DLP projector posterization issue : need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-10-2014, 08:50 AM - Thread Starter
anirbana's Avatar
Hi,
I seeks some help and suggestion fixing my Infocus IN82 DLP projector. This issue affected many users of the Infocus IN80/IN81/82/83.
The issue is dicussed in detail in the owners thread here
Infocus X10/ IN80 Owners thread - Reviews, Settings, Screenshots and issues
In summary, after few months of use, the image shows up murky and blotchy colours on dark skin tones or red / green tones. Initially it affects dark scenes with mostly red tones, but later it stars affecting al colours even in bright scenes.
The exact reason is not fully understood in that thread and Infocus is not going to fix it out of warranty. In my case Infocus replaced 5 units on the same defect, but they never fixed it or bothered.
Here's what is found in most cases on this particular issue
1. Initially starts with posterised red and green tones
2. On turning Brilliant color on - it goes away (not sure why)
3. After some time turning on BC reduces the issue greatly but not eliminate it completely
4. With more time the issue becomes worse and even with BC on it becomes unusable
5. Initial 2-3 min of turning on the issue is not visible, but shows off after that - heat??
The projector without the posterization issue is excellent, but not usable now as it affects the image too much now.
The reason I am posting this here is initially I thought it was affecting mostly Infocus In8X range, but later saw some other sites where people have reported similar issues on Optoma DLPs as well. I just thought posting here may get me and some owners some help from a wider DLP community.
I'd appreciate if anyone can help with the issue and if you ahve faced something like this, what you did to get rid of.
Buying a new PJ is a easy choice, but I am not able to just throw it away without giving it a try to fix.
Here's a couple of files with both BC off (see issue with red and dark skin tones) and BC on (issue gone or reduced)
ID:	206273   Click image for larger version
ID:	206281   Click image for larger version
ID:	206289   Click image for larger version
ID:	206297   Click image for larger version
ID:	206313   Click image for larger version
ID:	206321   Click image for larger version
ID:	206329   Click image for larger version
ID:	206337   Click image for larger version
anirbana is offline
post #2 of 8 Old 08-10-2014, 12:41 PM
dovercat's Avatar
Quoted: 100 Post(s)
Liked: 45
Looks like what used to be called solarization. I would guess it could be caused by dust on the color wheel or by a timing issue which might be caused by dust on the color wheel if the color wheel sync is not by magnet, or could be caused by poor contact on a contector or ribbon cable connector in the machine or a fault on the motherboard causing a problem with something like the lower voltage differntial.
I think all you can do is clean the color wheel and the cable connectors, maybe take the lid off and redo the ribbon cable connections inside to make sure they are clean and making good contact, and hope for the best. Note if you clean any of the optics do not use any chemicals as you can destroy the ant-reflective optical coatings. If it is the motherboard I would think you are screwed.
dovercat is offline
post #3 of 8 Old 08-10-2014, 04:28 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Planar 8150 had similar issues and was color wheel timing. Using the service menu and internal color step patterns I was able to fix it by adjusting the color wheel timing.
You may also want to do a factor reset on any calibration settings just to make sure something is not pushed to far and causing bit loss. I would think not since it comes and goes.. may be a component on a board someplace or connector as was suggested.
Good luck!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 8 Old 08-10-2014, 06:40 PM
danieledmunds's Avatar
Quoted: 20 Post(s)
Liked: 25
I called Infocus about this issue when I was thinking about buying an IN83 and they said it was due to dust build up and overheating. They said, in particular, the housing around the bulb needs to be cleaned thoroughly. Mine is 6 years old and so far shows no signs after a lot of use but I do clean it once a year and only use with the AC on.
Certainly with processors if they overheat a couple of times they tend to be more prone to overheating in general. Not sure if the same thing is happening with DLP chips or whatever controls the colour wheel.
danieledmunds is offline
post #5 of 8 Old 08-12-2014, 08:54 AM
David44's Avatar
Curious if your IN82/83 is ceiling or shelf mounted?
Reason for asking is that there are 2 intake vents on the bottom of the case where if shelf mounted on just the rubber nubs, there is very little space for airflow.
Does "source" make a difference on your PJ?
I notice the posterization on local & cable/satellite channels, but Brilliant Color seems to fix it. Never encountered the issue on "Casino Royale" or "Oblivion" blu-rays. But posterization did appear during "This is the End" blu-ray. (terrible movie), and Hobbit #2 that was streamed from Directv.
Finally, Brilliant Color: Is it software, or an optical (physical) adjustment to, say, the color wheel speed?
**Edited to read "posterization" and not "polarization". Guess that's better than "pasteurization".
David44 is offline
post #6 of 8 Old 08-12-2014, 09:32 AM
dovercat's Avatar
Quoted: 100 Post(s)
Liked: 45
Brilliant Color changes the timings DLP to the color wheel. With Brillian Color engaged the DLP chip uses spoke time on a RGB wheel or the clear white segment on a RGBW wheel or changes how colours are created as far as using secondaries and primaries on color wheel with one or more secondaries like a RGBYMC wheel.
TI paper explaining Brilliant Color http://www.eefocus.com/data/07-01/11...1168591126.pdf
dovercat is offline
post #7 of 8 Old 08-12-2014, 05:50 PM
Quoted: 20 Post(s)
Liked: 25
I notice the polarization on local & cable/satellite channels, but Brilliant Color seems to fix it. Never encountered the issue on "Casino Royale" or "Oblivion" blu-rays. But polarization did appear during "This is the End" blu-ray. (terrible movie), and Hobbit #2 that was streamed from Directv.
Its ceiling mounted with a about half a foot behind it for airflow.
I wouldn't say that source makes that much difference, I had a PS3 hooked up to it and now a mac mini and as long as the projector was calibrated, posterisation wasn't a problem. What I have found is that it can't quite be calibrated perfectly, there seems to be slight errors in a few shades of blue but wouldn't describe it as posterisation.
I do see posterisation on my cable box but I also see that with other displays, probably just errors in the signal.
post #8 of 8 Old 08-27-2014, 04:30 PM
David44's Avatar
Originally Posted by anirbana View Post
Hi,
I seeks some help and suggestion fixing my Infocus IN82 DLP projector. This issue affected many users of the Infocus IN80/IN81/82/83.....
OP - any updates on your end? Thanks!
David44 is offline
