1.8 gain screen will help my 270 lumens lcd projector ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-15-2001, 04:54 AM - Thread Starter
David600's Avatar
Location: the REAL cinema experience at home: THAT's the trick.
I currently use a Dalite 1.0 gain mat screen. unless I can work out something with the lamp ( a brigther model, but I doubt so ), is this gain increase results in significant increased brightness ?
thanks
David
for cinema sound in your HT, use cinema speakers and cinema amps! unbeatable.
David600 is offline
post #2 of 3 Old 04-15-2001, 09:46 PM
KFung's Avatar
Yes a higher gain screen will definitely help! It should make you image 80% brighter, just like you'd expect from the gain numbers. That's quite a bit and hopefully there will be little or no hotspotting.
Kam Fung
KFung is offline
post #3 of 3 Old 04-16-2001, 12:53 PM
Sublime's Avatar
You're probably aware of this, but you're trading viewing angle for straight ahead brightness. No free lunches.
Sublime is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
