Help please. Best Multi-Use Projector for $5k or less. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-20-2014, 06:32 PM - Thread Starter
bearcat2002's Avatar
Quoted: 44 Post(s)
Hey everyone, I am looking to be building a theater room that will be about 16' deep by 19' wide and was looking for a bit of help in determining the best projector for the room. Its going to be shining on a 120" screen and will be for multipurpose use, tv watching, lots of sports, and some gaming. The room will have a small amount of noncontrolled light during the daytime but nothing direct. I'd like to mount it on a shelf that will be built into the ceiling so I'd like one fairly slim (6-8"). The ceiling will be 8'8" so the projector would have to have a fair amount of vertical lens shift too as I can mount it pretty much central to the screen. I'm looking to spend about $3-5k and after looking at post after post, I felt overwhelmed and just needed to ask for help. I see Epson 5030 and 6030 all over the place but just didn't know if there would be a better option for another $2k or so. Any recommendations would be greatly appreciated. Thanks again! -Bearcat
bearcat2002 is offline
post #2 of 9 Old 07-20-2014, 06:48 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Why not consider the JVC 4910 (500) It is an amazing projector for under $4,000. Contact Mike at AVS for more information. You can also check out the threads on the projector.
rwestley is offline
post #3 of 9 Old 07-20-2014, 07:18 PM - Thread Starter
Quoted: 44 Post(s)
I will look into it. I am totally open for suggestions. You feel it's way better than the epson?
post #4 of 9 Old 07-20-2014, 07:22 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
I suggest that you look at the reviews and you will see that the JVC RS4910 is really this years best buy in a projector under $5,000. The blacks are amazing. I don't feel the Epson is in the same league.
rwestley is offline
post #5 of 9 Old 07-20-2014, 10:16 PM - Thread Starter
Quoted: 44 Post(s)
Are the upper jvcs much better? Would an sony 500es be better than the jvcs?
post #6 of 9 Old 07-21-2014, 04:51 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
The RS4910 represents the best buy in the JVC line. The difference is not that great with the more expensive units. The Sony 500ES (600) is a 4K projector and at this point there is not much 4K available. It is a great projector but at this point unless you want to spend between $10,000-15,000 for a projector you are would probably be better off the the RS4910.
rwestley is offline
post #7 of 9 Old 07-21-2014, 06:03 AM - Thread Starter
Quoted: 44 Post(s)
Ok, I'm looking into the jvc 4910, and so far it seems pretty awesome. Only thing I see is there has been a firmware problem, do you know if this is resolved? Thanks man?
post #8 of 9 Old 07-21-2014, 06:39 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
The firmware problems have been resolved If you buy from Mike at Avs they will update firmware to latest version before it is delivered
rwestley is offline
post #9 of 9 Old 07-21-2014, 10:13 AM
Mike Garrett's Avatar
Quoted: 5605 Post(s)
Liked: 3588
Sent you a PM.
mjgarrett100@gmail.com
Mike Garrett is offline
