JVC DLA X500R Calibration help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-20-2014, 11:06 AM - Thread Starter
vikram2003's Avatar
I have just ordered my JVC DLA X-500R & would appreciate some advice as to how should I calibrate my projector to get the best out of it?
Are there any software/light meters that you would like to suggest?
I'm considering CalMan 5 Control with either OEMi1 Display or SpectraCal C6.
Your feedback will be very valuable for me.
Thanks a lot in advance.
vikram2003 is offline
post #2 of 9 Old 03-20-2014, 11:09 AM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
You can get the Basic Calman which is $350 with the bundle.
blee0120 is online now
post #3 of 9 Old 03-21-2014, 05:46 AM
stef2's Avatar
Quoted: 332 Post(s)
Liked: 212
I just ordered a Chromapure package for my RS57 from curtpalme.com, along with an eye1 display pro.
stef2 is offline
post #4 of 9 Old 03-21-2014, 06:06 AM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
From what I understand CalMAN will eventually implement an autocal feature for the 2014 JVC PJ line up, like they have for earlier models.
_____
Axel
Axel is offline
post #5 of 9 Old 03-21-2014, 06:07 AM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 949 Post(s)
Liked: 2913
Greetings,
I use Calman 5 Control along with the C6 meter. I have used the Auto calibration with the JVC RS55 and it worked quite well. The auto calibration with Calman Control for the new JVC line hasn't been implemented by Spectracal just yet. I have done a manual calibration on my RS4910 and the results are excellent. I look forward to giving the auto calibration a go as it makes touch ups a snap...smile.gif
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
post #6 of 9 Old 03-21-2014, 10:30 AM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Ralph;
A few quick questions about the the CMS of the RS4910, if I may:
How 'sophisticated' is its CMS, i.e. max. # of points for gray scale? Color gamut: primaries only or also secondaries? Cube?
~Axel
Axel is offline
post #7 of 9 Old 03-21-2014, 04:33 PM - Thread Starter
vikram2003's Avatar
Originally Posted by Ralph Potts View Post
Greetings,
Thanks you all very much for the feedback. I will wait for CalMan to come out with an upgraded version with support for 2014 JVC line.
post #8 of 9 Old 03-21-2014, 04:54 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3029 Post(s)
Liked: 2958
In the mean time, email me at craig@avscience.com and I'll send you some " out of the box " settings to use. smile.gif
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #9 of 9 Old 03-23-2014, 09:17 AM
Ranger's Avatar
Greetings,
Hi Ralph,
Would it be possible for you to share your settings of the RS4910 ? Thanks
Ranger is offline
