panasonic pt-ae8000u LCD Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-25-2014, 08:45 PM - Thread Starter
edgerunner's Avatar
When I power on my projector it runs for 10-20 seconds....nothing coming up on the screen. Then the fan starts to really get going and the temp light starts to flash. I don't know what this means, and it hasn't ever done this before. It has been several days since using the unit. I could understand if it were on for a long period of time before the temp light comes on but it comes on almost immediately. Any insight would be awesome!
edgerunner is offline
post #2 of 3 Old 04-25-2014, 10:12 PM
dragonleepenn's Avatar
Quoted: 193 Post(s)
Liked: 85
You may have a clogged filter, or some obstruction. Vacuum the filter and check the unit for other areas it may be stopping free air flow. Good luck.
PeterV
dragonleepenn is offline
post #3 of 3 Old 04-26-2014, 06:02 AM - Thread Starter
edgerunner's Avatar
Thanks, but have already tried this. After reading the manual I think it has a bad temp sensor. Which is strange because I haven't had but about 7-8 months. I contacted Panasonic support and I'm waiting for their response. You don't have any other ideas do you?
