Pixels on VW10HT Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-17-2001, 01:28 PM - Thread Starter
Bally Lakh's Avatar
I received my Sony VW10HT yesterday and when I powered up I noticed a blue dot to the right of the image being projected that seems to be there regardless of any input. I spoke to the people I bought the machine from and they said that it is caused by a bad pixel and it is common to have some of these out in every LCD projector. Also they stated that it is very rare to find a projector that has the perfect LCD panel (no pixels out).
They have offered to replace it however she said that I may end up with a projector that has more then one blue dot.
Is this common and has anyone out there seen this on there Sony VW10HT?
Bally
Bally Lakh
California, USA
Bally
California, USA
Bally Lakh is offline
post #2 of 3 Old 04-17-2001, 01:43 PM
dpgreene's Avatar
Dead pixels are, indeed, a fact of life with most LCD projectors. If the pixels bother you in the course of normal viewing, return or exchange the projector. From a normal viewing distance, one dead pixel (particularly blue -- green are more visible) shouldn't bother you on a 10HT. But if it does, swap it out.
Perfect LCD panels do exist -- but beware, there are far worse problems out there than dead pixels. If this is a good unit that operates well under normal conditions, I'd keep it.
FWIW, I have two dead pixels (one blue, one green) on my 10HT. I only notice them when I mute the picture and stand right next to the screen. Under normal conditions, I never see them.
dpgreene is offline
post #3 of 3 Old 04-17-2001, 02:19 PM
btmoore's Avatar
I received a 10ht with a dead blue pixel. I called my vendor and asked them to replace the unit and to please pre screen it for defeats. They agreed and I now have 0 dead pixels and an excellent picture. If you are dealing with a reputable vendor I think that they should do that for you rather than try to scare you with fud (fear uncertainty and doubt). If they do not satisfy your needs find a different vendor. I used medicalvideosystems.com and found them to be excellent to work with.
Brian
btmoore is offline
Closed Thread Digital Hi-End Projectors - $3,000+ USD MSRP
