Yellow On Screen Problem - AVS Forum | Home Theater Discussions And Reviews
Old 12-25-2014, 02:50 PM - Thread Starter
Liked: 0
Question Yellow On Screen Problem
Hi,
Has anybody experienced this problem before where the white on screen turns bright yellow? It used to be intermittent but now has become a regular feature. I used to be able to fix it by rebooting the Geffen HDMI extender so I assumed that was the issue, but after moving to another extender the problem is worse.
You can see the problem on this picture where the team's white kit has yellow blotches on it.
The problem occurs on all sources (cable TV, Apple TV, Blu Ray). I am running an Oppo Blu Ray player, a JVC DLR-ILA RS65 Projector with a Rotel RSP 1572 Sound Processor.
Any help would be appreciated.
Thanks, Martin
Martin Weigold is offline
Old 12-25-2014, 07:25 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Originally Posted by Martin Weigold View Post
Hi,
Thanks, Martin
I would get a shorter hdmi and take the BR player over to the projector and see if that fixes the issue.. If so you need to eliminate the pieces in between till you isolate the problem.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
