format=2
post #158 of 903 Old 01-14-2014, 01:22 PM
Moderator
rboster's Avatar
Liked: 1018
You are correct. replaced link wth proper product. http://www.amazon.com/StarTech-com-10-Feet-RS232-Serial-SCNM9FF/dp/B00006B8BJ/ref=pd_sim_e_1
post #159 of 903 Old 01-14-2014, 02:36 PM
noah katz's Avatar
Quoted: 1006 Post(s)
Liked: 344
Someone tried the update with that one and it didn't work.
I got the one JVC recommends:
http://www.ebay.com/itm/160804080791?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Noah
noah katz is offline
post #160 of 903 Old 01-14-2014, 03:11 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1011
NOAH. Just so it is clear to all, is the DB9 connector on the Trip Lite unit wired as a null modem connector or does it require an additional null modem cable to present the correct pin connections to the JVC?
mark haflich is offline
post #161 of 903 Old 01-14-2014, 03:16 PM
wse
wse's Avatar
Quoted: 2194 Post(s)
Liked: 804
wse is offline
post #162 of 903 Old 01-14-2014, 03:28 PM
noah katz's Avatar
Liked: 344
Beats the heck out of me I was just repeating what JVC used.
Noah
post #163 of 903 Old 01-14-2014, 04:14 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3641 Post(s)
Liked: 3617
Having had issues with trying to download firmware updates to my Lumis Host ( which I'm 99% sure were due to a USB - serial cable problem ), I'd just use whatever cable JVC recommends and says works. I isn't worth trying something else - especially to try and save $ 5.00 !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #164 of 903 Old 01-14-2014, 04:32 PM
Liked: 1011
I agree but it is still unknown if that converter outputs as a null modem receiving end or needs the addition of a female to female null modem cable to convert it? The trip lite unit looks like it has male outs and the JVC connector is male, so a female to female cable would be needed if a conversion to null modem is required.
post #165 of 903 Old 01-14-2014, 04:40 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3617
Don't know Mark, but JVC says this one works - http://www.staples.com/Staples-USB-to-Serial-Adapter/product_837560
If it works for them it should works for others !
post #166 of 903 Old 01-14-2014, 04:52 PM
Liked: 1011
Normally, as in my Lumagen, I use a converter and a null modem cable is still required. Sooner or later someone here will just use the linked converter and tell all whether the end is already wired as a null modem receiver end or whether a cable is still needed. Right now you don't know and neither do I or anyone else. Here's hoping one does not need a cable in addition but if one does its no big deal. Radio shack sells them over the counter. Most null modems are not female to female so a sex change adapter or two might be needed.
post #167 of 903 Old 01-14-2014, 05:23 PM
Schwa's Avatar
Quoted: 1089 Post(s)
Liked: 1145
If you look at JVC firmware install instructions, they recommend the Keyspan USB-to-RS232 adapter AND they state that a null modem cable is still required. In other words (and I'm surprised Mark hasn't said this yet), RTFM. tongue.gif
krichter1 likes this.
Schwa is offline
post #168 of 903 Old 01-14-2014, 05:33 PM
Seegs108's Avatar
Quoted: 4671 Post(s)
Liked: 2317
For those looking to spend less, this will work too and is much cheaper:
http://www.amazon.com/exec/obidos/ASIN/B008634VJY
It also specifically states it's a "Null Modem" cable. When having to update the firmware on an old Sharp XV-Z20000 it also had to be a Null Modem cable and that cable worked perfectly fine. Just make sure you install the drivers. They come with the cable or they can be downloaded from the manufacturer's website here:
http://www.startech.com/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
Seegs108 is offline
post #169 of 903 Old 01-14-2014, 05:41 PM
lovingdvd's Avatar
Quoted: 2767 Post(s)
Liked: 590
Originally Posted by spcav View Post
i just tried updating my X700
flash starts, communiucates with jvc (bottom bar indication) but after of 5 secs I get the message
OPERATION FAILED (PROGRAMMING) FAILED TO SEND DATA TO THE DEVICE
then JVC remains in programming mode (even after power disconnect) and cannot start
any ideas (even how to exit programming mode)?
Were you able to get it out of programming mode??
lovingdvd is offline
post #170 of 903 Old 01-14-2014, 06:27 PM
krichter1's Avatar
Liked: 2235
Yeah... I wanna know too since he sounded frantic (and it sounded bad).
Kevin
post #171 of 903 Old 01-14-2014, 06:45 PM
krichter1's Avatar
Liked: 2235
Are you saying you know it'll work because you just updated your PJ or are you saying in your opinion you think this one should work and it's an edjamucated guess? wink.gif
Kevin
post #172 of 903 Old 01-14-2014, 07:06 PM
Schwa's Avatar
Liked: 1145
Hey, guess what? it doesn't work. I tried it today and got an autobaud error. And that exact cable worked fine to control my 4810. The update software's webpage says wonky cables are the #1 cause of the autobaud error. So, I ordered the cable that JVC recommends and will be using that tomorrow. Just because the cable works in one use case doesn't mean it'll work in another.
Before making recommendations you might want to actually try the product you're recommending. rolleyes.gif
Schwa is offline
post #173 of 903 Old 01-14-2014, 07:07 PM
Seegs108's Avatar
Liked: 2317
Originally Posted by Schwa View Post
Hey, guess what? it doesn't work. I tried it today and got an autobaud error. The update software's we page says wonky cables are the #1 cause of this error. So, I ordered the cable that JVC recommends and will be using that tomorrow.
What did you set the baud to? There's no reason why this cable shouldn't be working. I've seen this exact cable recommended multiple times for this exact use with many other projectors including my old Sharp XV-Z20000.
Seegs108 is offline
post #174 of 903 Old 01-14-2014, 07:15 PM
Schwa's Avatar
Liked: 1145
57600 just like the instructions indicated.
If I try the Keyspan cable tomorrow and it doesn't work either I'll start looking for other causes. I'll also eat my hat. But I'm inclined to believe it's the cable based on the software's help page.
Schwa is offline
post #175 of 903 Old 01-14-2014, 07:18 PM
zombie10k's Avatar
Quoted: 3232 Post(s)
Liked: 3323
I am seeing the autobaud error with my lumagen cable + prolific USB -> serial adapter that I use all the time with my Cisco gear and also previous flashed the RS55 with it. Perhaps this flashmagic application is more restrictive.
changing baud rates doesn't help from what I've tried so far. My patience is thin tonight so I am rigging up my Optiplex 755 desktop which has a serial port on it. let's see how that goes.
zombie10k is offline
post #176 of 903 Old 01-14-2014, 07:20 PM
Seegs108's Avatar
Liked: 2317
And you checked what the port itself is set to by going into the device manager and setting it under the properties of the device? Sometimes there is a software/hardware mismatch that can cause abnormalities. There seems to be an issue like this if you're getting a baud type issue. Not quite sure what "autobaud" is.
Seegs108 is offline
post #177 of 903 Old 01-14-2014, 07:25 PM
dsanchez33's Avatar
Mike - thanks for posting the new firmware. I just did this update on my RS4910 and confirmed the new firmware version (r1210.3) shows up in the information menu. I used a null modem cable with an XP laptop that had a RS232 port. I have been testing (switching between various sources) for about 45 minutes now with no lockups. My screen just arrived so I will do some more testing after I get it setup / installed and report back if any lockups occur.
Craig Peer likes this.
dsanchez33 is offline
post #178 of 903 Old 01-14-2014, 07:29 PM
Schwa's Avatar
Liked: 1145
I used a Windows 7 virtual machine on my MacBook Pro earlier today when I had problems with the autobaud error. Just to rule VM issues out (although I still have a feeling it's the cable) I installed Windows 7 on the same computer, this time using Boot Camp, so it'll run natively. I hope it works when I get my Keyspan cable because the only machine I have with a serial port is an old netbook and I really don't feel comfortable using that slow POS.
Schwa is offline
post #179 of 903 Old 01-14-2014, 07:32 PM
Liked: 1011
Man. This is a collective effort to help all get the update done. Please let's not fight. When someone gets it done, share the equipment you used, problems, and solutions. For some this should be a piece of cake, others will have problems understanding everything and everything that needs to be done to get it to work. Com ports, yada yada. Let's help each other and verify what works. Loading drivers etc is not simple for all. Its not a contest, there is no prize for finding a cheaper solution which might work with extra work. I am going to stay out of this from no on.
When someone is successful with the JVC recommended converter, with nothing else needed or not, please let all know. If some other converter works post that. Remember not all here are skilled in all the stuff and steps needed.
post #180 of 903 Old 01-14-2014, 07:38 PM
lovingdvd's Avatar
Liked: 590
Great to hear the encouraging reports of no more lockups, from those who have been able to get it to run. Seems odd that the process is so dependent on the specific types of USB-RS232 adapters, but great to hear the encouraging results.
In addition to there not being any lockups, how quick is HDMI handshake compared to other displays and earlier JVC model? Because its great that its fixed, but hopefully its quick and not sloppy about the handshake as some displays are.
Jvc , Jvc Dla X700r , Jvc Dla X900r , Jvc Dla Rs66
