Sony 95ES , Panny 8000 or JVC X35 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-28-2014, 04:23 AM - Thread Starter
Yukichon's Avatar
Quoted: 145 Post(s)
Liked: 59
Hi
I'm very close to deciding on a new projector. I would appreciate advice on what you would choose.
I would like to use a 2.35:1 screen but it's not the be all and end all. First row of seats will be approximately 10 ft from the screen and I would prefer to ceiling mount the PJ. The room size is 18'3 x 17'
Up to now I've been using an InFocus IN82..... Thanks
Yukichon is offline
post #2 of 9 Old 02-28-2014, 06:52 AM
Mike Garrett's Avatar
Quoted: 5609 Post(s)
Liked: 3591
The 95 is not near as bright as the IN82. IN82 is about 1.4 times brighter. The 95 would have much better contrast. What size and gain screen are you wanting to go to and what are you using now?
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 9 Old 02-28-2014, 07:39 AM - Thread Starter
Yukichon's Avatar
Quoted: 145 Post(s)
Liked: 59
Current screen is a 92" Grandview with a 1.1 gain so quite low
Yukichon is offline
post #4 of 9 Old 02-28-2014, 10:30 AM
jbn008's Avatar
Quoted: 100 Post(s)
Liked: 48
I used a 95 on a 138" (diagonal) 1.1 gain screen 2:35 screen with good results. I have a light controlled room and kept the lamp on high, but Sony's high lamp noise is just as silent as most company's low mode. I would definitely choose the Sony or JVC (owned 6 JVCs) over the Panny.
Headless Petie
jbn008 is online now
post #5 of 9 Old 02-28-2014, 10:30 AM
Liked: 3591
A 95 will not have any problem lighting up that screen. I am assuming that you have somewhat light control. smile.gif
post #6 of 9 Old 02-28-2014, 10:52 AM - Thread Starter
Yukichon's Avatar
Quoted: 145 Post(s)
Liked: 59
This new PJ choice will also be going onto a new screen, looking at around 137" ......really impressed with the Screen Innovation LED lit Slate no edge screen but it's around $4000
The PJ will be going into a new dedicate theatre that will be completely light controlled
Yukichon is offline
post #7 of 9 Old 03-05-2014, 09:20 AM - Thread Starter
Yukichon's Avatar
Quoted: 145 Post(s)
Liked: 59
After lots of questions and advice, think I'm settling for the JVC RS4910
Yukichon is offline
post #8 of 9 Old 03-05-2014, 09:24 AM
DavidHir's Avatar
Quoted: 1709 Post(s)
Liked: 1331
Why was the 95ES discontinued? Seems like Sony doesn't have that mid point projector right now.
DavidHir is online now
post #9 of 9 Old 03-05-2014, 12:54 PM
Liked: 3591
They do have a big hole in their line up. We have some of the 95 B-stocks coming in tomorrow. smile.gif
Jvc Dla X35 3d Hd Front Projector , Panasonic Ptae8000u Hd Projector , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
