Can't decide which projector to get - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-03-2014, 06:38 AM - Thread Starter
Liked: 0
First off, thanks to everyone on this site for all the great information. I have been researching this for 6 months and still can't decide on a projector.
We have a dedicated theater room 18x28 and the seats are 10 to 24 feet from the screen. We will use this for a lot of TV, but also for movies. The room has no windows, but we plan to use it a lot with some lights on. I like the concept of CIH, and think I will go with a 133" 2.35 Black Diamond screen.
Budget is around $5k for the projector and I am trying to get a good picture for the large screen, good lamp for viewing with lights on and lens memory for zooming between formats.
Any help would be greatly appreciated.
DLyn is offline
post #2 of 5 Old 08-03-2014, 08:03 AM
Mike Garrett's Avatar
Quoted: 5548 Post(s)
Liked: 3538
If planning on going with CIH using lens memory, then your choices are really limited to the JVC line with that budget. If also buying a video Processor like the Lumagen, then you would be able to look at Sony and Epson. Another option would be to use an A-lens like the CineVista. All of these options are available to you at your price point. Give us a call and we can go over the advantages and disadvantages of each method.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 5 Old 08-03-2014, 08:04 AM
Liked: 3538
If planning on going with CIH using lens memory, then your choices are really limited to the JVC line with that budget. If also buying a video Processor like the Lumagen, then you would be able to look at Sony and Epson. Another option would be to use an A-lens like the CineVista. All of these options are available to you at your price point. Give us a call and we can go over the advantages and disadvantages of each method, along with pricing.
post #4 of 5 Old 08-03-2014, 09:34 AM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1319
I highly recommend giving Mike a call. He's helped me out tremendously on my set-up.
DavidHir is offline
post #5 of 5 Old 08-23-2014, 08:12 AM - Thread Starter
Liked: 0
I called him, thanks for the advice. He was great, very helpful!
DLyn is offline
