DLP VS. CRT? - AVS Forum | Home Theater Discussions And Reviews
Old 04-16-2001, 07:57 PM - Thread Starter
smittymd's Avatar
I may have to replace a nec crt projector. My throw distance is only 9-9.5 ft.My screen width is approx. 76". I don't want to spend alot.I don't know whether to think about a replacement CRT, such as the seleco hd-500, or switch to a dlp projector such as the runco vx-101c with video controller. Any opinions on picture quality and which dlp's can handle a throw distance as mine?
smittymd is offline
Old 04-17-2001, 12:34 AM
Jon S's Avatar
Quoted: 798 Post(s)
Liked: 259
Look for a used NEC. They are relatively cheap. If Alan has any left, a XG135 8" crt was $6500. Used ones are about $3000. Be careful though, i bought one on e-bay and it had to go to the shop right away. Someone messed with the controls.
If it's not a BIG screen, it's not a theater...
Jon S is offline
Old 04-17-2001, 03:22 AM
buialat's Avatar
Why don't you look into the Seleco DLP line of products. The screen size vs. throw distance you are looking for is perfectly what Seleco offers.
buialat is offline
