whisper/flow - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-10-2001, 12:36 PM - Thread Starter
kenh's Avatar
Has anyone measured the temp. of the the inside of a Whisper/Flow hushbox using a DILA, and also how does it handle the stray light that comes out the intake and exhaust of the Dila. since it is constructed of clear Plexiglass wouldn't that let the light go threw. thanks
kenh is offline
post #2 of 13 Old 04-10-2001, 12:50 PM
tommyboy2's Avatar
The light isn't blocked in any way since it is clear plexiglass. I think Dave Beatty told me he could build it out of colored plexiglass though for a little extra $$.
I use a thermostat in my whisperflow to activate the 3 fans I use and the temp is currently set at roughly 74 degrees before they turn on. That takes all of 1 to 2 minutes once the D-ILA is turned on. I will measure the temp tonight for you as I've been meaning to do this anyway to make sure I have the fan speed set properly.
Tom
[This message has been edited by tommyboy2 (edited 04-10-2001).]
tommyboy2 is offline
post #3 of 13 Old 04-11-2001, 06:38 AM - Thread Starter
kenh's Avatar
thanks, i will really be interested in the temp. inside the whisper flow.
kenh is offline
post #4 of 13 Old 04-11-2001, 06:43 AM
tommyboy2's Avatar
Yikes! My Whisperflow was baking inside at 94 degrees! Needless to say I turned up the fan speed and will watch to see if I'll need to run all three fans.
Tom
post #5 of 13 Old 04-11-2001, 06:56 AM - Thread Starter
kenh's Avatar
don't feel bad i was watching a movie last night and my home made hush box was registering 116 degrees i immediately went over and tuned up the fan and took the sides off, i am really suprised it didn't shut off. i continued watching the movie with the sides off. How hot can these projectors run?
kenh is offline
post #6 of 13 Old 04-11-2001, 10:14 AM
jvalls's Avatar
I have the whisperflow and I really recommend it.
The support and service from Dave was wonderful.
He designed also for me the brackets and how to set up the box from the ceiling.
Send an e-mail to Dave
BEATTYNYC@aol.com
Regards
Jose
jvalls is offline
post #7 of 13 Old 04-11-2001, 10:24 AM
Phat Phreddy's Avatar
try www.whisperflow.com as Dave seems to have registered the domain..
PhatPhreddy@Bigfoot.com
HTPC without using windows... GUI Front Ends for Home Theater
Phat Phreddy is offline
post #8 of 13 Old 04-11-2001, 06:11 PM
M NEWMAN's Avatar
Hi Kenh,
These PJ's can run pretty scaldingly hot before the temp sensors trip and shut down the lamp. While I didn't actually measure the temp of the one I tripped, it had to be in excess of 120 deg. Needless to say, however, high heat = short life (on everything), so keep it cool.
Mike
Mike
M NEWMAN is offline
post #9 of 13 Old 04-12-2001, 11:02 AM
Patrick Bennett's Avatar
The maximum operating temperature listed for my G-11 is 95 degrees F.
Patrick Bennett is offline
post #10 of 13 Old 04-12-2001, 02:58 PM
M NEWMAN's Avatar
That actually would make sense, Patrick, as JVC would not build in a temp cutoff right at 95 deg, but rather a little above it. That along with electronic (10%) variance in values and the fact that there are fans continually blowing that hot air through, and a given PJ could easily approach or surpass 120 deg.
Mike
Mike
M NEWMAN is offline
post #11 of 13 Old 04-12-2001, 04:47 PM
fr8flyr's Avatar
I just ordered one. Nice guy very easy to work with.We talked about my requirements and he answered all my questions and is making a box that meets my needs.
Earl
fr8flyr is offline
post #12 of 13 Old 04-13-2001, 04:36 PM
Dave Beatty's Avatar
Hi Forum,
I have recently made a modification to the inside baffle of the WhisperFlow to improve airflow and lower inside temperature of the enclosure(at lower fan speeds). If anyone has an earlier enclosure and wants to modify, please call me. My goal is to have the best enclosure available at a low cost. Best wishes with your home theaters!
Dave
www.whisperflow.com
Dave Beatty is offline
post #13 of 13 Old 04-16-2001, 01:10 PM
tactical's Avatar
I plan on doing this mod real soon on my Whisperflow and will post pictures if anyone's interested.
-Matt
-Matt
tactical is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
