Which Device Should Process Video-Oppo>Integra>DILA??? - AVS Forum | Home Theater Discussions And Reviews
Old 08-04-2014, 12:05 AM - Thread Starter
1fzj80's Avatar
I have a Oppo BDP-103 > Integra DTC-9.8 > JVC DLA-X70.
I can pass video direct 'through' / 'source direct' to the projector or can process at the Oppo or Integra.
Which component has the best video processor?
I have tried each and it seems like it is best sending source direct from the Oppo to the Integra and then going out to the projector as 1080p. I am watching Bluray or Vudu.
Any suggestions.
1fzj80 is offline
Old 08-04-2014, 06:01 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
If you are watching a 1080p source, what exactly are you processing? You are feeding 1080p direct from the Oppo through the Integra. For Vudu, what is the source resolution? I don't know. If its interlaced, then the answer is which of the 2 units (you are not feeding the Vudu into the Oppo or are you? has a deinterlacer which favors artifacts you can stand. They all make trade offs and it becomes a question of taste and sensitivity. Most here would choose the deinterlacer in the JVC over the Integra.
mark haflich is offline
Old 08-04-2014, 10:23 AM - Thread Starter
1fzj80's Avatar
Thanks for your input.
The Oppo is a Vudu enabled device and is the source for streaming. Exactly how that works regarding the de-compression codec from source over the net and the format being sent to the Integra, I have no idea? But, I have tried using 'direct' with both the Oppo and Integra which means any necessary processing is being performed at the DILA and it looks pretty good. Streaming has come a long way.
Occasionally, I do watch DVDs and using 'direct' to the DILA doesn't always work. Sometimes the aspect ratio of the projected image is wrong. In this case, I set the Integra to 1080p out and it works good.
I usually believe the newest device is better than the older at performing the processing. The Oppo is new, the DILA is next and the Integra is circa '08. I can test various combinations of processing and compare, but was wondering if there is a suggested device/component and/or order in which the video signal should be processed as it passes from source to image.
If the DILA is suggested for processing, that is how I normally set with both the DILA and Integra in 'direct' or 'through'.
1fzj80 is offline
Old 08-04-2014, 08:30 PM
Liked: 1010
Why don't you give me a call tomorrow nighte and we can discuss. I want to take you through this aspect ratio thing. I just don't have the patience to write a long post. i'll just ask you a few questions and we will get to the bottom of your aspect problem.
Old 08-04-2014, 11:04 PM - Thread Starter
1fzj80's Avatar
Sure, if you don't mind chatting, I will call. Open to any help I can get.
1fzj80 is offline
Old 08-05-2014, 09:08 AM
Liked: 1010
Any help. In al modestly, you will get some of the best help available.
Before you call. please set your aspect ratio to to 1.78 in all three devices. the aspect ratio settings are for your screen size which I assume is a 1.78 screen.
You will see side unlit screen for any 1.33 source and top and bottom black bars for any source aspect (wide screen) higher than 1.78. Most if not all of your source frames will be 1.78 even though for wide screen stuff your active video will be at a higher aspect ratio. Not correctable without geometrically distorting the image. You can zoom to fill your screen in such cases but you will zoom part of the image off the screen.
