JVC Newbies Tips, Tricks and Recommendations Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 106 Old 02-22-2014, 02:02 AM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2582
None of the home theater projectors that offer a "panel alignment" feature do it in a physical fashion. It is all done digitally through video processing software. This is why you should only use this feature in moderation. After a certain point you're doing more harm than good and you'll start to notice a less refined image.
Seegs108 is offline
post #92 of 106 Old 02-22-2014, 08:23 AM
cardoski's Avatar
Quoted: 1589 Post(s)
Liked: 1746
Originally Posted by 42Plasmaman View Post
Does the JVC actually move each panel or is it a digital/SW adjustment/alignment ?
I am not certain, but what odedia says makes sense to me.
As for focus, since I posted the focus tip i have learned of a better focus technique by a member. Use a green window from the Rec709 disc, this allows you to see the pixel grid, I was able to get the focus very tight that way. As in my other tip turn E-shift off.
It's always in the last place you look.
cardoski is online now
post #93 of 106 Old 02-23-2014, 08:01 AM
stef2's Avatar
Quoted: 423 Post(s)
Liked: 257
Originally Posted by odedia View Post
Alm
almost positive its digital. You can fix very specific regions while not impacting others. I doubt that's possible by really moving the panels.
I believe the same. I did adjust the convergence on my RS57 using a very minor global adjustments and finally various minor local adjustments. Convergence was perfect around the middle of the screen and gradually got worse as I got closer to the edges of the screen. I checked resolution patterns with and without the correction applied (it is easy to switch the panel aligment correction on and off quickly) and I saw no loss of resolution whatsoever, just sharper, more defined lines. Of course, the difference is harder to see with real video material, but the picture looks sharper to my eyes with panel alignment correction applied, and this is more obvious as I look closer to th edges of my screen, even with real video material.
BTW, I dont mean to say my RS57 had bad convergence from the factory. In fact, the whole center area of the screen had perfect convergence, and the lens (more than panel alignment) probably causes the slight convergence errors I see around the screen. No matter, JVC provided a nice feature to fix this, and to me it leads to subjectively improved perceived image quality.
stef2 is offline
post #94 of 106 Old 02-23-2014, 03:38 PM
jbryngelson's Avatar
Does anyone have a screen size over 120" Diag (over 60" high) in a light controlled room? It appears that the newer projectors will not put more than 12fL of light on a 100IRE window above this size. What is your size and experience?
Jeff in Detoirt
jbryngelson is offline
post #95 of 106 Old 02-24-2014, 01:11 AM - Thread Starter
odedia's Avatar
Liked: 25
Jeff in Detoirt
I have a 140" 2.35:1 1.0 gain which is about 150" in 16:9 terms. I mostly watch in a dark room but the walls are light color. No clue what's FL or anything like that, but honestly it looks great for 2D and 3D. I did set the envrionment setting in the menus and I think it helps a bit. For 3D 2.35:1 I would still go with high lamp mode, for 16:9 (which is about 115") I don't see the need, low lamp is sufficient. Note that this is with JVC/XPand glasses, with the samsung glasses I had terrible experience.
In 2D I'm using low lamp all the way.
odedia is offline
post #96 of 106 Old 02-24-2014, 04:39 PM
Thanks OD. What model do you have? Your screen must be about 55"H. Do you mask L & R side to get 16x9? How long have you had this?
post #97 of 106 Old 02-25-2014, 08:14 AM - Thread Starter
odedia's Avatar
Liked: 25
For about a month. I don't mask because it's really not bothering me on the sides. It's driving me insane up and down though,even a small strip is annoying. Humans perceive visuals vertically more that horizontally.
I have a grandview screen. It uses da lite Matt white 1.0 fabric.
odedia is offline
post #98 of 106 Old 03-01-2014, 11:02 PM
JOE-C's Avatar
This may be a dumb question but is there another way to bring up focus without the internal grid with the word "focus" coming up and if so how do you get there ( in order to use the Rec709 disc instead )- in other words where is that in the menu?
JOE-C is offline
post #99 of 106 Old 03-02-2014, 06:58 AM
deewan's Avatar
Quoted: 294 Post(s)
Liked: 287
Go into the menu for lens control (or whatever it is called) and turn off the pattern option. Then when you enter the focus option only the word focus will display in the upper right hand corner and you can use whatever is projected on the screen to focus (aka when using a calibration disc).
deewan is online now
post #100 of 106 Old 03-02-2014, 07:47 PM
ultimate_ed's Avatar
I'm looking at about the exact same screen setup that you have - dimension wise. I'm curious - how far back from the screen in your projector?
ultimate_ed is offline
post #101 of 106 Old 03-03-2014, 04:07 PM
deewan's Avatar
Quoted: 294 Post(s)
Liked: 287
Who exactly is your question directed towards?
post #102 of 106 Old 03-04-2014, 10:21 AM
Hmm, I must have just hit reply instead of quote on that last one. I was directing my question at Odedia.
post #103 of 106 Old 03-05-2014, 03:47 PM - Thread Starter
odedia's Avatar
Liked: 25
My screen is right at the edge of filling the image for 2.35 content, around 4.50 meters.
odedia is offline
post #104 of 106 Old 03-05-2014, 03:57 PM
Thanks - in that case, I should be in good shape. My distance it going to be right about 15 feet, which is just a little over your 4.5 meters.
post #105 of 106 Old 04-03-2014, 08:14 AM
sk576c's Avatar
Quoted: 27 Post(s)
So I love the richness of the image in THX. But the black crush and shadow detail are horrible. Has anyone without extra calibration equipment (metets/Lumagen etc) got any suggestions on settings to obtain the THX image richness while obtaining better shadow detail/black crushing?
sk576c is offline
post #106 of 106 Old 04-03-2014, 09:12 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4144 Post(s)
Liked: 4222
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
Jvc Harx500 Over The Ear Headphones , Jvc Dla X700r , Onkyo Tx Nr709
