Best mount location for JVC X55R - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-28-2014, 06:10 AM - Thread Starter
jchambers_18's Avatar
Quoted: 17 Post(s)
I recently purchased a X55R and would like to mount it soon as I have it sitting on a box on a sofa table behind the sectional. My room is 22' deep, 9' ceiling, and 139" 2.39 DIY flexi-white 1.1 gain screen. I am planning on building a soffit around the room at around 10" or 12" by 24" or 30". I am going back and forth on ceiling mount or shelf mount and what range would be better. I see the projectorcentral calc says between 15' and 30'. At 15' it is obviously brighter at 21fL according to the calc. At 20' looking around 16 fL. Oh yeah top of screen is 18" from ceiling now. What would you all do?? Thanks!
James
jchambers_18 is offline
post #2 of 10 Old 07-28-2014, 08:19 AM
Mike Garrett's Avatar
Quoted: 6712 Post(s)
Liked: 4402
James
That calculator is way off for the JVC. You will not get that bright of an image. I would mount toward the short end of the throw range. I am assuming you are talking 139" diagonal screen, not width.
mjgarrett100@gmail.com
Mike Garrett is offline
post #3 of 10 Old 07-28-2014, 08:25 AM - Thread Starter
Quoted: 17 Post(s)
Yes 139" diag 2.39 screen. I am kind of guesstimating the size because I added more on each side for black borders to cover but have not done that yet and the way i am going to do it will take a little away from the top and bottom but not the sides as I still have a little black bar at top and bottom. Right now it is 144". I want to get the best image quality I can get and still possibly run a 3d movie every now and then. So you would stick with around 15'? If the calc is wrong I wonder if i could move it even closer than that? Thanks for the reply Mike!
post #4 of 10 Old 07-28-2014, 10:06 AM
Liked: 4402
You will not have good brightness on a scope 3D movie and I would place the projector a few inches short of minimum throw range.
post #5 of 10 Old 07-28-2014, 10:11 AM - Thread Starter
Quoted: 17 Post(s)
You mean shorter than the calc minimum distance? So the minimum says 14' 11". Are you saying go short of that and see if it still fills the screen?
post #6 of 10 Old 07-28-2014, 10:35 AM
Liked: 4402
No, I am saying to use a throw a few inches longer than the minimum. Sorry, my wording was not clear.
post #7 of 10 Old 07-28-2014, 10:46 AM - Thread Starter
Quoted: 17 Post(s)
Gotcha! Thanks again for the assitance. Do you think a 3d movie will be watchable at that distance or should i not even worry with a 3d blue ray and glasses?
post #8 of 10 Old 07-28-2014, 11:24 AM
Liked: 4402
By most people's standards, you will not have enough brightness for good 3D, when watching scope 3D.
post #9 of 10 Old 07-28-2014, 11:26 AM - Thread Starter
Quoted: 17 Post(s)
Well then I wont bother with buying a new 3d Blue ray and glasses. My 2 year old samsung will do for now. Thanks again!
post #10 of 10 Old 07-29-2014, 06:13 AM
Liked: 4402
Keep in mind, most 3D movies are 16:9, not scope. You will be fine for those, just not the scope movies.
