Sony 55ES low profile ceiling mount - AVS | Home Theater Discussions And Reviews
post #1 of 6 Old 03-20-2015, 10:21 PM - Thread Starter
txmxer's Avatar
Quoted: 20 Post(s)
I have a cheap (meaning lacks precise adjustment) ceiling mount and I need to get a good one for a Sony 55ES. I'm sold on going with Chief or Peerless (unless there is something more dialed in). The ceilings are 8', and the screen is at 7'8" so my goal is to get the projector as close to the ceiling as possible.
Is there a go to on this? The RPMAU? The peerless appears to be a bit lower from the ceiling?
thanks
txmxer is online now
post #2 of 6 Old 03-21-2015, 06:47 AM
Skrill's Avatar
Quoted: 165 Post(s)
Liked: 49
I use the Peerless PRG UNV - good mount, and $100 shipped through Amazon.
Used it with my 55 and now with my 500ES.
Skrill is online now
post #3 of 6 Old 04-07-2015, 09:49 PM - Thread Starter
txmxer's Avatar
Quoted: 20 Post(s)
So, I used the Peerless PRG universal mount.
I really like the adjustability. The screw adjustment is excellent. But, after I get the projector set perfectly, I start to make adjustments to the projector--screen size and focus. The projector wobbles and the perfect alignment is gone.
Any thoughts?
I adjusted the projector where I want it for the most part. Right now, there is an inch of white space on the sides and top of the screen. The bottom is zero'd in on the border. Basically, I'm giving up that fraction at this time since I don't have a fixed screen. I suppose I could go back and tweak it a little, but, if I start moving the manual focus, I know it will affect the alignment.
post #4 of 6 Old Yesterday, 06:22 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1396 Post(s)
Liked: 765
thanks
I would use the RPA020. Has the custom plate and holds the projector a little firmer than the RPAU. If we can help you, give us a call.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Sony, JVC, Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, SVS & Def Tech, Denon, Pioneer, Marantz & Yamaha .
AV Science Sales 5 is online now
post #5 of 6 Old Yesterday, 07:44 PM
Skrill's Avatar
Quoted: 165 Post(s)
Liked: 49
Any thoughts?
I never really had this problem -- I would get the PJ right with the screws and all. Then get the lens shift and focus right. If things were a bit off -- I could fix it with just manual adjustment of the PJ at the end (i.e., a nudge or two).
Do you have the adjustment allen screws fully torqued down? I found that he needed to be quite snug. I have certainly had no issues with the Peerless mount - and am using it with my 500ES now.
post #6 of 6 Old Today, 11:49 AM - Thread Starter
txmxer's Avatar
Quoted: 20 Post(s)
Thanks, I'll double check it.
