Question regarding Active 3D projectors - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-25-2014, 12:50 AM - Thread Starter
Liked: 0
Hi,
I have a question regarding 3D projectors.
Is it possible to use passive 3D glasses with a projector which is a Active 3D projector?
We are looking for a projector between 5000 and 10,000 Lumens (preferably Panasonic but open to other options)which is a passive 3D projector. But so far all we have been able to find is active 3D projector.
Regards.
mmobeen is offline
post #2 of 3 Old 08-25-2014, 08:24 AM
Mike Garrett's Avatar
Quoted: 7076 Post(s)
Liked: 4780
Originally Posted by mmobeen View Post
Hi,
Regards.
Passive glasses use would require a two projector setup with polarizers on them and a device to split the signal so that the image for the right eye is sent to one projector and the image for the left eye sent to the other projector.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 3 Old 08-29-2014, 06:18 PM
Hagenstein's Avatar
Quoted: 94 Post(s)
Liked: 86
And additionally, a polarization-preserving screen, just in case the OP hadn't considered that as well. Unless a chromatic solution such as Omega 3D is considered, which, while providing pretty much zero ghosting, has a few other issues to contend with.
Hagenstein is offline
