Screen going completely black for a second - AVS Forum | Home Theater Discussions And Reviews
Old 03-14-2014, 06:45 AM - Thread Starter
maril555's Avatar
I got new Panasonic PT-8000 just a month ago. I have only PS4 connected to it.
And here is a problem I've been having- periodically it goes completely black (no picture, just black screen) for a second, or two.
It would go for a cycle of 5-10 blackouts every 15-20 seconds, and then would work fine again for an hour or two.
Does anyone has, or had this problem?
My first question is: is it due to a projector or PS4?
And the second question is- how to fix it? (duh...)
Thanks for your help
maril555 is offline
Old 03-15-2014, 08:49 AM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Do you loose audio or just picture?
trans_lux is offline
Old 03-15-2014, 02:17 PM - Thread Starter
maril555's Avatar
Just picture
maril555 is offline
Old 03-15-2014, 02:18 PM - Thread Starter
maril555's Avatar
And BTW, PS4 audio out is connected to A/V processor, and video directly to the projector via HDMI
maril555 is offline
Old 03-15-2014, 07:42 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
If it was an HDMI handshake issue you'd likely loose audio.
Couple questions:
To confirm your using the HDMI for audio, not the optical connection?
Is it on all sources or just the PS4?
Both games and movies from the PS4?
When you loose picture do you see any on-screen messages like searching for signal?
What happens if you set the output resolution on the PS4 to the next step down-like 1080i or 720P?
Old 03-16-2014, 07:58 AM - Thread Starter
maril555's Avatar
Couple questions:
Audio from PS4 is optical, HDMI only carries video directly to projector, and not through the A/V processor.
PS4 is the only source
Both movies and games
There are no message, it is really very short, probably a second, or so, in a series of 5-6 at a few seconds intervals,
and doesn't happen every time I use it.
I haven't tried to change an output resolution
maril555 is offline
Old 03-16-2014, 08:05 AM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Ok so it could be a handshake issue as you would not loose audio as you are connected-I don't think.
Try lower the output resolution, if you have no issues this could point to the HDMI cable to the projector.
How long is the cable from the PS4 to the projector?
Old 03-16-2014, 08:50 AM - Thread Starter
maril555's Avatar
Cable is about 15 ft long
maril555 is offline
