JVC RS45U Warning Light Blinks 5 times - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By rboster
post #1 of 7 Old 04-13-2014, 11:38 AM - Thread Starter
dfresco's Avatar
Hi all,
My projector has been working just fine, however, I turned it off and all of a sudden I have:
red - standby light
orange - lamp light
red light blinks 5 times continuously on the warning light.
In the manual it only shows up to 4 blinks of the warning light and I was wondering if anyone knows what this means?
The projector will not power up anymore.  I have unplugged it over night but to no avail.
dfresco is offline
post #2 of 7 Old 04-15-2014, 08:58 PM
veinboy's Avatar
You may need a new processor board.
It runs $449 plus tax and shipping.
But I would call JVC support first.
That fixed my flashing lights and recurring lock up problem on my RS 40.
veinboy is offline
post #3 of 7 Old 07-28-2014, 04:46 PM
yeephok's Avatar
Originally Posted by dfresco View Post
<p>Hi all,</p>
<p> </p>
<p>My projector has been working just fine, however, I turned it off and all of a sudden I have:</p>
<p> </p>
<p>red - standby light</p>
<p>orange - lamp light</p>
<p>red light blinks 5 times continuously on the warning light.</p>
<p> </p>
<p>In the manual it only shows up to 4 blinks of the warning light and I was wondering if anyone knows what this means?  </p>
<p> </p>
<p>The projector will not power up anymore.  I have unplugged it over night but to no avail.</p>
<p> </p>
<p>Thanks!</p>
Hi, I have a RS-45 with the Warning Light Blinking 5 times. Both Standby Light is a constant Red and the Lamp Light is a constant Orange. This occurs about 10 seconds after plugging in the projector. Unable to switch on the projector.
How was your problem solved in the end? Was it a replacement of the CPU Board?
Thanks in advance for your help!
yeephok is offline
post #4 of 7 Old 07-28-2014, 05:20 PM
Moderator
rboster's Avatar
Quoted: 1211 Post(s)
Liked: 1307
I wouldn't count on getting a response from the original poster, he hasn't been on avs since the day he posted the question. Hopefully, someone can provide some assistance
Ron
yeephok likes this.
rboster is offline
post #5 of 7 Old 07-28-2014, 06:22 PM
yeephok's Avatar
Unhappy
Ron
OK! Thanks for the heads-up.
yeephok is offline
post #6 of 7 Old 07-29-2014, 06:47 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
A wiser man than most of us.
mark haflich is offline
post #7 of 7 Old 08-08-2014, 06:33 AM
someoledude's Avatar
Quoted: 14 Post(s)
Yep I went through similar issues with blinking lights,freezing, inability to power off,blue color checkerboards, generally making it unusable. I sent it in for service and it was fine afterwards. Firmware updates and other user interventions did not solve the issues. Contact JVC to get started.
someoledude is offline
